How can i use dot notation in time derivation equations?
I want to write a variable with a dot on top, but I can't.
any idea?
Hi! I want to know whether it is possible to convert a Mapleworksheet into an eps format directly so that we get a figure in Latex? Thanking you in anticipation. Best Regards, Rajiv Babajee
...to extract the installer to. <sic>.
I get this error when attempting to upgrade from MAPLE 10 to 12. I went to the Maple site, made the credit card purchase/entered my serial number, downloaded installer, and voila - zip.
Running XP Home 2002, SP3. 8800 GT, 3.4 GHz Pentium, 2G RAM.
No location I select seems to work. I did check out the FAQ before posting, and have an email in to Support.
Eric
The font I get in Maple 12 when I use it on Windows XP is, for lack of a better word, thin. Can I make the font a bit more readeable? Thanks in advance.
I want to solve the following set of ODEs numerically using shooting techniques
they are:
de := diff(x(t), t)+2*(diff(x(t), t))^2-y(t)-.1*z(t) = 0, diff(y(t), `$`(t, 2))-x(t)*(diff(y(t), t)) = 0, .2*(diff(z(t), `$`(t, 2)))-x(t)*(diff(z(t), t)) = 0; bc := y(0) = 1, z(0) = 1, x(0) = 0, x(infinity) = 0, y(infinity) = 0, z(infinity) = 0; gn := desolveSH({bc, de}, t = 0 .. 20, info = 1, numeric)
Any help
I have got a discrete power law distribution from which I would like to sample.
I tried to define a new distribution, but didn't succeed so far.
The probability p(k) = C(gamma)*k^(-gamma),
With ProbabilityTable I've got the problem that my distribution is not limited to a certain range. It starts from a lower limit kmin, but goes to infinity.
Why does the evalb function return 'false' for the following function test?
evalb(sin(2*beta/2)=2*sin(beta/2)*cos(beta/2));
This function should return true, but does not.  Any comments/corrections would be appreciated.  Thank you for your help.
Wayne
I am able to get the matrices entered and they are assigned line numbers in the worksheet.  I am trying to add two matrices and having no luck.  I have tried (1)+(2)  [those are the line numbers assigned by Maple] but I am only getting an answer of 3 for the line numbered (3).
I hope I am making sense.   Perhaps as I think it through, I am not entering the matrices correctly?  I am using the matrix maker on the left side.  If anyone has any help I would really appreciate it.
> T1:=convert(series(f,x=infinity,5),polynom);
             1. ln(x)   1.   0.5000000000   0.3333333333
       T1 := -------- + -- - ------------ + ------------
Hey,
I'm new to here and new to maple and I've got 3 questions:
1. Is it possible to make maple multiply two series with the cauchy product?
2. How to prove identity of two equations? Sometimes I have to differentiate a function and want to prove it with maple ... But when I differentiate with maple with diff(f(x),x) it's displayed in another way. Is it now possible to prove wether the two eqautions (mine and the one from maple) are the same, just in another notation?
A while ago, I tried to understand the dynamics of a tricky 3-D system. Back then I received great help from Robert Israel and Doug Meade. After leaving the problem aside for a while, I'm giving it another shot.
I have a 3-D system of ODEs in the variables (x,c,q) defined on an infinite time range. The initial value of x is given, x(0), but the other values c(0) and q(0) are free. The question is whether it is possible to find values of c(0) and q(0) such that the system will converge towards a critical point.
The first difficulty is in locating critical points, i.e. stationary states. Because the system below contains a singularity at a stationary state, the "critical" points must be understood as a limit that may or may not be approached as time goes to infinity. I have reduced the set of candidate critical points to one element (that for which q=b, where b is a parameter of the system, see below). Denote this critical/stationary point by (xs,cs,qs). The second difficulty is in establishing whether the critical point is reached by a stable (or center) manifold, i.e. whether it is possible to find values of c(0) and q(0) such that, given x(0), it is true that as T goes to infinity x(T)->xs, c(T)->cs, and q(T)=qs. My current assessment, based on the calculations below, is that the critical point may be approached if the initial value of x is below the stationary value but not if it is above it, i.e. x(0)<xs, but not if x(0)>xs. And, if I'm correct, the approach is along a one-dimensional manifold. I'm not 100 percent sure of myself, hence my message on mapleprimes.
