I am programing the RSA-Algorithm. Somewhere in the program the user gets the choice to get a rough summary of the algorithm and the various steps used.
To do that I wrote a 1 1/2 page summary in Word. To see how the text is displayed withing the Window I took the first paragraph of my summary and put it in the following code:
with(Maplets[Elements]);
mapletExplainRSA := Maplet(Window('title' = "Erfahre mehr über RSA",
["Das verschlüsseln und entschlüsseln einer Nachricht dient der sicheren Kommunikation. Es existieren bereits Methoden der sicheren Kommunikation. Eine davon nennt man „one way ciphers“ oder „trap door ciphers“.  „One way“ da obwohl alle eine Nachricht verschlüsseln können, nur einer sie entschlüsseln kann. Für jedes Verschlüsselungsverfahren gibt es einen Schlüssel für das verschlüsseln und einen anderen Schlüsseln für das entschlüsseln.",
[Button("Nachricht verschlüsseln", Shutdown("True")), Button("Abbrechen", Shutdown())]]));
Maplets[Display](mapletExplainRSA)
The problem is that when I run this code the whole paragraph is written on the same line and hence does not even fit in the Maplet Window. Is there a way so that my rather long text will be formatet nicely within the Maplet window. Just like it would be displayed using Word. That is a text in paragraph style where sentences are wrapped automatically.
Oskar
******************************************where d1 to d45 -kappa and chi are constant**********
dsys4 := {d1*h1(theta)+d2*(diff(h1(theta), theta, theta))+d3*(diff(h2(theta), theta))+d4*(diff(h2(theta), theta, theta, theta))+d5*h3(theta)+d6*(diff(h3(theta), theta, theta))+d7*(diff(h1(theta), theta, theta, theta, theta)) = 0, d8*h2(theta)+d9*(diff(h2(theta), theta, theta, theta, theta))+d10*(diff(h2(theta), theta, theta))+d11*(diff(h1(theta), theta))+d12*(diff(h1(theta), theta, theta, theta))+d13*(diff(h3(theta), theta))+d14*(diff(h3(theta), theta, theta, theta)) = 0, h3(theta)^5*(d16+ln(h3(theta))^2*d15+2*ln(h3(theta))*d17)+(diff(h3(theta), theta, theta))*h3(theta)^4*(d19+ln(h3(theta))^2*d18+2*ln(h3(theta))*d20)+(diff(h3(theta), theta, theta, theta, theta))*h3(theta)^4*(d22+ln(h3(theta))^2*d21+2*ln(h3(theta))*d23)+h1(theta)*h3(theta)^4*(d25+ln(h3(theta))^2*d24+2*ln(h3(theta))*d26)+(diff(h1(theta), theta, theta))*h3(theta)^4*(d28+ln(h3(theta))^2*d27+2*ln(h3(theta))*d29)+(diff(h2(theta), theta))*h3(theta)^4*(d31+ln(h3(theta))^2*d30+2*ln(h3(theta))*d32)+(diff(h2(theta), theta, theta, theta))*h3(theta)^4*(d34+ln(h3(theta))^2*d33+2*ln(h3(theta))*d35)+h3(theta)^4*(d37+ln(h3(theta))^2*d36+2*ln(h3(theta))*d38)+h3(theta)^4*(diff(h2(theta), theta, theta, theta, theta, theta, theta))*(d40+ln(h3(theta))^2*d39+2*ln(h3(theta))*d41)-beta*h3(theta)^3*d42-chi*ln(h3(theta))^2*d43/kappa-chi*d45/kappa-2*chi*ln(h3(theta))*d44/kappa = 0, h1(0) = 0, h1(1) = 0, h2(0) = 0, h2(1) = 0, h3(0) = 1, h3(1) = 1, ((D@@1)(h1))(0) = 0, ((D@@1)(h1))(1) = 0, ((D@@1)(h2))(0) = 0, ((D@@1)(h2))(1) = 0, ((D@@1)(h3))(0) = 0, ((D@@1)(h3))(1) = 0, ((D@@2)(h3))(0) = 0, ((D@@2)(h3))(1) = 0}; dsol6 := dsolve(dsys4, 'maxmesh' = 600, numeric, output = listprocedure)
hi
DirectSearch answer has confused me. How to reduce the residual.
