Assuming I have a general function f(x). The derivative with respect to x would be: df/dx .
I now want to rescale, which basically means that I want to change x to a*y where a is a parameter (general constant) and y is my new variable.
If I use
subs( x=a*y, df(x)/dx )
I get
d/d(a*y)  f(a*y)
but 'a' should be a parameter, so this should give
1/a * df(a*y)/dy = df(y)/dy
How do I tell that to Maple?
I know that I have raised this question before, and also got some responses.
However, I cannot find the thread, and I'm still interested in what is going on.
I don't have a clue.
f:=proc(a)
plot(sin(x),x=0..Pi);
#plot(x^3,x=0..1);
#plot(undefined,x=0..1);
a^2
#Now try plotting what should be the parabola y = x^2 on the interval -1..1:
plot(f,-1..1,adaptive=false);
plot(f,-1..1);
plot(f(a),a=-1..1);
Another pointplot3d animate problem
when the axes option is not specified the view option magnifies the symbols when symbol=circle
The field of view is not increased as it should.
animate(pointplot3d, [[[1, 2, 3], [4, 5, 6], [2, 2, 2]], color = blue, symbol=circle, orientation = [A, A]], A = 45 .. 405, view = [-100 .. 100, -100 .. 100, -100 .. 100], frames = 100);
 This is in Maple 12, I haven't checked to see if it exists in newer versions of Maple.
 i want to create matrix that it`s element are matrix.
for example my matrix is 3*3 and elements are 2*2
in addition my element-matrix elements are unknown(x11,x12,........)
i got many float data from 'for' sentence relating x,e.g.
for i to 4 do
  x := 0.01*i;
  if (i = 1) then
    y := 0.2;
    z := 0.05:
  elif (i = 2) then
    y := 0.3;
    z := 0.5:
  elif (i = 3) then
    y := 0.5;
    z := 1.05:
  elif (i = 4) then
    y := 1.2;
    z := 2.05:
Hello all,
I have a nonlinear model y=f(x,y,z,p) that I'd like to solve for various value of p (parameter), where f is a system of equations. This model is constrained by a set of inequalities c(x,y,z,p) <= 0.
I coded the model up in Maple in the following format:
f1 := ...;
f2:=....;
f3:=...;
f4:=...;
c1:= x>=0;
c2:= ....;
etc.
To solve this, I type:
i got a set of roots of nonlinear equation by fslove method.e.g.
y1:=a^4+b-3=0;
y2:=a^3+b^2+2=0;
fsolve({y1, y2})
⇒{a = -1.402752934, b = -.8719054433}
i got roots value of the equation,but i want to continue to use direcly the float values of 'a' and 'b' in my program,but i couldnt ues them by some methods since 'a' and 'b' didnt seem to be assigned.so i had to write the values in a text file,then...
I have a maple worksheet with 2d input:
> for i to 10 do f := proc (x) options operator, arrow; x^2 end proc; f(x) end do;
of course it looks "pretty" in the actual worksheet.
When I export this to Latex I get the standard stuff and this:
\begin{maplegroup}
\begin{mapleinput}
\mapleinline{active}{2d}{for i to 10 do f := proc (x) options operator, arrow; x^2 end proc; f(x) end do; -1}{\[\]}
I ' m trying to plot this parabolas and hyperbollas and all I am getting is like a triangle and a couple of crossed lines. (with or without scaling=constraint)
polarplot(4/(1+1.1*sin(x))):
polarplot(2/(1-sin(x)),x);
polarplot(2*1.5/(1-1.5*cos(x)),x);
Is it another problem with Maple?
i have system of two equastion with two vairable (x,y) and paramater ( b1,...,b4, a,...,a4 ) as follow,
 q:=b4*(y^3)+b1*x*(y^2)+b2*(x^2)*(y)+b3*(x^3);
q1:=a*y+a1*x+a2*x*y+a3*(x^2)+a4*(y^2);
solve({q,q1},{x,y}):
maple doesnot  give any result except o,o solution
can you help me to solve this problem ?
is there any package that able to find the solution reither than numerical method?
i have a same problem , could you please help to solve this problem?
I used maple help to solve my problem but for this one I could not.
I have equation system with 4 equations and variables are for example x y z w .
The problem is I  have  xy  x^2  x^3  yw   in my equations so maple with solve could not solve that.
On the other hand,the equation are parametric and non numeric I mean the answer...
I get a data of string type from .txt file,but i want to use the data from string type to float tpye in my program,In fact ,i had tried in many methods,convert,sscanf,type etc.but, i coundnt solve this problem until now.if u know,please tell me how can i do.
example:
x:="0.01"⇒x=0.01
Assuming I have an expression, 'F', I would like to extract from it a factor, 'a', so the expression is displayed as
a*(F/a)
where F/a is a simplified (or expanded or any other displayed form) expression.
As an example:
F:=1 + Q*x2 + P*x3
a:=x2 / L2
then this will be displayed
x2 / L2 * ( L2 / x2 + Q*L2 + P*L2*x)
This doesn't seem to work in Maple 13 and 14.  However it works in Maple 12.
All I get is a static animation plot.
animate(pointplot3d,[[[1,2,3],[4,5,3],[2,2,2]],color=blue,orientation=[45,A]],A=45..315);
What am I doing wrong?
I started my university project 5 months ago and working with maple from that time.
On the other hand,the equation are parametric and non numeric...
First 1989 1990 1991 1992 1993 1994 1995 Last Page 1991 of 2457
