How many randomly ordered signals are required until we achieve a chaotic signal, or one that is undistinguishable from being random? Another way to put it, although not a good example, is if we had an infinitely large room full of people talking, what is the minimum number of people needed to be to make the noise appear random? Of course making a few unrealistic conditions such as the volume of each persons speech is heard at the same level and pitch no matter their distance...
readshare(gfun,analysis):
with(gfun):
orec:={y(n)+(n+1)/x*y(n+1)-y(n+2)-(n+2)/x*y(n+3)=0};
erec:=borel(orec,y(n));
edeq:=rectodiffeq(erec,y(n),Q(w));
sol := dsolve(edeq,Q(w));
Please help me out!
there is an error in using dsolve!
what can I do?
Eq17 := -3*m2*b*(diff(alpha(t), t))^2*(diff(alpha(t), t, t))*(1/2)+((-m2*b*(diff(beta(t), t, t))+2*m3*a*b*sin(beta(t))+b*sin(beta(t))*a*m2+m3*a*c*sin(beta(t)+theta(t)))*(diff(beta(t), t))+(m3*a*c*sin(beta(t)+theta(t))+m3*b*c*sin(theta(t)))*(diff(theta(t), t)))*(diff(alpha(t...
i follow a book's command
with(share):
with(gfun):
orec:={u(n+2)+u(n+1)+u(n)=n}:
odeq:=rectodiffeq(orec,u(n),y(x)):
dsolve(odeq,y(x)):
OGF:=op(2,");
orec:={(n+4)*u(n+2)+u(n+1)-(n+1)*u(n)}:
erec:=borel(orec,u(n)):
edeq:=rectodiffeq(erec,u(n),y(x)):
dsolve(edeq,y(x)):
EGF:=op(2,");
1. all can not run with dsolve in maple 15, error expecting ode or a set or list of ode,
2. what is the meaning of op(2,");?
I need to do this:
A:=[1,3,5,2,7];
B:=[2,5];
f(B,A)=[3,7]
Notice that the elements in A can be lists themselves. How can I define such kind of function?
TIA for the help
I am trying to plot this function Sigma(R30) but I get failed to do so. Any one would like to try to help me out?
The attached maple sheet contains the asymptotic solution of the huge equation in .txt file.
thx.
 20110819_doodles2.mws
20110818_section4-5a.txt
How can I plot the intersection of x^2+y^2+z^2<=9 and x^2+y^2+(z-3)^2<=9?
Is the intersection of this two equations a 3D region?
trig_integrals_prime.mw
if you put these integrals into Tool...Tutors...Calculus SV ....Integration methods, you get simpler "nicer" answers than when you integrate them directly in a worksheet (even after simplification).
why the difference?
I am currently attempting to write my own program in maple for the 2nd order Runge-Kutta method for a second order differential equation. What I am finding dfficlut is assigning the initial conditions.  I want to include the condition that
(d(theta)/dt)[0]=v_0 and then proceed to evaluate using different values of v_0, however I'm not allowed to assign a value to a differential.
How do I go about including this condition?
Georgie
(i^2+i*alpha+i*beta+i)*Q(n)+((-x*alpha-x*beta-2*x+beta-alpha)*n-x*alpha-x*beta-2*x+beta-alpha)*Q(n+1)+((1-x^2)*n^2+(-3*x^2+3)*n-2*x^2+2)*Q(n+2) = 0
After using diffeqtorec, there is n in coefficient, if multiply x^n/n! to all terms, i can not convert some to exponential function due to n^2, n and the difference of outer coefficient n not greater than n+2 in Q(n+2)
as i do not know the initial condition of above formula, differential equation is no use.
I wrote a procedure that solves an optimal control problem governed by volterra integral equation. This procedure  takes N , number of lagrange interpolating polynomials, as parameter and call NLPSolve function .the problem is: for N>10 maple displays this Error: Error, (in Optimization:-NLPSolve) object too large. How can I fix this problem?
here is my procedure:
Hi! I need some help with a curve I'm trying to plot.
f(x,y)= x^2*y^2/(x^4+y^4)
I'm asked to intersect the surface produced by f(x,y) with the plane z=1/4 and to plot the curve generated by the intersection (in 3D). I found how the curve looks like but I don´t know how to plot that in 3D.
hi
I want to have a fprint command which should given me the data in two columns.
I want to modifiy the following command
fprintf(fd,"%f \n",li,sigmai);
this command gives me data in horizental form, i.e.,
0.001000 0.300990 0.600980 0.900970 1.200960 1.500950 1.800940  2.100930
But i want it in the follwoing form
 li              sigma
0.001000 0.300990
 0.600980 0.900970
I Just shifted to Maple from TI-Interactive and i'd like to know if i can make equations and formulars without output and still using maples attributes such as when i divide stuff and it automaticly puts one under the other.
I TI-interactive i used the inser --> object and then chose the Microsoft Equation 3.0 for making equations where i write the output.
Is there a command to change differential equation into difference equation?
First 1858 1859 1860 1861 1862 1863 1864 Last Page 1860 of 2457
