matlab has break point in loops which in extremely useful tool for finding errors in long term loops,whay maple does not has sth similiar !?
hi every one,i want to know what are the maple strentgh compraed to matlab and mathematica ? why someone should choose maple instead of these both ? i searched the net,but nothing useful has been found , tnx in advance .
How to identify whether biased game is changed based on the latest toss from a sequence
can HMM identify this?
for example
if
fair fair fair biased biased fair fair biased
I have a system of diff equations (see below). I am trying to obtain analytical solution. when I assume that z=wN, I receive such solution. Do anybody have idea if I know that z>wN, does this system has an analytical solution?
diff(K(t), t) = -(1/2)*(Q(t)^2*alpha^2*eta*upsilon-2*eta*alpha*(N*upsilon*w*C[max]-z*alpha*K(t))*Q(t)+N*w*(-2*C[max]*z*eta*alpha*K(t)+upsilon*((-N*w+z)*alpha+N*C[max]^2*w*eta)))*K(t)/((C[max]*w*N-alpha*Q(t))*upsilon*N*w)
diff(Q(t), t) = (1/2)*(-z*(Q(t)^2*alpha^2*eta-2*N*Q(t)*alpha*eta*w*C[max]+w*(w*(eta*C[max]^2-alpha)*N+z*alpha)*N)*K(t)-2*N*upsilon*w*(N*w-z)*(C[max]*w*N-alpha*Q(t)))/((C[max]*w*N-alpha*Q(t))*upsilon*N*w)
K(0) = K0, Q(0) = Q0
Dmitry
I would like to set equal to zero some monomials in a polynomial. In particular those monomials in which an unknown has a certain degree.
For example for the polynomial
poly := x^2*y+x*y*z+x*z
i would like to set equal to zero the monomials in which x has degree 1, that is x*y and x*z.
Is there a way to do it?
Manuele
http://www.math.uni-frankfurt.de/~numerik/maplestoch/
read "D:/diffalg03/stochastic9";
Sigma := `<,>`(`<|>`(1.0, .5), `<|>`(.5, 1.0));
V := WienerProcess(Sigma);
Z := t -> exp(a*t+b*V(t)[1]+c*V(t)[2]);
drift1 := simplify(Drift(Z(t))/Z(t));
diffusion1 := simplify(Diffusion(Z(t))/Z(t));
with(stochastic);
linearsde(drift1, diffusion1[1][1]);
Euler(x[1],drift1,diffusion1[1][1]);
1.what are a, b, and c?
2. how to convert SDE for monte carlo for this ito formula?
3. how to convert to euler scheme with this ito formula
Hello fellow maple users,im new to the software,im trying to solve a differential system but it dosent work
This is the system :
DE1 := diff(Y(t), t) = 5*Y(t)*ln(b(t)/Y(t))-5*Y(t)
DE2 := diff(b(t), t) = 5*b(t)*Y(t)^(3/2)-5*Y(t)
Thank you for your help !
I have a function f(X,Y) and I create a random sequence of input values for X and Y.
I now want to create a 2D scatter plot with X and Y on the axis, on the graph I want each point (X,Y) to be color coded according to the value of f(X,Y).  For example, 0<f<1 Red, 1<f<2 Blue, 2<f<3 Green.
Does anyone know how I could do this?
sin(xy) = x + y
subs( y(x)=y, solve( diff(subs( y=y(x), (1) ),x), diff(y(x),x) ) );
-1
subs( x(xy)=x, solve( diff(subs( x=x(xy), (1) ),xy), diff(x(xy),xy) ) );
cos(xy)
I can not get this answer to come out correctly when using this software please help. the correct answer in the back of the book is
1- y cos(xy)
x cos(xy) - 1
And is there a way that this program can tutor me on how to get this answer intead of spitting out the answer
the diff tutor only allows for a one sided equation to be entered.
I wanted to ask whether it's possible to use the taylor command together with vectors from the physics package, maybe I am just doing something wrong here. I tried the following:
and get an error message that diff cannot handle vectors. Of course I could do the expansion by hand an enter the result in Maple but I think it would be a very nice feature because an expansion of vector fields which vary in space and time is such a common problem e.g. in classical electrodynamics. I think of an expansion with non-projected vectors such as
+ higher order terms.
Thanks a lot!
Peter
Hi. I want to differentiate the following expression using "Diff", not "diff". but I want to apply "Diff" to differentiate each separate term based on the chain rule. How can I do that? Does "Diff" apply chain rule for differentiation?
I wish to substitute Re=W[0]/V[0] in the expression V[0]/W[0] * diff(u(t),t). I tried using the subs command but it didn't work. Any help would be appreciated !
When greek symbols are used in code edit region (by copying from worksheet 2d math mode), they used to get exported properly to PDF but the only issue was large code edit region used to get cut off. But now with this new 18.01 update, code edit region is not cut off but greek symbol inside code edit region are not appearing in PDF export instead just pink boxes. Has anyone else also encountered this issue and suggest a resolution.
Hi Everyone,
    I just upgraded a Linux 64-bit computer from Maple 17 to Maple 18.01.  Code that worked on Maple 17 no longer works on Maple 18.01.  The code uses BLAS matrix operations in in the LinearAlgebra package.  When the first such operation is called, I obtain the following fatal error:
MKL FATAL ERROR on loading the function mkl_blas_avx_xdcopy.
Maple 18.01 is unable to load any of the MKL routines even though the MKL shared libraries are in the Linux bin directory.  If I load my own MKL library (provided by Intel), Maple 18 will run these operatrions, but they ultimately lose precision which causes the program (which works fine in 17) to crash.  Any ideas about how to activate the version of MKL provided by Maple?  Will this version not loose floating-point precision?  Any help is greatly appreciated.
Best wishes.
David
University of Chicago
mode_shapes_and_critical_load(changed_model).mw
This is my code for finding mode shapes and critical load for a bimaterial strut under buckling.
Although everything else is working fine but I have a problem while solving for critical load.
h_new := convert(series(h, P, 3), polynom):
without converting to polynomial, the code is unable to solve for P. Even on conversion, for differnet S values, I need to change the truncation order of conversion (like for S=0.5, it would work with 3 but for other S values I have to change truncation (convert(series(h, P, 6), polynom)), which also causes the number of solutions of equation to change which causes problem with plotting of graphs of critical load that I need (basically I need lowest two plots), thereby restricts me from automating the code with a for loop. I need to test it for various S values and then later in code I need to put teh critical load back and check mode shapes for different a values.
Is there a better way to solve two variable equation to get one variable in terms of another(the equation is quite complicated, contains trigonometric expressions).
and also if I try to automate the analysis for different S and a values, teh process needs to put teh value back in P which changes everything and teh next time loop operates it just ruins everything. Also there are varied number of solutions of P_crit for differnet S values which makes it difficult to store those solutions during automation?
First 1446 1447 1448 1449 1450 1451 1452 Last Page 1448 of 2463
