Hi everybody is there a built-in procedure that transforms a complex number in its exponential form: a+I*b -> sqrt(a+b) exp(I*arctan(b/a)) Tks S.
Hey, i am a undergraduate at uni and i have run in to a bit of a roadblock with Maple.
I am using the following code;
M[Star]:=2*10^(30);
M[planet]:=2*10^(27);
q:=(M[planet])/(M[Star]);
Delta[p]:=max(H,|R-a|);
Alpha(R,a):=piecewise(R<a, -(q^(2)*6.67*10^(-11)*M[Star])/(2*R)*(R/(Delta[p]))^(4) ,R>a,(q^(2)*6.67*10^(-11)*M[Star])/(2*R)*((a)/(Delta[p]))^(4) );
PDE1:=diff(S(R,t),t)=(3/(R))*(diff(R^(1/(2))*(diff( S(R,t)*R^(1/(2))-(2*Alpha(R,a)*S(R,t)^(3/(2)))/((6.67*10^(-11)*M[Star])^(1/(2))),R)),R));
Does anyone know how to export surface plot with multible surfaces to a file format that can be easily plotted using matlab?
Regards Brian
I am brand new to maple and im having a very hard time. My teacher gave us an assignment but he didnt teach us how to use maple.
Can someone please explain to me how i can find the horizontal asym. of sqrt(9*x2 - 4*x + 2)+ 3*x - 5?
and how would i find the x and y intercepts?
thanks a lot
Hi all, Being new to Maple, I have a rather trivial question for most out there. How does one plot x=ln(y) or any function x=g(y) to be more general? I have worked with implicitplot() as such, but it only feels like drawing a straight line for x=ln(y). Here is the syntax I used: > g := y -> ln(y) > with(plots) > implicitplot(g, x = -10 .. 10, y = -10 .. 10) Does maple expect the assignment of the full equation (i.e. g:= x = ln(y)) in order to process inverse or implicit functions? I'm obviously borking the syntax. I have searched through this forum and the help. Any information is thoroughly appreciated in advance. Phillip
Hello if you can help I would really appreciate it.
I have a loop that gives me real, complex and imaginary solutions, and a few zero solutions. I am only interested in the zero solutions and so i only want to see what my input values are when the solution is zero. All i need is some command to discard all solutions except the zero solutions at every interval of the loop so that i can see the corresponding input values.. I tried selectremove but its not really working, is there a way to do this? If this doesnt make sense i can clarify more.
(&sum;)a[ijk](t)(x^(j))^((k))+b^(j)(t)=0,i=1,..,n.
click enter,and the font will be automatical converted to Times New Roman
but with error information about my subscript (j,k)
s1 := series(sin(x), x, 6)
c1 := series(cos(x), x, 6)
e := exp(1)
e1 := series(e^x, x, 6)
how to make s1+c1 =  e1's form,but x-(1/6)*x^3+(1/120)*x^5+O(x^6)+(1-(1/2)*x^2+(1/24)*x^4+O(x^6))
Hi wizards,
I've recently migrated some Maple-based research to an 4-way AMD 64-bit system running Linux Ubuntu 9.10 (Karmic Koala). installed Maple 11.02, and thanks to previous forum posts I was able to resolve the blank document window problem, and was able to install a version of libstc++.so.5 that is required by NLPSolve in this version of Maple. Although I picked it up in a forum that claimed to distinguish between 32-bit 64-bit versions, it looks like I'm not out of the woods yet. In response to an Optimize call, Maple returned
I am trying to graph a torus using maple.
z= 1 - (r - 5)
Could someone please help. I think I need to use implicitplot3d but need help setting it up.
I also want to set up an integral that will allow me to find the volume and surface area of the torus. Any help appreciated. I do not know maple that well at all by the way.
When I execute the code below, dsolve returns the trivial solution. If I were to apply the BCs by hand I'd conclude that there is a set of eigenvalues associated with the ODE. Is there a way to have Maple produce the eigenvalue equation automatically, or would you typically apply the BCs by hand to find it?
Y_diffEq:=diff(y(x),x$4)-beta^4*y(x)=0;
Y_BCs:=y(0)=0, (D@@2)(y)(0)=0, y(L)=0, (D@@2)(y)(L)=0;
dsolve({Y_diffEq,Y_BCs},y(x));
PS
Is there another way to specify the derivative BC?
Has anyone used MapleSim to coordinate with Matlab/Simulink Model for the purpose of making their autocode the most effiecent?  I belive from  a webinar I watched something like this could can be an application of MapleSim.  I'm curious if anyone  has used it for that purpose?  If so, what were the challenges/benefits? Did you save in embedded memory needed (i.e. smaller autocoded files) or shorter proccesing time measured?
Hi, im having trouble with selectremove. Im trying to select R(z)>=0 or if R(z)=0 then Im(z)>0, i tried this:
selectremove ( if z--> R(z)>=0 else R(z)=0 then Im(z)>0 end if , % );
but its not working, any help would be much appreciated.
I've been working on my master's project and am at (at least I hope I've got it) the final stage of making Maple do everything that I want it to. I have the flow chart here which is a little hard to see while looking at the module I have set up.
The difficulty I'm having is getting it to run as a whole. I just do not know what I need to do to get the thing started. The way I have it set up is that each procedure references another until they are done - a loop structure. Which may be more appropriate but I humbly submit it to you.
I do not completely understand the module pieces. I do know that each procedure I have inside of here should work (and if not, that's why it's a master's problem :D)
Thank you again for looking!
 (I know the local and export may not be correct, and sorry for the matrix multiplication looking so ugly here)
I want to evaluate a polynomial and turn its coefficients into hfloats. Shouldn't evalhf do this? For example:
f := randpoly([x,y,z]);  # integer coefficients
g := evalf(f);    # software float coefficients
h := evalhf(f);   # error
I think the last one should give me a polynomial with hardware floating point coefficients. Instead I get an error.
First 2046 2047 2048 2049 2050 2051 2052 Last Page 2048 of 2458
