lim  (x+2cos/4x+sinx)
 x-∞
I'd like to generate several random matrices within the same question. If I put this code under "Algorithm", both matrices are the same (although they both change to a new matrix if you refresh the question):
$A=maple("randomize():LinearAlgebra[RandomMatrix](2,2,generator=rand(-9..9))");
$B=maple("randomize():LinearAlgebra[RandomMatrix](2,2,generator=rand(-9..9))");
$displayA=maple("printf(MathML:-ExportPresentation($A))");
$displayB=maple("printf(MathML:-ExportPresentation($B))");
Is there a faster way to do the following code? This takes 6.5 hours to run for n:=10...
> with(Statistics):
n := 1:
A := Array(1..10000000):
> for k to 10000000 do
t := RandomTools:-Generate(list(float(range=0..1,digits=20,method=uniform), n)):  # chooses 6 random variables from the interval [0,1]
t := sort(t):   # sort them in ascending order
I want to find symbolic roots of
                                                      expr := (A^2 * B^2 * Pi^4) + (2*A*B*C^2*Pi^2) Z^4 + (D*L^4) Z^6  + L^4 Z^8
  i tried in maple
Rootof(expr) ;
allvalues(%);
I am using the Physics package. I have an expression with many terms and need to contract indices with the Simplify command. It returns the following
> KLMN := Simplify(subs(substtot, G4Z2s));
Error, (in Check) unable to handle tensor expressions as 4*I
Has anybody come across this problem?
I'm trying to write a Maple T.A. question bank in LaTeX, since the online question bank editor was too slow to be usable. Running LaTeX even on the "Sample Question Bank" from the documentation gives 25 errors, mostly of the form:
hello, im just trying to do a solve function in  maple 13 for this equation.....1.5=2.4713(1+e^-t+1)*(1-1.23934*e^-0.2145(t+1))^3
I want to solve for T but it keeps telling me that the solutions are lost when i try to solve, please helppppp.  im freaking out here.  and the "e's" in the equation are the exponent function, not another variable.
hello,
1.how can solve the riccati equation for nonlinear time invariant systems, please give example with 4X4 matrices.
2.for the same problem how one can get  the plot for input and states by new method called (theta- D). suboptimal nonlinear control technique.
Hi all, Is there any way I can check what my maple is doing? It's running this code for almost two days now.
I need help in solving following 4th order system of 02 ODEs which are coupled
where, indicates derivative w.r.t  time t , and A,B are constants.
Hey Everyone!
I cant figure out why Maple can give eigenvectors for a matrix A, through Eigenvectors(A); but I cant use LinearSolve() to do this same calculation. (I get <0.,0.> as the answer).
Here is what I am doing (note, Eigenvectors(S) gives correct answer).
with(LinearAlgebra);
S:=<<7476.45,303.62>|<303.62,26.19>>;
I2:=IdentityMatrix(2);
charPoly:=Determinant(x * I2 - S);
EV:=solve(charPoly=0,x);
         produces: EV := 7488.802926, 13.83707411
I'm trying to export some plots to a .gif file which are then imported to a latex-beamer presentation. Since the presentation uses a non-white background, I want maple to produce gif plots with a transparent background. What I tried so far is plotsetup( gif, plotoptions="transparent=true" ) but no dice. As an alternative, setting a RGB valued BGcolor would be ok for now as well ... here I tried setting the PlotBGColor value of my maplerc but this had not the desired effect as well. Thanks in advance, Cheers Nils
how can i plot 20 pairs of (x,y) data,displaying both dots and one of available commands of CurveFitting Package in one diagram? for example if we have L:=[1,2,...,20]: and w:=[23,24,25,...,42]: plot dots:[1,23],[2,24],...,[20,42](but without writing these 20 pairs manual!) together with a fitting line in one diagram.
I am trying to get hold of this DAE system
Hi guys, I need the text output of a maple sheet exported to a text file. Where I need to make this text file and how can I export the output? Thanks MS
First 2136 2137 2138 2139 2140 2141 2142 Last Page 2138 of 2457
