Where can i read about logic of assignment in maple? In all normal languages
c:=0;
c:=c+1; returns c to 1.
While maple gets into reccursion. Why politics of assignment was made so? Why imstead process all previous assignments maple also seems to process current one while calculating rhs (or lhs via evaln)? Where can i read about that and how actually assign value to expression without postprocessing of current operator ?
I have a for loop :
for n to 20 do 'A'^n = A[1]^n end do
Is it possible to change the way the output is displayed ? Right now its just on in one collum in the document, and a row for each do. Is it possible maybe to set it up in 2 collums or even 3 ?
Dear Forum
Lets say, I use the simplify function to process some expression and it returns x*x. On the paper, I find x^2. How can I use Maple to verify that x*x==x^2?
Thanks for any hints.
How to do subj? Straightforward way doesn't compile:
myint:= proc(u::float)::float;
return int(exp(x^6), x=0.0..u);
createcomp:=proc (expr::evaln, exprfunc::evaln);
exprfunc:=(v::float)->unapply(evaln(expr),a)(v);
return Compiler:-Compile(exprfunc,optimize);
global_expr:=myint(a)+a^a;
s:=createcomp(global_expr, global_exprfunc);
"Error, (in Print) cannot translate value of lexically...
How can i trunc (find closest integer) each element in a matrix ?
This is my matrix equation:
for n to 20 do 'CD'^n, 'F' = evalf(C[1].D[1]^n.F[1]) end do
And i want to show  "trunced" results
How can the ?DifferentialGeometry package be used to apply a vector (derivative) to a scalar?  I thought Hook might be used here, but I don't know that there is a way to express a scalar as a 0-form.  Consider
with(DifferentialGeometry):
DGsetup([x,y],E2):
Hook(D_x, x^2);
Error, (in DifferentialGeometry:-Hook) expected 2nd argument to be a differential form or bi-form. Received x^2
> eqns := {(x[1]+1)^2+y[1]^2 = (x[2]-1)^2+y[2]^2, (x[1]-c[1])^2+(y[1]-c[2])^2 = (x[3]-1)^2+y[3]^2, (x[2]-c[1])^2+(y[2]-c[2])^2 = (x[3]+1)^2+y[3]^2, y[1](x[3]+1) = y[3](x[1]+1), y[2](x[3]-1) = y[3](x[2]-1), (x[2]-c[1])(y[1]-c[2]) = (x[1]-c[1])(y[2]-c[2])};
 /          2       2            ...
The variable A is a matrix in Maple. I need to show A, A^2, A^3, ....., A^19, A^20, and that i do by making a for loop:
for n to 20 do A^n end do
And it works and shows correct results..
But i want to show more than just the result of each step in the for loop.
The result right now is without variable name etc. How can i show more than just the result ? ...
I have changed the Typesettinglevel to extended.
Hello guys,
I am unfamiliar with maple and have problems with dsolve complex system:
dz*_i/dt=sum(sum(z_i-z_j),j=1..2),i=1..2).
where i not equal to j and z* is conjugate(z).
here is my code:
for i from 1 to 2 do
summ(i)=0
od;
for j from 1 to 2 do
if i <> j then
summ(i)=summ(i)+(z_j(t)-z_i(t));
end if
od;
od
Dear Forum
I'm trying to evaluate the following expression:
Int(Int(Int(N*exp(-alpha*r^2)*N*exp(-alpha*r^2)*r^2,r=0..infinity) *sin(t), t=0..Pi),p=0..2*Pi)
The value of the integral should equal 1 and from that the value of the normalization constant N can be obtained. It should equal sqrt...
ggg:=(y,a,b)->
(2*(-a+6*y^2*a^2+2*b*y^2*a^2+9*b*y^3*a+3*b*y^2*a+b*y^6*a^2+4*b*y^5*a^2+5*b*y^4*a^2+2*b*y^5*a+8*b*y^4*a+3*b*y^3*a^2+4*b*y^2-y^3*a-3*y^2*a+y^6*a^3+5*y^5*a^3+8*y^4*a^3+4*y^3*a^3+y^5*a^2+5*y^4*a^2+9*y^3*a^2+b*y^4+4*b*y^3+y*a^2+2*a*b*y+y^3*a*(y+1)^(-2*b)+a*(y+1)^(-2*b)+3*y^2*a*(y+1)^(-2*b)+3*y*a*(y+1)^(-2*b)-2*y^2*a^2*(y+1)^(-2*b)-y*a^2*(y+1)^(-2*b)-3*y*a-y^3*a^2*(y+1)^(-2*b))/(y^2*(a+b)*(y+1)*(y+2)^2*(y*a+1)^2)+(-2-y^2+2*y^2*a^2-2*y+4*b*y^3*a+8*b*y^2*a+2*b*y^4*a^2+4*b*y^3*a^2...
I'm trying to use the geometry module. I tried the following code:
> with(geometry);
> point(A, xA, xB);
A
> point(B, xB, yB);
B
> line(AB, [A, B]);
line: One of the following conditions must be satisfied xA-xB <> 0 xB-yB <> 0
Error, (in geometry:-line) not enough information: the line is not defined
As you can see, maple is unable to create the line object since the two points can be the same....
calchas:~ sedoglavic$ maple
    |\^/|     Maple 14 (APPLE UNIVERSAL OSX)
._|\|   |/|_. Copyright (c) Maplesoft, a division of Waterloo Maple Inc. 2010
 \  MAPLE  /  All rights reserved. Maple is a trademark of
 <____ ____>  Waterloo Maple Inc.
      |       Type ? for help.
> 264 ;
I have downloaded the quaternion package in Maple but I can't figure out how to plot them. According to the help page I need a package 'with(Plots)' (with a capital P for plots). Has anyone had any success in plotting quaternions? I'd really appreciate some help.
What is the total number of the nonnegative integer solutions of the system
{x+2*y+5*z-10^2012<=0, x+3*y+4*z-10^2012<=0}?
Edit. Bad copy and paste and  the tags.
First 1826 1827 1828 1829 1830 1831 1832 Last Page 1828 of 2457
