I need to solve systems of numerical equations. I encountered a problem, where one of the parameters (tau[p3]) become FREE, see Maple worksheet attached.
That was clearly not expected.
I spent about 40 mintues to inspect what the problem is, eventually, I find that fsolve works perfectly.
Though fsolve would be the "first" choice for solving floating point problems. I really dont see why the simple "solve" syntax can not work. It is acting strange. And why is *tau[p3]*  FREE, not the others?
Could this be a bug? Or maybe is just WRONG to use solve?
Casper
solve-fsolve.mw
Can anyone tell me how to scroll the context menus in Maple 17?
I'm using the DynamicSystems pkg and would like to use its context menu but it's cut off at bottom of screen.
When I right click on an expression in a Maple document, I get the context menu,but it goes off the screen at the bottom, and I can't find any way to scroll down to see what is cut off.   I tried the Zoom feature on the menu to make things smaller, and it made the print in my document smaller, but the context menu is the same size, and still gets cut off.
Any help appreciated.
hello
1-DirectSearch results is like this:
[0.,[0.], [x = -.400000000000000], 11]
x=.4 is the answer of SolveEquations (code is in the second question) please interpret other terms.
2-how can i save only x?
this is my code:
a := Matrix([1, 2, 3, 4, 5]);
for k from 1 by 1 to 5 do
z = DirectSearch:-SolveEquations(a(1, k)*x+2 = 0)
end do
I'm having some trouble maybe someone can point out my error please. I'm using the Maple 18 worksheet to try some basic linear equations. The trouble is in the last step.
1.) I start with 2 ordered pairs (2, 14) and (14,18)
Then I put in my formula to discover the slope. I confirm it looks correct in the Variables window.
m := (y2-y1)/(x2-x1);
2.)  Next I input the values for my ordered pairs. I also confirm thru the Variables window.
x1 := 2;
y1 := 14;
x2 := 3;
y2 := 18;
3.) Now I can type m and expect to get an answer to what my slope is.
m;
4.) Now I want Slope/Intercept form of y=mx+b. When I put in the formula y-y1=m(x-x1) i get a strange result
When I execute this formula, the result is y-14=4. (or thru context menu I tell it to solve for y, then I get y=18)
y-y1=m(x-x1)
When I manually input the values, the output is y-14=4x-8 (or thru context menu I tell it to solve for y, then I get y=4x+6)
y-14 = 4*(x-2)
Why is my equation (y-y1=m(x-x1)) not executing properly?
Hey everyone,
New here but I'm a bit stuck. Ive looked around in list tools as well as tried but I havent had any luck.
Suppose I have a list defined as FirstList:=[A,B,C,D,E,F]. Now I want to create (and label) all possible
lists from FirstList which contain 4 elements which dont have an element repeated within the same list
In this example, there are 15 lists in total i.e.
Sublist[1]:=[A,B,C,D]:
Sublist[2]:=[A,B,C,E]:
Sublist[3]:=[A,B,C,F]:
Sublist[4]:=[A,C,D,E]:
..etc
Is there a simple way to do this???
Any help is appreciated!
This is one is for Edgardo: In the "mini course", there is a command "PlotExpression" used that does not seem to do anything, at least for me. This is in a fresh Maple 18.01 installation on Linux with the latest version of Physics pulled off the Web today.
I cannot find any reference to PlotExpression in the Maple Help files, so where is this thing supposed to be defined? I >am< running a .mapleinit file of my own, configuring some of the plots[setoptions] parameters to my liking, but it should not clobber anything from the system mapleinit.
Another person managed to get the definition of PlotExpression and send it to me. From that I can see that the underlying plots:-plotcompare command seems to work, at least in part.
USPAS
> local `+`;
Error, unable to parse
meet difficulty running script in maple 12
restart;  local `+`;  `+`:=proc(a,b) :-`+`(a^`~2`,b^`~2`) end proc;
how to override plus + operator so that apply on matrix operation such as linearalgebra package
for example if + =  a^2+b^2
1 + 2 result in 5
and also apply on matrix multiplcation for each element
I am writing a procedure that I would like to have several outputs. The code is as follows:
Initialize := proc (p, theta, PiV, PiU, n, m)
J := CompJ(PiU, m);
for i to n do
if member(i, V) then
Ai[i] := CompAi(PiU, PiV, i, n, J)
end if
end do
end proc
The function calls other functions previously defined that are not important here. Basically I would like to return the set J and the list Ai, but I am not sure on how to do it.
