I was wondering if there is a more elegant way of doing this:
SX := proc ()::set; local j, sx, SEqn; Digits := 30; SEqn := {evalf(subs(EV, Eqn(1)))}; for j from 2 to n do SEqn := `union`(SEqn, {evalf(subs(EV, Eqn(j)))}) end do; sx := SEqn end proc:
Charles
Please , can anybody tell me about the basical things to know about Maple that are not described in the internet . I mean about adding a new line with the sign > , joining or parting two parts , or insert a title and above all where i can find the list of the pakages wee need to perform a program .
hi
I have this PDE:
PDE := diff(f(x, y), x, x)+diff(f(x, y), y, y) = 0
With BCs
bc := {f(0, y) = 0, f(1, y) = 0, f(x, 0) = 0, f(x, 1) = sin(Pi*x)}
which has a relatively simple exact solution.
I'm trying pdsolve and getting nowhere, either numerically or symbolically.
Any advice most welcome
PL
Hello everyone, I wonder how to carry out the so-called total derivative over a certain function with retaining the differential symbol "d". For example y=r*sin(theta) then how to obtain the following result from maple dy=r*cos(theta)d(theta)+sin(theta)dr. Thank you.
Hello there I'm a newbie, both here and to Maple !
I am performing arithmetic operations with polynomials. Can I get a step by step solution with such operations?
how can i found the integer number after any divident using maple commands
like
(13/4)
The following is a section of my codes:
Say if i have the following how can I label the contours with the value of f that each of the isovalue contour represent?
For example I tried:
L:=[a,b,c];
for i in L do
i:=Array(1..16):
I wanted to create three Arrays a, b and c.
I have an Array A with 90 rows and 16 columns.
The first column of each row denotes the name of a card, while the other 15 colums of each row specify certain characteristics of that card.
Moreover I defined a couple of selection rules Ri, to define sublists of A, which contain only the entries of the first column of A and where the number of elements in Ri is known a priori.
E.g.
R1:=[0$14]:
q:=1:
for i to 90 do
if A[i,2]=4 or A[i,2]=0 then
R1[q]:=A[i,1]:
q:=q+1:
end if:
Hi folks,
I'm using Maple14 (Build ID 479326).
It's unable to solve the folwing
fsolve({(1.+x[1])*exp(x[1]) = 7.505833908*10^26, (1.+x[2])*exp(x[2]) = 3.000809640*10^12}, {x[1], x[2]});            (1)
while the following is OK!
Hi, is there in Maple a generic identity matrix, i.e. with (symbolic) identity matrix behavior? I need it in order to perform some symbolic matrix computations, for example: (I-A).(I+A+A^2+...) Thanks,
Hi, Question 1: Is it possible to have names using subscripts? I've tried a few names with subscripts. Sometimes it works, sometimes it doesn't. Question2: There must be a faster way to write greek letters using the keyboard instead of going to the greek palette and clicking the greek letter you want. I wasn't able to find how to do that yet.
I want to implement from the following,
> A := `<|>`(`<,>`(6, 2, 1, 6, 8, 3), `<,>`(4, 3, 7, 1, 7, 2), `<,>`(3, 7, 2, 4, 3, 9));
> b := `<,>`(55, 37, 40, 33, 60, 75);
the procedure:
A x X = B
X = A x BA = U x S x V (Singular value decomposition of A)
A = V x S x U(Generalized inverse or pseudoinverse of A)
X = V x Sx Ux B
Least square fit solution
x = 2.63293929474354
y = 3.66652382290048
First 2017 2018 2019 2020 2021 2022 2023 Last Page 2019 of 2457