The transformed system (u,v,r) appears to exhibit a stable manifold converging to the stationary state u=v=0 and r=b, for r(0) given. Does this indicate that, likewise, the system (x,c,q) has a stable manifold?
many thanks for your help.
My worksheet with comments follows. Unfortunately, today I do not seem to be able to insert figures into the code below.
> restart: with(plots): plotsetup(default): with(plottools): with(DEtools): with(LinearAlgebra):
> Digits:=100: interface(displayprecision=5):
Parameter Assignment:
> A:=1: d:=1/10: s:=1:
> b1:=2/100: b2:=3/100: w2:=1/2: w1:=1-w2: b:=w1*b1+w2*b2: b;
The dynamic system of interest:
> xdot:=diff(x(t),t)=A*(x(t))^(1/2)-d*x(t)-c(t);
> cdot:=diff(c(t),t)=s*(A/2*(x(t))^(-1/2)-d-q(t))
> qdot:=diff(q(t),t)=-(q(t)-b1)*(q(t)-b2)+(q(t)-b)*rhs(cdot)/rhs(xdot);
Computing the "stationary" state (xs,cs,qs):
> xd:=eval(rhs(xdot),x(t)=x, c(t)=c, q(t)=q):
> cd:=eval(rhs(cdot),x(t)=x, c(t)=c, q(t)=q):
> qd:=eval(rhs(qdot),x(t)=x, c(t)=c, q(t)=q):
> qs:=b: xs:=fsolve(eval(cd,q=qs),x): cs:=fsolve(eval(xd,x=xs),c): ss:=evalf([xs,cs,qs]);
 > R:=b;
 The Transformed Dynamic System
> sys := convert([xdot,cdot,qdot],rational):
> PDEtools[dchange](x(t)=A^2/4/(r(t)+d)^(2),c(t)=A^2/2/(r(t)+d)-d*A^2/4/(r(t)+d)^2-u(t),q(t)=r(t)-v(t)/s,sys,[u(t),v(t),r(t)]):
simplify(%) assuming u(t)>0 and v(t)>0 and r(t)>0:
newsys:= expand(solve(%,diff(u(t),t),diff(v(t),t),diff(r(t),t)));
 > eval(newsys, r(t) = R):
sys2D:= select(has,%, diff);
 Eigenvalues of the System
> M:= [eval(rhs(newsys[2]),u(t)=u,v(t)=v,r(t)=r),
eval(rhs(newsys[3]),u(t)=u,v(t)=v,r(t)=r),
eval(rhs(newsys[1]),u(t)=u,v(t)=v,r(t)=r)]:
> us:=1e-20: vs:=1e-20: rs:=R:
J:= eval(VectorCalculus[Jacobian](M,[u,v,r]),u=us, v=vs, r=rs);
 > LinearAlgebra[CharacteristicPolynomial](J,x):
> E,V:= LinearAlgebra[Eigenvectors](J):
Re(E); Re(V):
Gives one negative eigenvalue and two positive ones.
If I set the stationary value of r (and consequently q) to something other than b, I get one very large eigenvalue and one very small one. Analytically: one is zero, the other is infinite. This led me to rule out all candidate stationary states except r=b. When r=b, it is possible that the terms (r-b)/u and v/u in the jacobian, both of the form 0/0, might tend to something finite. It is this possibility that I investigate here.