Once the procedure returns these elements, I would like to assign them to some variables. I am not sure on how this can be done when a function returns more than one thing.
Thanks in advance for the help
Bests
Manuele
I have a system of linear differential equations and am trying to solve them using Fourier transforms.
I can reduce the system to a final result (for the variable of interest) in Fourier space as this (note the frequency variable is 'w'):
with(inttrans):
vout_fourier_num := fourier(phi[3](t), t, w) = 6.63569999999998*10^(-15)*w^2*fourier(V(t), t, w)/(-5.69875218358308*10^(-40)*w^4+(9.19473390627057*10^(-29)*I)*w^3+2.15219369729956*10^(-18)*w^2-(4.14691648617110*10^(-8)*I)*w-700.8);
#the drive can be defined as:
drive:=5.70000000000000*10^(-6)*exp(-3.18877551020408*10^18*(t-2.0*10^(-9))^2)*cos(4.8*10^9*Pi*(t-2.0*10^(-9)))*10^(19/20);
#substitute the drive in - this is not necessary, but it should work!...
vout_fourier_num2:=subs(V(t)=drive, vout_fourier_num);
#now take the inverse... note this gives 0!...
invfourier(vout_fourier_num2, w, t);
the final results calculated is zero. It is wrong... it seems like an accuracy issue, but increasing the digits does not help. I should note that I can calculate the solution directly via dsolve, and get completely reasonable answer.
any ideas how to get the Fourier method to work?
thanks!
hello
this is my program and fsolve for low intensity solve the equations but for high intensity cannot solve why?
this is my code:
ep0 := 1/(4*3.14);
el := 8.54*10^(-2);
hbar := 1;
vf := 1/300;
kb := 1;
tem := 2.586*10^(-2);
ci := 1;
p := 1.458*10^16;
beta := 2;
ai := 7.1*10^(-4);
bi := ai/sqrt(3);
enph := .196;
d := enph/(kb*tem);
n0 := 1/(exp(enph/(kb*tem))-1);
gama := hbar*vf;
intensity:=9000000
w := 7.28;
impurity := 7.2*10^3;
g := hbar*beta/(bi^2*sqrt(2*p*enph));
aa := g^2*(n0+1)/(2*Pi*hbar*gama^2);
bb := g^2*n0/(2*Pi*hbar*gama^2);
cc := 2/(Pi*gama^2);
l := (1*hbar)*w/(2*kb*tem);
u := el^2*intensity/(32*w*hbar^2);
[fsolve({op([((enph*ln(1+exp(c+enph/(kb*tem)))/(kb*tem)-polylog(2, -exp(c))+polylog(2, -exp(c+enph/(kb*tem))))*enph*(kb*tem)^2-(enph^2*ln(1+exp(c+enph/(kb*tem)))/(kb^2*tem^2)+2*enph*polylog(2, -exp(c+enph/(kb*tem)))/(kb*tem)+2*polylog(3, -exp(c))-2*polylog(3, -exp(c+enph/(kb*tem))))*(kb*tem)^3+(-exp(b)*enph*ln(1+exp(c+enph/(kb*tem)))+exp(c+d)*enph*ln(1+exp(b-d+enph/(kb*tem)))+exp(b)*kb*tem*polylog(2, -exp(c))-exp(c+d)*kb*tem*polylog(2, -exp(b-d))-exp(b)*kb*tem*polylog(2, -exp(c+enph/(kb*tem)))+exp(c+d)*kb*tem*polylog(2, -exp(b-d+enph/(kb*tem))))*enph*(kb*tem)^2/((exp(b)-exp(c+d))*kb*tem)+(exp(b)*enph^2*ln(1+exp(c+enph/(kb*tem)))-exp(c+d)*enph^2*ln(1+exp(b-d+enph/(kb*tem)))+2*exp(b)*enph*kb*tem*polylog(2, -exp(c+enph/(kb*tem)))-2*exp(c+d)*enph*kb*tem*polylog(2, -exp(b-d+enph/(kb*tem)))+2*exp(b)*kb^2*tem^2*polylog(3, -exp(c))-2*exp(c+d)*kb^2*