I have this relatively simple 4 equations which I am trying to solve simultaneously. But for some reason Maple just returns a pair of empty square brackets as solutions. "[ ]" like this.
I have uploaded the Maple Worksheet for your convenience. It would be very helpful if anyone can take a look at it and point out out the problem. Thank you.
Simultaneous_Eq.mw
I tried to find out whether the expression
g1:=2*mu*(phi+ln(mu/(exp(phi)*sigma2-sigma2+mu)))/((-sigma2+mu)*phi)+mu*(1/(exp(phi)*sigma2-sigma2+mu)-mu/(exp(phi)*sigma2-sigma2+mu)^2)*(exp(phi)*sigma2-sigma2+mu)/((-sigma2+mu)*phi)-mu^2*(phi+ln(mu/(exp(phi)*sigma2-sigma2+mu)))/((-sigma2+mu)^2*phi);
is positive under the given assumptions:
is(signum(g1)=1) assuming mu>0, sigma2>0, phi>0, sigma2<>mu;
I need to use the flexible beam in my model. I want to know if the component's correctness can be guaranteed, but I can't find any correlative documents or thesis, only find an article titled "Dymola – Flexible Bodies library". Is the flexible beam in maplesim similar to this? based on the modelica library? applied the finite element method? Some detailed information is very helpful.
I have a little problem, I tried to find out the Temperature of the Electrons in a Plasma,
the cross section name is sigma and I'm working with noble gases and there Threshold energies.
In the end I wand to find out  T_e but there comes only "Warning, solutions may have been lost"
Can anyone help me please?
Thank you very much
greetings from munich
I want to solve this
2010.pdf
I'm dealing with a complicated expression:
exp((1/6)*kappa*R^2-0.5000000000e-1/R)*sqrt(x)-1+(1/2)*kappa*exp((1/6)*kappa*R^2-0.5000000000e-1/R)/(sqrt(x)*(1+coth(exp((1/6)*kappa*R^2-0.5000000000e-1/R)*sqrt(x))))-(1/6)*kappa*(exp((1/6)*kappa*R^2-0.5000000000e-1/R))^2+0.5000000000e-1/exp((1/6)*kappa*R^2-0.5000000000e-1/R) = 0.
I want to plot various graphs of kappa vs x for different values of R on one axis. How is this possible in Maple?...
Is there a possiblity to create custom multibody components with the custom component template? Is there another template available for this purpose, or do you propose another solution?
Thanks a lot,
Bernd
Can anyone help me convert this outdated maple code into something current? Particularity I need help finding the equivalent command to "stats:-empirical" as I can't even find documentation for it.
with(stats): with(linalg): with(StringTools):
P1:=matrix([[.6,.3,.1],[.4,.5,.1],[.3,.4,.3]]);
j:=1:  res:="S":
for i to 50 do
    j:=random[empirical[op(convert(row(P1,j),list))]]():
I appreciate that maple can solve equations so quickly, but i would like to solve the equation myself and only use the basic features of maple so that I can practice the theory. For example:
for the differential equation y'' + 3y' + 2y = 0
I would like to assume y = ce^rt then plug it in and get something like
c*(r^2*e^rt + 3r*e^rt + 2e^rt) = 0
maple runs into problems regarding:
-whether the parameters are functions or constants
Download problemexample.mw
Hello Maple wizards,
After reading the mapleprimes post http://www.mapleprimes.com/posts/36097-Add-Map-And-Seq on the hidden complexities of using thread-safe versions of add (Threads:-Add), I have been struggling to correct a problem similar to the "escaped k" problem described by Joel Riel...
I have a family of functions characterized by
f:=x^2+b*x+b*3;
I plotted some of them:
graph1:=x->subs(b=0,f):
graph2:=x->subs(b=2,f):
graph3:=x->subs(b=4,f):
plot([graph1(x),graph2(x),graph3(x)],x=-10..3,y=-5..15);
And now I want to draw a line through all maxima into the same diagram. The maxima have the coordinates (-1/2*b | -1/4*b^2+3*b). I managed to create a pointplot:
The help page mentions that filledregions=true, that regions defined by curves are filled with different colors
implicitplot({y = x^2, y = x+5}, x = -10 .. 10, y = -10 .. 10, numpoints = 5000, filledregions = true)
What I expected was that the region between the line and the curve would be a different colored region.
Hi friends,
I am running an application which consumes big memory (~2GB); and in the middle of calculation I got this error:
Kernel connection lost... and the message is:
Execution stopped: Memory allocation failed! Please see ?alloc for more details...
Please let me know how I can increase memory alocation capacity of maple (version: Maple 13)
Hi guys,
I am new to Maple, so forgive my ignorance!
I need to define the implicit function R:=exp[(L/2)-(m/2R)] for use. When I attempt this the normal way, I get a 'recursive argument' error. How can I get round this?
Jimmy
I tried to carry out an advanced plotting task and I am not even sure, if Maple is able to do that.
In a Cartesian coordinate system with axis x=1..100 and y=0..1, I wanted to plot three graphs at once and have the parameters n, p and rho to be interactive.
Here are the graphs:
(1) y=1-exp(-rho*x);  #depending on x and rho
(2) y=-(1-p)^n+(p/(1-p)+1)^n*(1-p)^n+(1-p)^(n-1)*((exp(rho)*(-1+p)-p)*((exp(rho)*(-1+p)-p)/(exp(rho)*(-1+p)))^(n-1)-exp(rho...
First 2012 2013 2014 2015 2016 2017 2018 Last Page 2014 of 2463
