Hi everyone, I have question that i cannot solve.
The question is :
Write a procedure named MULTIPLYMATRIX to find the product of an n x m matrix by an
m x q matrix. Your procedure should print the result matrix. The dimensions n, m, q should be
input parameters in your procedure. Test your procedure by demonstrating multiplication of a 2 x
3 with a 3 x 4 matrix of your choice.
I mean when typing polynomials, convert the 2x4 to 2x^4,,,
for 4 is in the right
and sometimes I'm a little lazy(?).
p1:=4*y^2+12*y-4*x*y-6*x+x^2+8
a is "coeffs(p1)"
b is "coeffs(coeffs(p1, {x, y}))"
c is "coeffs(p1, [x, y])"
d is "coeffs(p1, x)"
e is "coeffs(p1, x, y)"
the results of a,b,c are the same
8, -6, 12, 4, 1, -4
and the results of d,e are the same
4*y^2+12*y+8, -4*y-6, 1
question 2:
I'd like to get the both resuls of "coeffs(p1, x)" and "coeffs(p1, x)" at the same time,
what's the simplest way?
I have some calculations/results which I use in many other documents. Is there anyway to link to this document that contains results I need for another sheet in the beginning of the sheet I need the calculations for?
Regards Brian
If you make a misspelling in spacecurve as in
plots:-spacecurve([ARctan(t),t,t], t=0..10);
then Maple 13.02 (Standard) loses contact with the kernel.
Even if you forget 't ='  as in
plots:-spacecurve([ARctan(t),t,t],0..10);
Maple will lose contact.
It seems that also Maple 12 has a problem.
Maple 13 Classic doesn't have the problem.
Will these and other 3d-plot problems be corrected in Maple 14?
Preben Alsholm
How do I write a loop to store a set of values for t and n(t) into an array?
I wrote a loop to get the values:
>for t  from 1 by 1 to 25  do print(t, f(t)) end do
but don't even know where to begin with putting them into an array.
Thanks for any help.
why dont any of maples 11, 12, or 13 work properly in windows seven? for example: when i click on "open a file" or "save" botton, and then it opens a window, the respective window dont show "up one level" or "create new folder" and "details" bottons above it.
This is a student portfolio attached below. When I open the file, it says that "There were problems during the loading process. Your worksheet may be incomplete." The first time it happened, all of the graphs became blank, and the second time, only a portion of the worksheet shows up. Is there any way to retrieve the file?
Thank you...
Is it possible to set an external image-file as background in a 2d plot?
I am trying to define a function in terms of a solution of dsolve. I initially tried the following method:
I defined my function as:
a := 10; ode := diff( n(t), t ) + a*n(t);
Then I solve it using dsolve and store it as a function:
f:= t -> dsolve( ode, n(0) = 10);
This was syntactically wrong so I tried:
f:= t-> rhs( dsolve( ode, n(0) = 10) );
 How do I implement this sum in maple:
Sum(A[i,j],i=1..12) with j<>i
Gracias
This is what I have so far
S1:=unapply(u*FresnelS(u)+((1/Pi)*cos((1/2)*Pi*u^2))-(1/Pi),u);
C1:=unapply(u*FresnelC(u)-((1/Pi)*sin((1/2)*Pi*u^2)),u);
with(plottools);
u0:=sqrt(0.25);
e1:=evalf(FresnelC(u0)+FresnelS(u0)*cot((3*Pi)/8));
p1:=display(plot([FresnelC(u),FresnelS(u),u=0..u0]));
p2:=display(plot(x-e1,x=0..1,y=0..1,colour=black));
display(p1,p2);
I find that Maple leaves things like sin^2(x) + cos^2(x) as they are, which is giving me some very long and complicated looking expressions that are often just simple things.
I'm sure there must be a way of sorting this out but I can't find anything.
Also, on a more theorectical note, does anyone know why Maple doesn't do this automatically, or at least have a pre-programmed command to simplify such things?
First 2052 2053 2054 2055 2056 2057 2058 Last Page 2054 of 2458
