I was wondering how maple deals with the powers of a piecewise function. I've a piecewise function of f of thins kind
A_eff:=proc(f)
global Enn,f_a,f_b,f_c,alpha_var, Ell_lor,w_var;
piecewise(f<f_a, (f)^(-7/6), f< f_b and f >=f_a, alpha_var[1]^(-23/2)*(f/alpha_var[1])^(-2/3), f< f_c and f >= f_b, alpha_var[1]^(-7/6)*w_var*Ell_lor(f,alpha_var[2],alpha_var[3]))
and then I must integrate A_eff^2 over a range of frequency which begins before f_a and ends at f_c
Hi everyone. Forgive me for bad english, but it's important to solve one problem. Here is my Maple-code: >restart; define_external(WATCOM); Integral := define_external('periodic_integral','FORTRAN','eps'::float[8], 'Low_1'::float[8],'High_1'::float[8],'Under_I_1'::PROC('x'::float[8],'RETURN'::float[8]), 'WRAPPER','REPLY_1'::float[8],'LIB'="D:/Integral/Debug/Integral.dll"); eps:=10e-5: a:=0.: b:=10.: Under:=proc(x) RETURN(cos(x)*sin(x)) end proc: Reply:=0: Integral(eps,a,b,Under,'Reply'); print(Reply);
how can i solve these two massive nonlinear equations ? and by which way ?
the 1st is:-
I am just wondering, if dealing with 'large' numbers,
which one is better? or which is approiate?
a:=[12,34,56,78,100000];
t:=time():map(i->Power(i,43214342341) mod 5423524532,a);time()-t;
t:=time():
for i to nops(a) do
a:=subsop(i = `mod`(Power(a[i],43214342341),5423524532),a):
a;time()-t;
I'm sorry about the weird subject of this topic.
Somewher in my calculation with maple I expect to find integrals of products of derivatives of a function of (say) f and M other parameters (say a vector theta) , possibly with constant (symbolic) coefficients, times f^alpha  (alpha real. Something like
Int(  N* Diff(psi(f, theta_1, .., theta_M), theta_a))* Diff(psi(f, theta_1, .., theta_M), theta_b))* f^alpha)
(N is an unknown constant)
I want, if possible to tell to maple:
I need help on turning this code into a procedure and what changes do i have to make  so it works like the gauss-seidel algorithm. I have tried many times on my own but can't seem to get my head around it. Any help would be appriciated greatly.
How can I set up the game of Pig in Maple ?   en.wikipedia.org/wiki/Pig_%28dice%29
Does anyone have any experience with such an game in Maple ?
Could anyone please explain the solution in simple terms ?
I'm using Maple to write a report.Maple always produces quite complicated results during some steps while I only want to print the last simplified one.I need to keep those intermediate expressions because some errors will occur when reevalutes worksheet without them.
So can I hide intermediate results?Thanks.
I tried posting this on a similar post but didn't get a response:
I'm trying a similar thing but the intermediate voltages (in my case Va, and Vb) are not being removed.  Here are my equations:
First of all: I'm so sorry, I posted my question to a wrong place ( into the poll).
So I copy here the question and the answer of jakubi and my reply to jakubi.
Question:
I would like to solve the following system
x*(2*sin(x)*y^2+x^3*cos(x)+x*cos(x)*y^2) = y*(2*sin(y)*x^2+y*cos(y)*x^2+y^3*cos(y)),
-x*sin(x) = y*sin(y);
Until I have founded only the solutions
x = k*Pi,  y = +/- k*Pi;    k is any integer.
jakubi's answer:
more solutions
Hello every body,  and many thanks for our help !!!
i have the following transient heat conduction  equation:
dT/dt = a * d^2T/dx^2
now i have:
T(0,t ) = k1(t) : boundary condition
T(L,t) = k2(t) : boundary condtion
T(x,0) = k3(x) : initial condition
T(x,t) : solution at all the time
how to find out
a ?
I need to plot the slope field for this DE: (y'(x))^2 - 4*x*(y'(x)) + 4*y(x) = 0 I'm very new to Maple (tonight was my first time using it) and I'm not a good programmer, so any light you can shed on my problems would be much appreciated. This is what I tried: > with(DEtools); > eq := (diff(y(x), x))^2-4*x*(diff(y(x), x))+4*y(x) = 0; > DEplot(eq, y(x), x = -1 .. 1, y = -1 .. 5); And then I get this error: Error, (in DEtools/DEplot/CheckDE) unable to isolate DEs for required derivatives Thanks
The fubction I've got  for ex:
f(x,y)= sum(exp(x*r[i])*a(r[i]),i=1..3):
where:
r[1],r[2],r[3] are functionsof y
I plot f in 3d in the case when r[i] are values. no problem
but i got confused when r[i] are functions
work with literal subscript. desire to isolate theta [B]. I show in the picture what the steps in Malpas and their outputs. With the last option Maple returns nothing.
First 2100 2101 2102 2103 2104 2105 2106 Last Page 2102 of 2457
