How to solve this receurrence relation with maple
a[k] := (2/5)*a[k-1]*ln((1/10)*(exp(1)*x/a[k-1])^10)/ln(10^a[k-1]*(exp(1))^4)
I found various methods, as listen here http://en.wikipedia.org/wiki/Recurrence_relation, to solve recurrsion relation. For example, methods of undertermined coefficients
But how to use these to solve the the above recursive relation.
I'm trying to animate a DEplot3d, but is that even possible? If it is, how?
Budgie
with(gfun):
> s := series(sin(x), x, 9); seriestoalgeq(s, y(x));
                  1  3    1   5    1    7    / 9\
              x - - x  + --- x  - ---- x  + O\x /
I tried to use the Physics package in maple 13 to make operations in the algebra M_2(E) - the algebra of 2x2 matrices over the grassmann (or exterior) algebra. E is a noncommutative algebra, and some of its elements anticommute with each other.
The problem is that when I multiply such matrices, the answer is not right. Maple multiply this matrices considering the entries as commutative, what is not true.
Here are the commands I used:
> with(Physics);
I've made a model and i wanted it to work out a distance, which it does. But it gives me an answer in the for a/pi, where a is a number. In my model I've used angles, which maple uses as radians. But I want the answer to be a decimal number and not the fraction in the form a/pi, even thought the value a/pi when worked out is right.
How can I convert this a/pi into a decimal number?
Do I need to use the convert command, and if so what goes in the brackets of this command?
Hi all
I have used pointplot3d to plot a set of points using three vecotrs v1, v2 and v3 which all contain many elements and the same number of elements.
I would like to know how to plot a new set of elements for new vectors v4,v5, and v6 on to the same plot as the previous set of values.
Could I then give each of the two sets a different color?
I want to make a numerical approximation of the number Pi to a defect that is not more than 0.0001
I use maple to verify some examples in my textbook. The followings are two warnings which I came across.
1.
> with(DynamicSystems); sys := TransferFunction((1+.2*s)/(1+.1*s));
> ResponsePlot(sys, Step());
When running the codes above, a warning appears unexpectly.
Warning, cannot evaluate the solution past the initial point, problem may be complex, initially singular or improperly set up
With this question, I...
I'm working on implementing a plot of the Lorenz equations, and I'm trying
  proc(something, something, more something) local something more;
  uses DEtools;
  something;
  end proc
And I get this response:
  Error, `DEtools` is not a module or member
What can I do? "uses" works for plots, LinearAlgebra etc. Why doesn't it work for DEtools?
I want maple to calculate sqrt(Pi) with an accuracy of (10)^-200 with Newton Raphsons method. How do I do?
I have this non-linear ODE in q(p):
ode := diff(q(p), p) = (q(p)-a*p)/(p-a*q(p))*(p^(-b)-1)/q(p)^(-b);
for some real parameters a and b, it may be solved in exact form for the special value a=1.
Is there any hope of getting a closed-form solution or of expressing the solution in a neat way for the case 0<a<1? even some specific value of a would be of interest, e.g. a=1/2.
dsolve(eval(ode,{a=1}));
let us consider the series
y = a_0 - sum(a_i,i=1..n)
here the terms a_i are defined recurrsively as follows
a_i = (a_(i-1) -4*ln(x)/ln(10) + 4/10 + 4*ln(a_(i-1)) )/ ( 1+ 4/(a_(i-1) * ln(10)))
a[n] := (a[n-1]-4*ln(x)/ln(10)+4*(1/10)+4*ln(a[n-1]))/(1+4/(a[n-1]*ln(10)))
how can i program this in maple. so i can...
Why doesn't 'ln(e)' simplify to '1' in Maple 12.02?
The problem arose from trying to simplify the solution of an ODE that contains a combination of exponentials, logarithms and powers. Maple refuses to simplify, whereas I can easily read the simplified answer. Maple seems to ignore the simplest of algebra concerning power, logarithms and exponentials.
what is the general sum formula for the following seires (we may notice from these few terms it has a pattern)
y-15.6+4*ln(y)/ln(10)=0
First 1919 1920 1921 1922 1923 1924 1925 Last Page 1921 of 2457
