AOA... Dears! When i solve the following differential equations
-(diff(lambda(s), s))-2*(diff(lambda(s), s, s))-(diff(lambda(s), s, s, s)) = 0
i got
lambda(s) = _C1+_C2*exp(-s)+_C3*exp(-s)*s
 here _C1,_C2 and _C3 are constant of intergration but i want the constant of integration of the following type
C[1],C[2] and C[3]
due to some reson pl help
I have written a for-end loop and put all the outcomes of the loop in a matrix and now I want to plot these results but for some reason maple won't plot the matrix in a correct way. If I copy-paste the matrix into an new file maple plots it correct. What is the reason that maple won't plot it in my original file?
Here is my file.
Parameters
L := 20; Q := 20; n := 8; h := 3; EAv := 1;
Mat := Matrix(10, 2, storage = sparse);
a := 1;
loop L1
for L1 from .6 by .1 to 1.5 do
L1 := L1;
L2 := 2*L1;
L3 := 1.6*L2;
L4 := (1/2)*L-L1-L2-L3;
alfa1 := evalf(arctan(h/L1));
alfa2 := evalf(arctan(h/L2));
alfa3 := evalf(arctan(h/L3));
alfa4 := evalf(arctan(h/L4));
F4 := (1/2)*Q*L4;
F3 := (1/2)*Q*L3+(1/2)*Q*L4+F4;
F2 := (1/2)*Q*L2+(1/2)*Q*L3+F3;
F1 := (1/2)*Q*L1+(1/2)*Q*L2+F2;
w1 := evalf((1+sin(alfa1)^3)*F1*L1/(EAv*sin(alfa1)^2*cos(alfa1)));
w2 := evalf((1+sin(alfa2)^3)*F2*L2/(EAv*sin(alfa2)^2*cos(alfa2)));
w3 := evalf((1+sin(alfa3)^3)*F3*L3/(EAv*sin(alfa3)^2*cos(alfa3)));
w4 := evalf((1+sin(alfa4)^3)*F4*L4/(EAv*sin(alfa4)^2*cos(alfa4)));
kkm := (w1-w2)^2+(w2-w3)^2+(w3-w4)^2; Mat(a, 1) := L1;
Mat(a, 2) := kkm;
a := a+1
pointplot(Mat);
I have this set of equations but maple won't solve the three variables and it gives an
Error, (in solve) cannot solve for an unknown function with other operations in its arguments. This are the equations with unknowns, alfa1, alfa2, and alfa3.
eq1 := 3*(1+sin(alfa1)^3)(30/tan(alfa1)+60/tan(alfa2)+60/tan(alfa3))/(sin(alfa1)^2*cos(alfa1)*tan(alfa1)) = 3*(1+sin(alfa2)^3)(30/tan(alfa2)+60/tan(alfa3))/(sin(alfa2)^2*cos(alfa2)*tan(alfa2));
eq2 := 3*(1+sin(alfa1)^3)(30/tan(alfa1)+60/tan(alfa2)+60/tan(alfa3))/(sin(alfa1)^2*cos(alfa1)*tan(alfa1)) = (90*(1+sin(alfa3)^3))/(sin(alfa3)^2*cos(alfa3)*tan(alfa3));
eq3 := 3/tan(alfa1)+3/tan(alfa2)+3/tan(alfa3) = 25/2;
solutions := [solve({eq1, eq2, eq3, alfa1 > 0, alfa2 > 0, alfa3 > 0}, {alfa1, alfa2, alfa3})];
Can anyone help?
How can I solve a differential equation set of the type,
dy(x)/dx +y^2 =P(x); dP(x)/dx = R(P) numerically
As we know that the indefinite integral in Maple is defined up to a piecewise constant.
For example,
Due to the indeterminate range of variable n, int returns the piecewise function.
But in the other similar case, we get a generic solution rather than a piecewise function,
Why not to returns the result like this,
Thanks for any help.
How do I plot the graph of 3 functions into one page (that is, as a series). Thank you.
Please this is urgent! I can't seem to be able to upload my job on here.
