I would like to include the current date in the filename when I use writedata.  How can I do that?
I know this doesn't work but I was trying to do something like this
  test:=[1,2,3,4,5,6]
  writedata("c:/data-FomatTime(%B%d%H%M).txt",test)
hi all
im reading documentation about mapleNET web services
"Currently the input strings must represent Maple 1-D expressions. The output will be Maple 1-D expressions."
what is Maple 1-D expressions?
Motion_of_a_Charged_.mw
The procedure I uploaded, was originally written in C++. I made a text file and plot the file with C++ without any problem.
But in the maple version of the same program, when I use the command:
I am using Maple to generate PDEs. I have expressions of the form p(dx,dy,dz, etc.) where p is a nonlinear polynomial. I would like to substitute d/dx for dx etc and then later apply the resulting differential equation to a function. I am having multiple problems with this.
1. Maple seems to be unable to handle a derivative unless there is a function for the derivative to act on. (This is not a huge issue, but it would be helpful.)
2. Even if I do specify a function Maple maps dx^3 to diff(f,x...
I would like to know how to plot different series of data on the same graph.
Thanks in Advance
hi all
in maplenet after next link  "/maplenet/imaging/image?maple=Histogram([1,2])"
i do not see image of Histogram, just image of formula 'Histogram([1,2])' , what need for generate image?
I'm trying to hide all text created in text mode (F5) so that all I see are the calculations or text typed in Math mode.  How do I do that?
I could create subsections with text but that's bulky.  I've tried document blocks but that only hides the calculations, the opposite of what I wanted.  Have I missed something?
I have a grafic, a power curve, and a few values of the curve.
The values are in 0.5 steps. I would like to calculate the values for all the 0.1 steps.
For example:
I know the values for 4, 4.5, 5 etc. and would like to find out the values for 4.1, 4.2, 4.3 etc.
Is this possible using Maple?
Best regards,
Calin
When I plot csc(k*x) for various values of k, the timing varies considerably depending on the value of k.
Here are the timings for k = 1..5 (note the strange case of k = 3):
  seq(time(plot(csc(k*x), x = 0 .. 2*Pi, -3 .. 3, discont = true)), k = 1 .. 5);
               0.031, 0.031, 14.133, 0.046, 0.062
For k = 6, the time is apalling:
I was wondering if anyone has any experience with conic optimization (ie Mosek)
to solve large scale portfolio optimization problems. It all seem so complicated.
It should be possible to call such an optimization engine from Maple right?!
I'm looking for this application : "A Double Pendulum Model using DynaFlexPro and Maple"
Does anyone have it ?
Indeed,it's no more on this site : http://www.maplesoft.com/applications/view.aspx?SID=1682
I really need to make a simulation of the motion of a double pendulum, using Maple.
After I have opened internet explorer with Maple
process[launch]("C:/Program Files/Internet Explorer/iexplore.exe")
what command do I use to close it with maple?
 hi
I want to solve this problem
Symbolic_Matrix.pdf
with that code
sumbolic_matrix.mw
hi
I have got an eq: Curl(A)=B;
Both A and B are vectors,  for example,
A(x,y,z):=Ax(x,y,z) _i+Ay(x,y,z) _j+Az(x,y,z) _k;
B(x,y,z):=Bx(x,y,z) _i+By(x,y,z) _j+Bz(x,y,z) _k;
can I get A as a funtion of B? if I can, how to deal with it, and if not, what other known conditions should be added to solve it?
any help would be appreciated@。@
I have the following data file
1.1    0.751    0
1.5    0.764    0.419
2       0.777    0.665
2.5    0.796    0.791
2.71   0.81     0.81
and I want to plot the 2nd column vs the 1st and the 3rd vs the 1st on 1 axis, with the 1st column on the x axis.
Is...
First 1994 1995 1996 1997 1998 1999 2000 Last Page 1996 of 2457