See the program.Direct.mw
I would like a plot of the solution of this differential equation : diff(phi(x),x,x)=phi(x)*(Ep(x)-E) with for example Ep(x)=(1-exp-(x-2))^2 and E=0.5
So :
>restart;with(plots); xith(DEtools);
>Ep:=x->(1-exp-(x-2))^2;E:=0.5;
>sol:=dsolve({eq,phi(o)=0,D(phi)(0)=0},type=numeric,range=0..10);
>odeplot(sol);
but nothing appear in the plot except axes
Thanks for answer
I want to solve two equations which I am mention in worksheet, i want the answers except complex values, when I am trying to solve in maple 18 it take too much time to evaluate, and also I did not get the answer, give some suggestions and ideas to do solve that work .
two_equations.mw
Thankyou...
Hi everyone,
I have a maple program that generates a polynomial g(y)=(80y^8 + 68y^6 + 12y^4 -4y^2 -1). This polynomial has two real roots (irrational roots), call them +/- y*. My code does a sequential calculation, and often sI am left with a higher order polynomial in y that has the form h(y)= p(y)*g(y), where p(y) is also a polynomial in y. This polynomial h(y)=p(y)*g(y) is not in factored form (i.e. it would look like expand(p(y)*g(y)). Is there a way to instruct maple to recoginize that +/-y* is also a root h(y)=p(y)*g(y)? So far I've tried things like applyrule([g(y*)=0],h(y*)), but nothing seems to work (I suspect because Maple cannot recgonize that g(y) is a factor of h(y)). I am not interested in computing this numerically. I am just trying to find a way to instruct Maple to recognize symbolically that h(y*) =0.
Thanks a million for anyone who has any idea.
Best,
Justin
Hi Maple users :)
do you know if exists a Maple package in order to perform a Panel method, for instance in the Hess-Smith version, for solving incompressible potential flow over thick 2d and 3d airfoil geometries?
Thank in advance for the help.
solve Differential equation "a-y=y' bc" use maple 17
the result is y(x)=a+_C1e^-(1/bc)
but the correct result  isn't y(x)=a-_C1e^-(1/bc) ?
Thank you in advance for your help
Hi :)
I have a Macbook Air running on OS X Mavericks. I am using Maple16.
I created a procedure, which construct two keys. Each of those keys consists of a list containing two elements. That is two primes. So at the end of my procedure I included the following code in order to write my data to a file:
> pkey := fopen(keyFile, WRITE, TEXT);
                      pkey:=1
> writedata(pkey, publicKey);
> fclose(pkey);
The problem is that I can't find the created file "keyFile".
So I tried breaking the problem down. I created a List and wanted to write that list in a textfile in a specific folder:
> L := [1, 2, 3];
> fd := fopen("Users\\****\\Desktop\\fdtest.txt", WRITE, TEXT);
                              fd:=1
> fprintf(fd, "This is a test");
                              14
> fclose(fd);
But this did not work either. It seems like the file fdtest.txt never gets created. This happens in general when I use fopen().
Schloemilch
I have a matrix then I need to plot its columns as curves on one plot.
I'm interested in doing some experimental mathematics using the PSLQ integer relation algorithm.  The only third-party program for doing PSLQ problems I've been able to find is a GNU C++ program with a less-than-user-friendly command-line interface.  I've heard that Maple implements PSLQ and I like the symbolic input and presentation it offers as a CAS, but I can't find any information on which alternative types of Maple 18 make the PSLQ algorithm available.
I am trying to plot several curves with values from matrix columns on one plot.
L1 := zip(`[]`, groups, waitArray[ .. , 1]);
L2 := zip(`[]`, groups, waitArray[ .. , 2]);
plot([L1, L2])
plot(L1) and plot(L2) work fine.
But for a joined plot I have an error
Error, (in plot) incorrect first argument [Array(1..3, {(1) = [5, HFloat(0.2889190508261187)], (2) = [10, HFloat(0.9017773091123074)], (3) = [20, HFloat(2.4000000155705576)]}), Array(1..3, {(1) = [5, HFloat(0.019538366928174924)], (2) = [10, HFloat(0.06875266075705706)], (3) = [20, HFloat(0.1884304855100058)]})]
f1 := expand((a1*x^2+b1*x+c1)^n);
f2 := a1*x^2+b1*x+c1;
solve([coeff(f1, x, 4) = coeff(f2, x, 4),
coeff(f1, x, 3) = coeff(f2, x, 3),
coeff(f1, x, 2) = coeff(f2, x, 2),
coeff(f1, x, 1) = coeff(f2, x, 1),
coeff(f1, x, 0) = coeff(f2, x, 0)], [a1,b1,c1,d1]);
hi,
i cant solve this
int(1/1-exp(a*x)*erfc(a*x))
Vector([a, b]);  <a, b>;  # Identical results
a:=[1, 2]:  b:=[3, 4]:
Vector([a, b]), <a, b>;   # Different results. Why?
First 1438 1439 1440 1441 1442 1443 1444 Last Page 1440 of 2460
