How can I write a vertical etiquette (title) in parallel with y axis ?
How can I give a legende inside the plot (inside Figure) ?
How can I make symboles for different curves ?
Since a few weeks i use Mac OS X, I downloaded the accordingly maple version from my campus server and installed it. I can start the program, but when I enter a simple instruction like plotting x^2, I get a little progress window with the headline "Kernel Connection Not Available", in the window there is: "Waiting for kernel connection" with a status bar and a Cancel-Button. The status bar runs through until about 60% and then it doesn't go on.
Can you...
I've just added a reply to an old thread I opened some month ago, but I don't see the thread at the top of the recent questions. Where is it gone????
Should I re-open a thread?
ps the thread was this one: http://www.mapleprimes.com/questions/35837-Execution-Stopped-Unhandled-Signal-Caught-UNKNOWN-1#comment96090
I'm trying to solve the following ode:
[-5*e4(r)*E+3*r*e5(r)*dE-5/3*r*e8(r)*dE+2*e7(r)*E+3*e1(r)*E-4/3*r*e2(r)*dE = 0, 1/3*1/r*(3*r^2*e5(r)*dE-6*r*e4(r)*E-12*M*e7(r)*E+10*M*r*e8(r)*dE-3*r^2*e1(r)*dE+6*M*e4(r)*E-3*M*r*e5(r)*dE+6*r^2*e4(r)*dE+8*M*r*e2(r)*dE-18*M*e1(r)*E-r^2*e2(r)*dE+6*r*e7(r)*E-5*r^2*e8(r)*dE) = 0, 1/3*r*(4*e7(r)*E-5*r*e8(r)*dE-4*e4(r)*E+5*r*e5(r)*dE) = 0, r^2*e2(r)*dE-2*r*e1(r)*E+1/3*r^2*e4(r)*dE+2/3*r^2*e7(r)*dE-8/3*M*e7(r)*E+10/3*M*r*e8(r)*dE+2/3*r*e4(r...
I am trying to determine whether there is a particular order to how Maple displays complex and real solutions to equations. for example if I input
>solve(diff(x^6,x)=k,x);
There are obviously complex and real solutions to this, and the output displays both but does Maple always display the real solutions first?
I am trying to solve the following optimization problem:
max ∑ij cijxij
st.: xij ≤ indic(∑uvxuv>0), u≠i, v>j, for all i & j,
      xij=0..1, for all i & j, where "indic()" is the indicator function.
My problem lies in evaluation of the inequality constraint. It gives back an error about the non-numeric type of the expression.
I have a list of single digit integers
mylist:=[1,2,3];
and it is easy to use
for x in mylist do convert(mylist[x],binary) end do;
to obtain 1, 10, 11 as the result.
However if
mylist:=[1,2,25];
two values are converted sucessfully but the third produces "Error, invalid subscript selector"
whattype(mylist) gives "list"
whattype(mylist[3]); gives "integer"
is there some way to handle piecewise functions as if they were just another equation? In this case I´ve got a piecewise in 4 segments, one of them empty. The other segments are equations that solve a function for a variable under constraints, i.e. it shows somewhat like:
{(conditions1), q[O]=(...), (conditions2), q[O]=(...), (conditions3), q[O]=(...), else, []}
(I hope you get what I mean. The piecewise is a tad long and I wouldn´t...
Hi folks,
i am brand new to Maple so please excuse if i ask a probably simple question:
Is it possible to get data from the first row of an array into a DropDownBox?
I created an array named mat, if i type something like test:=mat(2..,1) Maple shows me the information i need in a column.
Now i want to create an Element (DropBox) in which i want to select data from a list that should show me the same information as the...
I try to find minimum value for numbers as follow,
for i from 1 to 1000 do
x:= 1+i;
y[i]:= 2*x+1;
a:=min(seq(y[k],k=1..1000));  print(a); od;
in this case the maple can not provide any solution
however, when i use 100 instead 1000 i obtain result as follow,
for i from 1 to 100 do x:= 1+i;  y[i]:= 2*x+1; a:=min(seq(y[i],i=1..100));  print(a); od;
could you please help me to solve this problem?
Has someone an idea how to create a hysteresis plot that models a system with hysteresis?
A simple plot can be created by plotting two arctan functions (g1,g2)
But, I'd rather need a continous function as in the second example (f1..3).
I'm learning an elliptic curve scalar multiplication algorithm on GF(p^m). I'm trying to find some examples about using Maple to implement an elliptic curve scalar multiplication algorithm on GF(p^m) so that I can learn and apply it to implement the algorithm I'm learning.
However, I couldn't find any example up to now, maybe I'm unlucky.
Please help me if you know any Maple package or example that I can refer.
Thank you for your help in advance.
 If you see my last question "use fsolve or matrix dissection"CCC.mw
I want to find C, i finally solve it and get My special C
Now , I Want tolve My problem in block mode,
CCCd.mw
this means that, My matrix elemnts are block matrix, and search for result,
I have been using release 14, but was wondering whether MAPLE now can do things standard in MATLAB, JAVA: Is there a way to use the mouse for extract the coordinates of a point from a maple-plot [[ e.g. want to use initialize a dsolve() by graphically selecting the initil data.]] going further, is there a way to "draw" a curve on a maple plot using the mouse -- and get the coordinates of points along the curve back into the worksheet )(e.g. as an array that can be further manipulated)?
Hi guys,
I am wriiting some work in Latex and need to input some Maple code into my Appendix. Does anyone know how to do this? Also, if i have separate sections of code to input in different places, can I create subsections of the Appendix to cater for this?
First 1991 1992 1993 1994 1995 1996 1997 Last Page 1993 of 2457