Hi Everyone, i have question about Piechart.. http://www.mmsonline.com/cdn/cms/Sandvik-pie-chart.jpg
is something like this possible in Maple?
Hello guys,
I'm starting to learn MAPLE this week, so first of all I'm sorry for my lack of knowledge about the software.
I got a worksheet with a ready code, and i'm trying to run it, but I'm receiving an error message that I don't know how to solve, by the fact that I don't know very well yet. But I need to run this URGENTLY, so my hope is that you guys could help me.
The line of code is the following:
S1:-Results(solutionpoint);for cont2 from 1 to 2 do VNUM[jj,cont2]:=(rhs(S1:-Results(solutionpoint)[de+s+m+cont2]))end do;seq(-add(v[k]*x[jj,k],k=1..de)+add(u[r]*y[jj,r],r=1..s)<=0,j=1..n);seq(add(u[r]*y[jj,r],r=1..s)-add(v[k]*x[jj,k],k=1..de)<=0,j=1..n),
And the error message is the following: "Error, invalid sequence". I think that maybe is something really simple like a comma or something like that. Can you please help me? Thank you very much
I would like to compute the elements of the permutation group, let us say S10 or S20.
Is there any method to compute all the elements.
And can we make a list of the tranposition and cycles.
Many thinks.
Dear Colleagues,
1) is there any way to plot the difference of two ode solutions? Smth like display(p1-p2)?
2) is there a way to add a regular plot, i.e. explicit function to the set of plots? I need to have regular plotsand ode plots all together.
So if you are given a 3x3 matrix i was just wondering how to use plot3d and plot the 3 column vectors given by it?  Thanks.
I have a quite long document (around 200 equations + comments).
I need to share my document with collegues.
However, they don't have maple et moreover i would like only to give them my work in a paper format and in a synthetic way. Indeed, they only need to see the main steps of my calculation.
Consequently, i need to make a synthetic presentation of the work i have done on a classic maple worksheet.
For that purpose, i believe that i have 2 ways to do.
1) Create a slideshow. However, i find the mode not very complete in Maple ? Indeed, for the moment, when i have a big section, i didn't manage to scroll on it so as to read the whole section.
2) create a document mode and emphasize only the main equations.
Questions:
1) What is the best solution for you so as to make a presentation of a work made with classic worksheet?
2) Is it possible to transform a worksheet in a document mode? and if yes, how?
3) Have you some ideas to compact the calculation (or emphasize only the main steps) ?
Thank you for your help
im solving 6 ODE which is the equations are unsteady with boundary conditions.. the program can be run when A=0 but when A=0.2 or others value .. its cannot be run... A means for unsteadiness... before this i solve for steady equations.. this is first time i solve for unsteady using maple.. anyone know where i am wrong??? thanks for helping :)
restart; with(plots); n := 2; Ec := 2.0; Pr := .72; N := .2; M := .1; l := 1; Nr := 1; y := 1; blt := 2.5; B := .1; a1 := 1; rho := .5
