I don't find how to assume that the codomain of a function is the real range (0,infinity)
I want to define  g:= h-> A(h) and tell to maple that A(h) (or g(h) which is the same) is real for each h, even if the function A is still unknown.
Aditionally I can't undestand why I obtain
I am studying the application file "Maple in Finance"   www.maplesoft.com/applications/view.aspx
I have posted some of the stuff below. I have a hard time following along with the reasoning.
Could anyone please explain what is going one here is simple words ?!   There are a lot of new stuff here.
im working with a complicated system of equations and am tryin to find steady states, ive set the equations equal to zero and isolated a particular variable, i now want to sub this variable back into another equation, is there a way i can use the isolated variable without copying the answer and pasting it into 'subs'? (the experssion for the variable is very long and messy!)
How can I get Maple 10 Standard Worksheet to plot with vertical logarithmic axis having the gridlines at 10,10, and so on, in a vector graphic file like eps?
I am trying to maximize a concave function and I have 6 different parameters. I use the maximize command and establish the relevant constraints. The result I obtain is numerical, but I would like to have an analytical solution with one of these parameters being the dependent variable as a function of the others.
Can I use the maximize command or any other command that will give me an analytical solution instead of a numerical one?
How to execute expression when creating a function?
(before creating it, inside it)
I'm having a bit of difficulty with the function "eval" I would like it to perform a full evaluation of an expression, but it does not appear to be doing this. When I try to explicitly pass it a value for the evaluation level it doesn't appear to take the integer input, the only way I can get it to work is to nest calls to eval ...[ie eval(eval(exp))]. Below is the code giving me the problem, the problem occurs on the last line...any suggestions would be appreciated
contourplot(-z*(1/(x^2+z^2)^(3/2)-1),x=-3..3,z=-3..3,grid=[50,50],contours=10);
Doesn't seem like maple is plotting enough point for a nice smooth rounded graph.  Can I smooth them to look more realistic?
I'm straggling with Maple. The main purpose is to plot f(x,y)
I have two for loops for x and y  coordinates and I want to plot f(x,y)
for i from 1 to 5 do
for j from 1 to 5 do
xxiI]:=evalf(xx[0]+II*0.1):
x:=xx[i]:
yy[j]:=evalf(j*0.1):
 y:=yy[j]:
here I should type yhr function that depends on x and y( how can)
od:od:
and then i put the list of  points:=seq,( x,y,f(x,y) ??
and then surfdata(ponts)
is my logic right???
hello friends,
how can i find analytical solution of the
dT/dt = alpha * d^2T/dx^2
T(t,x)
t: time, x: space
with maple for given temperature conditions and initial condition
I was told that to obtain explicit values for an expression of a RootOf expression, I should use the allvalues command. However, when I use it with RootOf(expr, index=1),RootOf(expr, index 2), and so on, I use allvalues and get no explicit solution. I even tried to use allvalues, explicit.
The world has fallen over my head this morning when I discovered that the SAME maple input file, running on the same computer, had given different results. How can that  be possible???
S.
Could I please get help with this maple assignment? No idea where to even begin!!
I have the following solution with Maple 13:  RootOf((-4+4d)_Z+(4-4d)_Z-3d+2).
I understand that to obtain an explicit solution to the complex roots, I have to use evalf.
So when I write evalf(%) or evalf(RootOf((-4+4d)_Z+(4-4d)_Z-3d+2)), Maple returns the same complex root.
Hope you can assist me.
First 2101 2102 2103 2104 2105 2106 2107 Last Page 2103 of 2457
