Lets say I have a simple animation such as the code below.
p := [seq([x, 30*x-x^2], x = 0 .. 30)]:
An := proc (x)
pointplot(p[round(x)], axes = box, color = red, symbol = solidcircle, symbolsize = 30)
animate(An, [x], x = 1 .. nops(p), frames = nops(p), trace = nops(p)) ;
Now I want a Button (Embedded Component) to start this animation. How can this be done ?
I want to be able to assign an external jpg image to a variable in Maple and then assign that varaible to the background command
in animate. In other words I want to display an animation on top of an external jpg image.
I know how to view an external image in a maplet
restart; with(ImageTools); A := Read("..........jpg"); View(A)
I also know how to preview an external JPG image
plots[display](ImageTools:-Preview(ImageTools:-Read("...........jpg")), axes = none)
Download 4171_BioBased.zip
View file details
I've got an XML file from someone, which contains some data from a network. First a list of all the nodes and then a list of all edges.
I would like to read this data in Maple to define a Graph, but I don't know how to do that. Could you please help me?
I added the file as a zip (because XML is not allowed). I hope that that is clear.
I'd like to perform following operation as gracefully and computationally inexpensive as possible:
b := [[2, 3], 1, 2, 3, 4, 5]
c := b[2 .. nops(b)]
c[b[1, 1]] := c[b[1, 2]]
c := ListTools:-MakeUnique(c)
c[b[1, 1]] := max(c) + 1;
b[1] always contains a list of two consecutive indices which should be combined into one element of the list and having assigned the largest integer in the list. In the about example:
Hi All,
I cannot transfer variables from Matlab to Maple as shown in the demonstration video for Maple toolbox for Matlab.
Here is what I did:
I run the Matlab using: matlab-sym-maple.bat
and checked that it is using the maple (not the symbolic toolbox version):
toolbox_version maple
open my maple 13, do
version()
got: User Interface, Kernel, Library, Maple Toolbox for MATLAB: 397624
back in Matlab:
>> syms x y
>> g=int('sin(x*y)^2*x',x)
>> setmaple('G',g)
I got a rumor, something about Maple showing the steps that does when solving something. Anyone knows what do I have to do so Maple would show me the steps? It would be great if someone knows how to do it.
Hello, I want to create a list to store the points in C^n with norm 1. The motivation is to use this set of points as a domain to view the image of functions like <x, Ax> (so, x has norm 1).
If it's not possible to store an infinite list, is there anyway to store an albeit large finite list so as to have a good number points in C^n norm 1 spread about evenly?
Hello :)
I'm trying to write an Ackermann function on Maple, here is the source:
> B := (n, a, x) -> if n=0 then a+x elif n=1 then a*x elif n=2 then a^x elif x=1 then a else B(n-1,a,B(n,a,x-1)) end if:
> A := (n, x) -> B(n,2,x):
With small cases it works perfectly, for example:
A(3,3);
    16
but... when i'm trying to calc A(5,5), i get an "Error, (in B) too many levels of recursion". Any ideas?
I have this loop:
> for j from 1 to T do
if pointsd[2][j+1]<pointsd[2][j] then print(j-1) fi;od;
The print gives me (correctly) 2 numbers: 59 and 124
and i need to use these numbers further but i dont know how to call them..
It would be great if i could made an array with these two numbers,like
Hi! I have the following equation to solve: J1*K11-k*K1*J11=0 where: Jx=BesselJ(v,c*sqrt(a-x^2)) K11=BesselK(v+1,c*sqrt(x^2-b)) K1=BesselK(v,c*sqrt(x^2-b)) J11=BesselJ(v+1,c*sqrt(a-x^2)) k=sqrt(a-x^2)/sqrt(x^2-b) Any suggestion to find x???? I tried with "solve", but it says "Warning solutions may have been lost" Also tried with RootFinding --> Analytic, but after processing a while there is no output.. Any suggestion is very welcome!! thanks!
There is a set of non-linear equations solved at each time step for a differential equation..how to implement this in maple.
A typical scenario would be tyre models for vehicle dynamics applications.
help in this regard would be appreciated.
Raja Amer Azim
I have what may or may not be a nasty equation for the structure constants of a particular algebra I would like to classify.  Said equation looks like:
f^{0ij}_{\rho}*f^{\sigma\alpha\rho}_{\beta}=f^{\sigma\alpha0}_{\rho}*f^{\rhoij}_{\beta}+f^{\sigma\alphai}_{\rho}*f^{0\rhok}_{\beta}+f^{\sigma\alphaj}_{\rho}*f^{0i\rho}_{\beta}
hi
I'm dealing with an expression involving terms like:
( a * x ^ l * y ^ m * z ^ n ) + ( b * x ^ p * y ^ q * z ^ r ) + more of the same. The powers can add up to order <=8 [ for example  l + m + n can add up to 8 or less ]
How do I "ignore" terms in my expression where the powers add up to more than 4 ?  [ I know that these orders of magnitude can be ignored ]
I'm trying to use "collect" but can't see how to do this yet.
many thanks
Peter
To anyone out there who may be able to help
I have been researching into closed-form solutions of the 2 x 2 case of the Matrix Differential Equations
dM(s)/ds = [ M(s) , D(s)/2 ]   ,    M(0) = Mo in sl(2,R)  ( 1 )
dD(s)/ds = [ M(s) , K(s) ]      ,     D(0) = Do in sl(2,R)  ( 2 )
dK(s)/ds = [ D(s)/2 , K(s) ]    ,    K(0) =  Ko in sl(2,R)  ( 3 )
hellow!
my maple 11 recently isn't working, i mean with double click not only is not working,
but also after i removed it, setup also is not working.
whats the problem? is it of virus?
First 2145 2146 2147 2148 2149 2150 2151 Last Page 2147 of 2457
