Hi all
I very very new to Maple so please forgive me if this not a great question.
I'm trying to input the command lfsrlength(v,n) to calculate the determinants mod 2, however Maple is just returning the command and not the determinants please see below
L101;  [1, 0, 1, 0, 0, 1, 1, 0, 1, 1, 0, 0, 0, 1, 0, 0, 1, 0, 0, 0, 0, 1,
        1, 1, 0, 0, 0, 0, 0, 1, 0, 1, 1, 1, 1, 1, 1, 0, 0, 1, 0, 1, 0,
I'm trying to get a blank procedure call to work.  How can I go about doing that?
I wanted to do something like this
changedir:=proc(change)
  if change=NULL then currentdir("f:/") else currentdir(change) end if:
changedir()
Error, invalid input: changedir uses a 1st argument, change, which is missing
Can someone help me out here, is it possible to select a column from a matrix result in maple.
for example using the Eigenvector(M) command lets say i get the result
How can I find out how many positions there are in a table?
I have this equation:
2.3 = .5/(1+exp(-.3*i[2]-.5))+.7/(1+exp(-.6*i[2]-.3))
When I atempt to solve fori[2] this is the answer I get:
i wan't to compare the result with x1(t)=x2(t) of two ode,then modify v1,v2 in the form diff(x1(t))=v1,diff(x2(t)=v2 ,but the triger seem's fit to either one  of x1(t),x2(t), thus the action can't  excuted on the both,who can help me .
 hi
I am new in LinearAlgebra and i have many question in it,
My problem is in this pdf files and i described in it my question.
Matrix.pdf
I am using Maple 14 with Windows Vista OS and I would like to ask 2 questions:
1) Is there any possibility to change the width of a slider? I have 2 very similar source codes of the slider (one horizontal, one vertical). I would like to use the vertical one, but the biggest value does not appear correctly. This value should be "1000", but only "100" appears. In the horizontal case everything is OK.
Here are the source codes you can try:
L:=[[name,4,3,6,5],[3,5,name],[3,6,1,2,9,8]]   I want to remove name from the listlist or all 3's for example
I've tried
remove(has,L,3) which removes the entire sublists containing 3 so I tried
map(remove,`=`,L,3) but that doesn't work I thought since remove(`=`,L,3) worked on a flatlist that using map would work on the listlist or even map2(map,remove,`=`,L,3).  I can't figure it out.
And how do you use member on L?  I end...
Hello wizards,
I'm given to understand that using add() or if possible Task:-Add() is more efficient than a FOR...DO loop. Today I'm asking about the limits of this generalization. My illustration is probably missing some evalf's, but hopefully the concept is clear:
A computation I'm working on involves between 10E4 and 10E6 computations like
Occasionally I want to restrict a search of MaplePrimes to posts from a specific user.  Is that possible?
How can I create a matrix M by M with maple, where the elements of diagonal comes from b[i]=i+1 and the other elements comes from c[i,k]=i+k.
Amr
Using the Physics package I am trying to define commutation rules between operators. However it looks like when the commutator involves a Dagger, it is not "remembered" properly. Here is a (contrived) example (you might have to run it on your machine in case not clear from copy/paste what's going on):
with(Physics):
Setup(quantumoperators={a, b, c});
Hi:
How do I tell maple that some of my variables do not commute with each other?
For example i may have variables a_p and a_m which do not commute with each other, as well as s_x and s_y which also don't commute with each other... but a and s do commute. So basically I want maple to recognize that
a_m * a_p != a_p * a_m
but
a_m * x_s = x_s * a_m, etc..
... and be able to keep these rules when simplifying expressions.
Note,...
The code below changes the starting value of a to the last value of b (in Maple 14). Is that a feature?
> a := matrix(2, 2, [1, 2, 3, 4]);
> b := a;
> for i to 2 do for j to 2 do b[i, j] := (1/3)*b[i, j] end do end do;
> evalm(b);
> evalm(a);
First 1993 1994 1995 1996 1997 1998 1999 Last Page 1995 of 2457
