I would like to know what is the minimum number of clues (filled cells) for sudoku 6*6 with 3*2 irregular zones.
I am a graduate student who is currently enrolled for a graduate course in Computer Algebra during the Fall semester. I have spoken to the instructor of the course and he suggests that I should gain proficiency with Maple over the Summer. With that in mind, does anybody know of any resources that may be useful in gaining proficiency with Maple? Thank you for your cooperation.
Hi everyone..
I am new learner in maple program. I have quadratic exercise and It is important for me to sove it perfect. I tried to solve it but I am
not sure about me answers.I need your help please.
This is the question:
 - Given the equations: y=2(x-4)^2-18 and y=2x^2-8x-16, answer the questions below:
1- Find the y-intercept for each of functions
2-Find the zeros of of both functions
3- Find their General and vertex from respectively.
I have this formula:g:=Sum(Sum(Sum(n!/m!/j!/k!*(1+p/20-c-h)^m*(h-p/20)^j*c^k*( j*(w+r*p)+Sum( k!/(k-l)!/l!*(c+h-p/20)^l*(1+p/20-c-h)^(k-l)*( (k-l)*(w+r*p)+l*(w+r*p)*X),l=0..k)),k=n-m-j..n-m-j),j=0..n-m),m=0..n);
which I realized was silly after a few minutes of looking at it, that I should be able to reduce it to a double and triple sum instead of a triple and quadruple sum. However: when I got to reduce the triple to the double, with the formula
Download 10948_Turbulent_Inviscid_Flux_Jacobian.mws
View file details
I am trying to get the right eigenvectors of a matrix dFxdU (see file attached)
The first eigenvector is exactly what I expected (eqn 10.2), but the all the elements of eigenvector in eqn 10.4  is divided by a
View file details
I have derived some eigenvalues and eigenfunctions in this maplesheet. But in the subsection "check to make sure
the right eigenvectors are correct" , Maple is not converting the value of lambdax[i]=u or u-c and hence it returns me an output
of the form :
how can i solve: cos(x+y)sin(x-y)=cosx-siny? PLEASE HELP!!
I have been unable to get any sensible output from the SphericalY function in MAPLE 12. With the command:  testp:=SphericalY(1,0,phi,theta), for example, the output line is just the command line. The only input parameter list that seems to give anything else is (0,0,0,0), which gives testp=0.
Don Ritchie
I am trying to see that two square matrices are same or not in Maple. So I am subtracting one from other and expecting to see a 0 matrix of the same size.
But instead of returning a 0 matrix or some other result, it outputs a string "ee". Does
anyone know what "ee" means?
Jhapk
Download 10948_deleteThis.mws
View file details
I am trying to calculate the eigenvalues of the matrix dFxdU (see file attached) and Maple is giving me the message
"Error, (in content/polynom) general case of floats not handled"
This is weird as dFxdU is just a simplified form of dFdU derived earlier in the maplesheet and when I try to
get the eigenvalues of dFdU, it does it fine.
how can we ask maple to assign output of a "solve" command to it's unknown parameter that system solves it, not just displaying it,
and then sorts the answer in terms of one of the indice parameters.
Hi, I am developing a code with maple, summing up some elements of a 4th-order matrix like this for i to 3 do for j to 3 do for k to 3 do for l to 3 do S[i, j, k, l] := delta[i, j] + delta[k, l] end do end do end do end do; sum(sum('S[1, 1, k, l]*A[k, l]', 'l' = 1 .. 3), 'k' = 1 .. 3); But after execution, I get this error: Error, (in tools/add) bad index into Matrix "A" and "delta" are 3 by 3 matrices. Please help me come up with a solution. Thanx,
How can I Reverse a Fibonacci number and find the numbers between a range 20 and 20000 tia sal2
Greetings All
I've been able to figure out how to get the next fibonacci number in a
sequence given just one number using the floor command see below
x := 987.23
floor((x+sqrt(5*x^2))*(1/2))
What I'm trying to figure out is:
1) floor doesn't take into account decimals and I would like to
2) I would like to be able to find the fibonacci numbers in reverse
between the range of 20 to 20,000
I am trying to model reflectivity data at a Mn-doped GaAs interface and hence I need to create a Kramers-Kronig Transform to determine the depth-dependent complex value of the index of refraction at specific beam energies.  The integral I am trying to solve is the following:
f[1](omega) = P(2/(Pi)*(∫)[0]^(infinity)(u*f[2](u))/(u^(2) - omega^(2))du),
I want to shade the region bounded by the curves x^2 and x^3 from x=0..1. Could you please help me with this. Thanks in advance!!
First 2148 2149 2150 2151 2152 2153 2154 Last Page 2150 of 2457