Eq1 := diff(f(eta), eta, eta, eta)+f(eta)*(diff(f(eta), eta, eta))-(diff(f(eta), eta))^2+l*B*H(eta)*(F(eta)-(diff(f(eta), eta)))-M*(diff(f(eta), eta))-A*(diff(f(eta), eta)+.5*eta*(diff(f(eta), eta, eta))) = 0;
diff(diff(diff(f(eta), eta), eta), eta)+f(eta)*(diff(diff(f(eta), eta), eta))-(diff(f(eta), eta))^2+.1*H(eta)*(F(eta)-(diff(f(eta), eta)))-.1*(diff(f(eta), eta))-A*(diff(f(eta), eta)+.5*eta*(diff(diff(f(eta), eta), eta))) = 0
Eq2 := A*(F(eta)+.5*eta*(diff(F(eta), eta)))+G(eta)*(diff(F(eta), eta))+F(eta)^2+B*(F(eta)-(diff(f(eta), eta))) = 0;
A*(F(eta)+.5*eta*(diff(F(eta), eta)))+G(eta)*(diff(F(eta), eta))+F(eta)^2+.1*F(eta)-.1*(diff(f(eta), eta)) = 0
Eq3 := .5*A*(G(eta)+.5*eta*(diff(G(eta), eta)))+G(eta)*(diff(G(eta), eta))+B*(f(eta)+G(eta)) = 0;
.5*A*(G(eta)+.5*eta*(diff(G(eta), eta)))+G(eta)*(diff(G(eta), eta))+.1*f(eta)+.1*G(eta) = 0
Eq4 := G(eta)*(diff(H(eta), eta))+H(eta)*(diff(G(eta), eta))+F(eta)*H(eta) = 0;
Eq5 := (1+Nr)*(diff(theta(eta), eta, eta))+Pr*((diff(theta(eta), eta))*f(eta)-2*(diff(f(eta), eta))*theta(eta))+N*Pr*a1*(theta1(eta)-theta(eta))/rho+N*Pr*Ec*B*(F(eta)-(diff(f(eta), eta)))^2/rho+Pr*Ec*(diff(f(eta), eta))^2-.5*A*Pr*(4*theta(eta)+eta*(diff(theta(eta), eta))) = 0;
2*(diff(diff(theta(eta), eta), eta))+.72*(diff(theta(eta), eta))*f(eta)-1.44*(diff(f(eta), eta))*theta(eta)+.2880000000*theta1(eta)-.2880000000*theta(eta)+0.5760000000e-1*(F(eta)-(diff(f(eta), eta)))^2+1.440*(diff(f(eta), eta))^2-.360*A*(4*theta(eta)+eta*(diff(theta(eta), eta))) = 0
Eq6 := 2*F(eta)*theta1(eta)+G(eta)*(diff(theta1(eta), eta))+a1*y*(theta1(eta)-theta(eta))+.5*A*(4*theta1(eta)+eta*(diff(theta1(eta), eta))) = 0;
2*F(eta)*theta1(eta)+G(eta)*(diff(theta1(eta), eta))+theta1(eta)-theta(eta)+.5*A*(4*theta1(eta)+eta*(diff(theta1(eta), eta))) = 0
bcs1 := f(0) = 0, (D(f))(0) = 1, (D(f))(blt) = 0, F(blt) = 0, G(blt) = -f(blt), H(blt) = n, theta(0) = 1, theta(blt) = 0, theta1(blt) = 0;
f(0) = 0, (D(f))(0) = 1, (D(f))(2.5) = 0, F(2.5) = 0, G(2.5) = -f(2.5), H(2.5) = 2, theta(0) = 1, theta(2.5) = 0, theta1(2.5) = 0
L := [0., .2, .5];
[0., .2, .5]
for k to 3 do R := dsolve(eval({Eq1, Eq2, Eq3, Eq4, Eq5, Eq6, bcs1}, A = L[k]), [f(eta), F(eta), G(eta), H(eta), theta(eta), theta1(eta)], numeric, output = listprocedure); Y || k := rhs(R[3]); YP || k := rhs(R[5]); YR || k := rhs(R[6]); YQ || k := rhs(R[7]); YA || k := rhs(R[9]); YB || k := rhs(R[8]) end do
P1 := plot([Y || (1 .. 3)], 0 .. 10, labels = [eta, (D(f))(eta)])
P2 := plot([YP || (1 .. 3)], 0 .. 10, labels = [eta, F(eta)])
plots:-display([P1, P2])
Error, (in plots:-display) expecting plot structures but received: [P1, P2]
Download unsteadyManjunatha.mw
Help!!
Why do the first two of the following 4 examples not work in Maple 15?
subs(m=21,`mod`(m, 4));
subs(m=21,m mod(4));
                               21
                               21
`mod`(21, 4);
21 mod(4);
Is there a (simple) workaround?
Hi:
i have two functions(f(x)&g(x)),i calculated values this functions with numerical method(dsolve,numeric),
now i will plot the f(x)-g(x) for 0<x<1,how do this work?
First 1460 1461 1462 1463 1464 1465 1466 Last Page 1462 of 2462
