I'm dealing with a symmetric matrix with numerical values, very high values, e.g. 10^(50), let's call it low_index
Maple computed the inverse with
up_index:= MatrixInverse(low_index);
Hi, When I'm in document mode, whenever I type 'Re' in an equation, it turns into 'script R', which I don't want. How do I turn this auto-formatting off in general? Thanks, Steven
Let say I have a list like     L := [1, 2, 3, 4, 5, 6, 7, 8, 9, -5, -0.2];
Now I want to use the ListTools:-SearchAll() command and return the list index for all the
list element that are negative. I tried ListTools:-SearchAll(x < 0, K);  however that did not work.
The solution could also use a similar and simple command ....
Hi, I need to plot the curve specified by t->(t,t^3) as well as its osculating circle at several points. I know how to compute the radius of the circle but I have no idea how to get the whole thing.
I tried the following:
Alright all im really stuck on this maple question and its been bothering me for some time and i was wondering if you lot can help me out, heres the Q;
Im still getting used to maple, so forgive me for any stupid questions i may have. Thanks, David.
I have a list like     K := [A, B, C, D, E, F, G, H, I];
Now I want to remove list element K[3], K[6] and K[8] what command do I use to do that ?  remove ?
The list is much longer so manual deletion is not an option
Hello.  I am brand new to Maple.  I would like to plot complex functions, in particular as follows:  (1) I want to show all at once all the n-roots (say 4 or 9 roots) of a complex number or a polynomial with n solutions.  (2) I would like to show the results to vectors as I perform operations.  For example, I would like to display a vector, disply another vector, and display theproduct of the two vectors, all at once.
I'm having problems with numerical integration in maple.
I've integrals of this kind
Int(6.989220000*10^12*f^(57/50)/(1.936774504*10^19+2.094942676*10^14*f^2-9.877129764*10^14*f^(107/50)+4.636748856*10^11*f^(207/50)-1.0261950*10^7*f^(307/50)+111.*f^(407/50)), f= 10...1000)
and Maple needs ages to give me a numerical answer (with value(%) ) . Am I doing something odd or it is a "normal" computing time?
I'm running maple in a 8GB RAM, 3Ghz quad core computer
S.V.
hello
Hello everybody,
Hello, I have a 3x3 matrix in maple and am having trouble finding the eigen vector for it.
I attached the maple file. I know this is simple stuff but i am not getting the right results when i check the eigen vectors that i get.
Your help would be much appreciated.
I ran into the following error message
system error, "bad id"
what does it mean?
Hello there, I am all new to statistics. I know there are some functions in Maple that can calculate for example binomial possibilities. I have looking into it without luck, how should it be done? "What is the probability of getting just a six in seven throws?" I know the chance is 1/6 * (6/5)^6 * 7 Can anyone help? - Jonas
I am trying to write a program that contains multiple subroutine calls. I understand the placement of the single for-do loop to call the "lowest value" subroutine.
Here is program.
Calculating a given total using only given specific values
Greetings All
I'm trying to figure out a way to calculate a given total
using only given specific values.
Example:
The total given is 46
The numbers I can use are 56,38,20,12,4, and 1
First 2105 2106 2107 2108 2109 2110 2111 Last Page 2107 of 2457
