I have a pair of equations,
-xt[1,1]+a*tanh(xt[1,1])+a[12]*tanh(xt[2,1])=0,-xt[2,1]+a[21]*tanh(xt[1,1])+a*tanh(xt[2,1])=0
and I want to calculate xt[1,1] and xt[2,1];
when i use
solve([-xt[1,1]+a*tanh(xt[1,1])+a[12]*tanh(xt[2,1])=0,-xt[2,1]+a[21]*tanh(xt[1,1])+a*tanh(xt[2,1])=0],[xt[1,1],xt[2,1]]);
warning comes out," Warning, solutions may have been lost", and the solution [0,0] I am looking for is really lost.
I am to solve this differential equation (nonlinear):
C'(t) = G[0]+0.1*sqrt(C(t))-C(t)*n+C[ude]*n
G[0] = 1.7*1.2*83
n = 6
C[ude] = 417
i need to use programming since the DE is nonlinear.
Does anybody have the solution to that?
Best regards,
Marie
how we can convert mathematica5.2 worksheet into maple13 worksheet?
f:=x->x^3:
y[1]:=0.5:
y[3]:=subs(x=y[1],f(x)):
i := 2:
y[i] := y[i-1]-(y[1]-y[2+1])*(1/2):
i:=1:
g[i] := (y[i+1]-y[i+2])*x/(y[i]-y[i+1])+(y[i+2]*y[i]-y[i+1]*y[i+1])/(y[i]-y[i+1]):
g[i] := unapply(g[i], x):
h[i] := unapply(solve(y = g[i](x), x), y):
for i from 2 by 1 to 7 do
g[i]:=(f@h[i-1])(x);
g[i]:=unapply(g[i],x);
y[i+2]:=subs(x=y[i+1],g[i](x));
s:=solve(z=g[i](x),x);
h[i]:=unapply(s[1],z);
for i from -1 by -1 to -8 do
Is it possible to write a Maple program which prints itself and only itself?
Hey guys I'd be grateful if you can help me plot the following graph. It's the position of an elementary volume before a supernova takes place.
x0=r0sinθ0cosΦ0
y0=r0sinθ0sinΦ0
z0=r0cosθ0
create a mesh of 10 mesh points, divide the ranges
0<r<any positive value
Usually Maple gives solutions in terms of radicals only up to degree=4
(for example using RootOf + allvalues).
Using 'irreduc' (to test first) and 'galois' (to check for the Galois
group, if degree <= 9) I have cases, where the result implies, that by
theory the roots can be given through radicals:
Though the results are difficult to read in my case they are 'C(6)' or
'C(8)', the cyclic groups of that order - thus abelian and IIRC those
groups are solvable.
I have maple 13 and have been trying to set up some plot of a single point on a plane, to teach plotting in two dimensional plane.The figure at the following page may help you to get an insight of what I am trying to do in maple:
http://en.wikipedia.org/wiki/Cartesian_coordinate_system
Any advice?
Regards!
Sohail
Basically I have two curves, P1 and P2, which are dependent on Q1 and Q2 in a square manner. For example, P1:=1+Q1^2 and P2:=5-Q2^2. I now want to plot P1 and P2 on the same graph with the values of P1 and P2 on the same z-axis and Q1 and Q2 along the x- and y-axes. Consequently I would get two orthogonal parabolic curves. plot3d([P1,P2],Q1=-1..1,Q2=-1..1) doesn't work because it obviously draws two surfaces rather than two curves for P1 with Q2 always equal to...
Can anybody please help :
a_j := [-1/2 (r-q) j Delta t + 1/2 sigma^2 j^2 Delta t] / 1 + r Delta t
b_j := [1 - sigma^2 j^2 Delta t] / 1 + r Delta t
c_j := [1/2 (r-q) j Delta t + 1/2 sigma^2 j^2 Delta t] / 1 + r Delta t
with r:= 0.05, Delta t:= T/N , Delta S:=S/M, T:=0.4, q:=0, K:=1.1, S:=2, M=N:=10
Then I defined i:=N; such that f_{i,j}:=max(K - j*Delta S, 0);
And next I defined g_{k,j}:=f_{i,j}...
Could somebody help me I am having trouble with an if statement.
I have defined three functions a.b and c in terms of one variable j.
I have correctly defined g_{k,j} as well as other functions and now I have run into trouble with my if statement.
p:=(k,j)->if k=0 then max(K-j*S,0) else g_{k,j} end if
I think its clear what i am trying to achieve in the if statement as I want to be able to enter p(1,4), p(4,3) etc. . .  after the if statement...
Please help me with the following.
I have this function
y(theta,t):=1/4*Pi + A*sin(m*theta) + A*sin(m*theta)* (exp(-1/4 *alpha^2*beta^2)-2)/(4*Pi)*t;
which can also be written as
Hey!
I am trying to simplify this: (a+b)(a-b). As we all know, this is a2-b2. Maple, though, returns this: a(a+b) - b(a+b) which is also correct, but not what I want it to show :D Any way to make it show a2-b2?
I tried simplify, factor, expand - they all give the same result. Am I doing it wrong? :D
I try to sketch and solve PDE
PDE:+diff(u(x,t),t)+2*diff(u(x,t),x)=0
with boundary condition
u(0,t):=piecewise(0<t and t<=2*pi, sin*t,0)
how to get the solution u(x,t) and sketch u(x,0),u(x,pi),u(x,2*pi),u(x,3*pi)?
the derivative of the improper integral int(cos(1/sqrt(u))^2,u=0..x) at the point x=0 with Maple?
First 1921 1922 1923 1924 1925 1926 1927 Last Page 1923 of 2457
