 Data:
I was wondering how I can get the equation for Probability Density Function (PDF) for a variable x which follows
a normal distribution with mean 0 and stdev 10 but also has a stop at -10 (ie all x's that are more negative
than -10 becomes -10). I can plot such a function with the below code but I dont know
how to extract the equation for the PDF...humm
I'm trying to plot directly the result of a solve, using the following syntax:
plot(solve(diff(E,N)=0,N),Z=0..20);
( E is dependant of Z and N )
it works for an equation that has only 1 solution. But, when using an equation with two solutions, it only plot one of the solutions. Of course, it is always the solution I don't want.
I've tried solving this problem by forcing N to be above 0 ( the unwanted, but always plotted solution is negative ):
plot(solve({Ep-E=0,N>0},N),Z=0..20);
Dear experts, do you know how I can color and grid the surfaces/sides of the coordinate system when plotting a 3d plot?
I am using the LinearAlgebra package, and I am dealing with very big square matrices (almost a hundred rows and columns).  They have a lot of eigenvalues, with high multiplicity.
I am performing operations on the eigenspaces.  So what I would need is a matrix with as columns a basis with eigenvectors for a very specific eigenvalue.
I can of course use SubMatrix(Eigenvectors[2],....) but that would take ages and Eigenvectors gives the eigenvalues in an ever changing order.
Dear experts, I need to plot a scatterplot: I have a 3*1000 Matrix. Each line gives a x, y and z value of a certain point. Then I want to plot the 1000 point into a 3d scatterplot. Do you have an idea how I could proceed? Thanks a lot!
I just recently started using maple to supplement my math work. When I was just trying some random equations and graphing them, I tried to plot some 3D graphs. When I tried a simple equation, x+y from -2..2, I recieved this image. http://picasaweb.google.com/lh/photo/wnW4UIkdJck46smuTAnb4Q?feat=directlink
I have worked non-stop every day for the past 3 months on a massively difficult generalization of Bell polynomials.  Sufficiently complex examples on Maple might help me to visualize the general case. One published math paper in particular has helped me tremendously.
Recently I came across a page that was working with ifactor and it seems op now handles the operations a bit different now.
ifactor(3^43+1);
       (2) (82064241848634269407)
a:=op(2,%):
ifactor(3^41+1);
       (2)(270547105429567)(33703)
b:=op(2,%):
c:=a*b;
     (82064241848634269407) (271547105429567)
I am using fsolve in maple 13 to find the crossing of a pair of implicitly defined functions in a triangular region.  I have been  using the startpoint option, but sometimes fsolve wanders out of bounds.  I have tried specifying the range as {x=0..1, y = 0..x}, but fsolve complains of an invalid range.  Any suggestions?
Michael
Maple experts,
(I am using Maple10)
I have the following system of equations, but I cannot obtain the solution. (I am able to solve by hand, but I want to verify and to solve the same sorte of equation but with more variables).
solve(    {z1s- p*y1s-(1-p)*y1=0, z2s- p*y2s-(1-p)*y2=0, z3s- p*y3s -(1-p)*y3= 0, y1s+y2s+y3s=1,   y1s-thetas1*(1- z1s-z2s) -(1-thetas1)*z1s=0 } , [y1s]);
What is my mistake?
Thanks in advance for the help.
Gabriel
Pretty simple --- in Maple 13, I try plot(x^2, view = 1.995..2.005,3.99..4.01) and I get the below.  Any idea what's going on?
Just wondering if the Maplesoft website will be redesigned ( I hope not ) and what happens to Mapleprimes ( I believe there are some minor changes coming to the way the forums are set up ).
Will Maplesoft personelle continue to live and work at the site in Waterloo?  or will that building be vacated and a new headquaters set up in Japan?
I use Maple 10 to calculate eigenvalues and eigenvectors:
K:=Matrix(n,n,datatype=float,storage=sparse):
M:=Matrix(n,n,datatype=float,shape=diagonal):
# code to assign the non-zero elements of K and M
(lambda,v):=Eigenvectors(K,M):
For n>1000 the calculation takes several minutes (on 2.4 GHz processor, 2 GB RAM). Maple calculates all eigenvalues, but I only need the ten smallest eigenvalues (and the corresponding eigenvectors). Is there a way to increase the speed of the calculation?
I have a very simple problem. How to create custum component similrar to real expresion block (this block doesn't accept piecewise function) who generates piecewice function f:=x->piecewise(x<=2,0,x>=2 and x<=6,exp(-2x),x>=6,0) on output and nothing on input. When I modificate algebraic equtation template and input piecewise function there is an eror who doesn't accept the syntax for piecewise.
First 2117 2118 2119 2120 2121 2122 2123 Last Page 2119 of 2457
