I have the following terms: >
a := .178131; 0.178131 >
e := -0.6814e-1*`if`(t = 0, 6, `if`(t = 1, 10, `if`(t = 2, 15, `if`(t = 3, 20, NULL))));
 f := 0.16242e-1*`if`(t = 0, 6, `if`(t = 1, 10, `if`(t = 2, 15, `if`(t = 3, 20, NULL))))^1.5;
The ODE is:
Q1: Write a procedure named MULTIPLYMATRIX to find the product of an n x m matrix by an
m x q matrix. Your procedure should print the result matrix. The dimensions n, m, q should be
input parameters in your procedure. Test your procedure by demonstrating multiplication of a 2 x
3 with a 3 x 4 matrix of your choice
I have been struggling to solve this problem.
I want to minimize this function for w, x and y:
((w^2)/2)+((a/3)*x^3)+(2by)+((2a/3)*y^3)
Subject to w+x+2y=1
Where a and b are positive constants
And also, I want to minimize this function for w, x, y and z:
((3w^2)/2)+((2a/3)*x^3)+(by)+(ay^3)+(bz)+((a/2)*z^3)
where a and b are positive constants.
I've tried a ton of stuff on maple and have been unable to figure it out.  Any help is greatly appreciated!
I have a multivariable function, F(n, g(1,0),g(0,1),g(0,2),g(1,1),g(2,1),...,g(n,1),g(n-1,2),...,g(1,n)), of indeterminates g(i,j) (omitting g(0,0) - in other words - let L = set of all pairs of nonnegative integers, (i,j), which satsify 1<= i+j <=n) of the following form F = product over all the (i,j) in L of g(i,j)^h(i,j) / ((i!
Does anyone know how to shade the tails (eg the lower and upper 5%) of a probability density function?
thanks!
Eq1 := 55200.0*(1+(3.20000000*10^7*a+1.200000*10^5*b+400*c+d)^2)^.5*(2.048000000*10^15*a+7.680000000*10^12*b+2.560000000*10^10*c+6.40000000*10^7*d)/((3.20000000*10^7*a+1.200000*10^5*b+400*c+d)*(4.800000*10^5*a+1200*b+2*c))-1.177600000*10^12*(1+(3.20000000*10^7*a+1.200000*10^5*b+400*c+d)^2)^1.5/((3.20000000*10^7*a+1.200000*10^5*b+400*c+d)^2*(4.800000*10^5*a+1200*b+2*c))-1.766400000*10^10*(1+(3.20000000*10^7*a+1.200000*10^5*b+400*c+d)^2)^1.5/((3.20000000*10^7*a+1.200000*10^5*b+400*c+d)*(4.800000*10^5*a+1200*b+2*c)^2) = 0
EQ1 := 55200.0*(1+(3.20000000*10^7*a+1.200000*10^5*b+400*c+d)^2)^.5*(2.048000000*10^15*a+7.680000000*10^12*b+2.560000000*10^10*c+6.40000000*10^7*d)/((3.20000000*10^7*a+1.200000*10^5*b+400*c+d)*(4.800000*10^5*a+1200*b+2*c))-1.177600000*10^12*(1+(3.20000000*10^7*a+1.200000*10^5*b+400*c+d)^2)^1.5/((3.20000000*10^7*a+1.200000*10^5*b+400*c+d)^2*(4.800000*10^5*a+1200*b+2*c))-1.766400000*10^10*(1+(3.20000000*10^7*a+1.200000*10^5*b+400*c+d)^2)^1.5/((3.20000000*10^7*a+1.200000*10^5*b+400*c+d)*(4.800000*10^5*a+1200*b+2*c)^2) = 0;
I need to integrate an ODE : I use dsolve.
As there is not an exact solution, I use numeric integration :
F := y''(x) + a(x)*y'(x) + b(x)*y(x) ;
EDF := {F = 0, y(t0) = y0, y'(t0) = dy0};
Snum := dsolve(EDF, y(x), type = numeric);
S  := x --> rhs(Snum(x)[2]) ;
I can now plot the graph of the solution S.
But suppose I need also the graph of the derivative S'.
As this function is solution of Y' + a*Y + b*S = 0,
I code
I have a large number of lists labelled L1, L2, L3 ...etc.
I want to determine the number of elements in each list.  If I had labelled my lists L(1), L(2), L(3) ... I would easily have been able to pull out the number of elements with sequence
seq(nops(L(i)),i=1..3);
nops doesn't allow multiple arguments.  Is there any way I can use seq on the lists L1, L2, L3, ... etc  In other words, how can I have a two letter variable and get maple to vary the 2nd variable?
hi, i have a set of roots, say [a,b,c,d]. how do i make them so that maple will give me the roots like this:  {m=a},{m=b},{m=c},{m=d} ?
I have already plotted the intersection of 5 surfaces but need to plot their intersections, is this possible and if so how? Cheers
What is the correct syntax for:
java_args= - D entity ExpansionLimit = 1000000?
I get the following error: Invalid option in launch.ini I follow the instructions given in: "There were problems during the loading process. Your worksheet may be incomplete." http://www.maplesoft.com/support/help/view.aspx?sid=26039
Gracias
i am first time using maple for my cryptographic scheme i recently developed. I am wondering if there is any builtin package or library for AES Encryption/Decryption and SHA256 in MAPLE 11.
the "StringTools" can provide md5 hash of the message but i need SHA256 implementation and AES 256 bit encryption/decryption module in Maple.
any suggestions?
I was wondering if there is a way to compute the discriminant of a rank r quadratic form in maple? Alternatively, is there a way to diagonalize, via symmetric row and col operations, a symmetric matrix A over Z_p? For instance, modifying RowReduce in LinearAlgebra[Modular]. If I can do this then I can obtain the discriminant. Example: >with(LinearAlgebra[Modular]): >p:=5; >Matrix(4,4,[[0, 1, 1, 4], [1, 0, 1, 0], [1, 1, 0, 1], [4, 0, 1, 0]]); >RowReduce(p,A,4,4,0,0,0,0,0,0,0); # would like a symmetric row and column reduction
Hello.I could use some help to solve the folowing system, please.
Basically I have the 4 unknowns (A,P,C2,alfa)and I want to know their values by changing values to "a2" (eg. varying a2 from [0;80]).
With another software I solved matricially the EQ2;EQ3 and EQ4 for P,A and C2 with different values of a2 and then I replaced the P,C2 solutions (for each a2 value) on the EQ1 and tooked the value of "alfa" for each corresponding "a2". At the final I had the 4 unknows solved varying the "a2" value.
First 2050 2051 2052 2053 2054 2055 2056 Last Page 2052 of 2458