tem^2*polylog(3, -exp(b-d))-2*exp(b)*kb^2*tem^2*polylog(3, -exp(c+enph/(kb*tem)))+2*exp(c+d)*kb^2*tem^2*polylog(3, -exp(b-d+enph/(kb*tem))))*(kb*tem)^3/((exp(b)-exp(c+d))*kb^2*tem^2))*bb+u*(1/(1+exp(-l-c))-1/((1+exp(-l-c))*(1+exp(l-b))))-(((1*enph)*(enph-2*kb*tem*ln(1+exp(-b+enph/(kb*tem))))/(2*kb^2*tem^2)+2*kb^2*tem^2*(-polylog(2, -exp(-b+enph/(kb*tem)))+polylog(2, -cosh(b)+sinh(b))))*enph*(kb*tem)^2-(enph^2*(enph-3*kb*tem*ln(1+exp(-b+enph/(kb*tem))))-6*kb^2*tem^2*(enph*polylog(2, -exp(-b+enph/(kb*tem)))+kb*tem*(-polylog(3, -exp(-b+enph/(kb*tem)))+polylog(3, -cosh(b)+sinh(b)))))*(kb*tem)^3/(3*kb^3*tem^3)-(-exp(b)*enph^2+exp(c+d)*enph^2-2*exp(c+d)*enph*kb*tem*ln(1+exp(-b+enph/(kb*tem)))+2*exp(b)*enph*kb*tem*ln(1+exp(-c-d+enph/(kb*tem)))+2*exp(c+d)*kb^2*tem^2*polylog(2, -exp(-b))-2*exp(b)*kb^2*tem^2*polylog(2, -exp(-c-d))-2*exp(c+d)*kb^2*tem^2*polylog(2, -exp(-b+enph/(kb*tem)))+2*exp(b)*kb^2*tem^2*polylog(2, -exp(-c-d+enph/(kb*tem))))*enph*(kb*tem)^2/((2*(-exp(b)+exp(c+d)))*kb^2*tem^2)-(exp(b)*enph^3-exp(c+d)*enph^3+3*exp(c+d)*enph^2*kb*tem*ln(1+exp(-b+enph/(kb*tem)))-3*exp(b)*enph^2*kb*tem*ln(1+exp(-c-d+enph/(kb*tem)))+6*exp(c+d)*enph*kb^2*tem^2*polylog(2, -exp(-b+enph/(kb*tem)))-6*exp(b)*enph*kb^2*tem^2*polylog(2, -exp(-c-d+enph/(kb*tem)))+6*exp(c+d)*kb^3*tem^3*polylog(3, -exp(-b))-6*exp(b)*kb^3*tem^3*polylog(3, -exp(-c-d))-6*exp(c+d)*kb^3*tem^3*polylog(3, -exp(-b+enph/(kb*tem)))+6*exp(b)*kb^3*tem^3*polylog(3, -exp(-c-d+enph/(kb*tem))))*(kb*tem)^3/((3*(-exp(b)+exp(c+d)))*kb^3*tem^3))*aa-u*(1/(1+exp(l-b))-1/((1+exp(-l-c))*(1+exp(l-b)))) = 0, -cc*polylog(2, -exp(b))+cc*polylog(2, -exp(-c))-impurity = 0])}, {op([b, c])})];
thank you.
hi,I want to solve this equation with the following boundary condition numerically by maple:
hello evreybody i have these Error :
restart:with(plots):
M:=765 : m:=587 :I:=76.3*10^3 :Jp:=7.3*10^3 :e:=10.92: F:=0.42: omega:=0.56 :ka:=0.1:kb:=0.1:kc:=0.1: lambda1:=0.1 :lambda2:=0.1:lambda3:=0.1:
Error, illegal use of an object as a name
please help
thank you !
Is there away to quickly execute a specific section within Maple? I know that I can execute a selection, but that sometimes requires me to select several lines of Maple code and can be tedious and tiresome.
    I'm finding Maple very useful. I'm a student but not very far along, only in MATH-1075 (intermediate algebra).
I have learned how to plot equations using the context menu, and the smartplot() command.
I have two questions I have not been able to discover an answer for.
When I plot an equation, how can I ask Maple to tell me coordinates of X & Y intercepts?
When I plot 2 equations, how can I ask Maple to tell me coodinates of intersections?
thanks in advance for any help. I tried to look up myself how to do this but was unsuccessful :(
Brent
First 1448 1449 1450 1451 1452 1453 1454 Last Page 1450 of 2461