A first look at the transformed system
> DEplot(sys2D,[u(t),v(t)], t=-1..1, u=-0.1..0.1, v=-0.1..0.1,arrows=medium);
Computing the nullclines (I learned these tricks from Robert Israel)
> up := subs(sys2D, u(t)=u, v(t)=v, diff(u(t),t));
   vp := subs(sys2D, u(t)=u, v(t)=v, diff(v(t),t));
> Uu := solve(up, v);
> Uv := solve(vp, v);
> u1 := fsolve(Uu=abs(Uv[1]),u,avoid=u=0); v1:=eval(Uu,u=u1);
Plotting the Phase Diagram with the NullClines
> p1 := DEplot(sys2D,[u(t),v(t)],t=-1..1,u=-0.1 .. 0.1,v=-0.002..0.002, arrows=medium):
> p2 := plot([Uu,Uv], u=-0.1 .. 0.1, colour=[brown,blue], thickness=3):
> display(p1,p2);
Zooming on the critical point
> p1 := DEplot(sys2D,[u(t),v(t)],t=-1..1, u=-0.015 .. 0.01, v = -0.001 .. 0.001, arrows=medium):
> p2 := plot([Uu,Uv], u=-0.015 .. 0.01, colour=[brown,blue], thickness=3):
> display(p1,p2);
 The critical point can be approached from the north-east quadrant only
 Simulating the 3-D Transformed system
> T := 100:
> INI := u(T)=1e-15, v(T)=1e-15, r(T)=b:
> SYS := udot, vdot, rdot:
> VAR := u(t), v(t), r(t):
> SOL := dsolve(SYS, INI, VAR, type=numeric, range=0..T, abserr=1e-25, output=listprocedure);
Reverting back from the transformed system (u,v,r) to the original system in (x,c,q)
> r0:=rhs(SOL[2](0)); u0:=rhs(SOL[3](0)); v0:=rhs(SOL[4](0));
> X := (u,v,r)-> A^2/4/(r+d)^(2):
   C := (u,v,r)-> A^2/2/(r+d)-d*A^2/4/(r+d)^2-u:
   Q := (u,v,r)-> r-v/s:
Plotting the original system
> x := t-> X(rhs(SOL[3](t)),rhs(SOL[4](t)),rhs(SOL[2](t))):
> c := t-> C(rhs(SOL[3](t)),rhs(SOL[4](t)),rhs(SOL[2](t))):
> q := t-> Q(rhs(SOL[3](t)),rhs(SOL[4](t)),rhs(SOL[2](t))):
> px := plot(x(t), t=0..T): display(px);
> pc := plot(c(t), t=0..T): display(pc);
> pq := plot(q(t), t=0..T): display(pq);
Unfortunately, couldn't plot the implicit relation among the variables. To be fixed.
> pxq := implicitplot(q(t),x(t), q=q(0)..q(T), x=x(0)..x(T)): display(pxq): #THIS IMPLICITPLOT FAILS
pxq := implicitplot3d(t,q(t),x(t), t=0..T, q=q(0)..q(T), x=x(0)..x(T)): display(pxq, axes=boxed): #ALSO FAILS
Error, (in plots/implicitplot) invalid input: the following extra unknowns were found in the input expression: t
Error, (in plots:-display) expecting plot structures but received: pxq
Plotting the transformed system
> pu := odeplot(SOL, [t,u(t)], 0..T): display(pu);
> pv := odeplot(SOL, [t,v(t)], 0..T): display(pv);
> pr := odeplot(SOL, [t,r(t)], 0..T): display(pr);
> puv := odeplot(SOL, [u(t),v(t)], 0..T): display(puv);
> pur := odeplot(SOL, [u(t),r(t)], 0..T): display(pur);
> pvr := odeplot(SOL, [v(t),r(t)], 0..T): display(pvr);
 A 3-D plot of the (u,v,r) stable path
> p3D := odeplot(SOL, [u(t),v(t),r(t)], 0..T, colour=black, thickness=3): display(p3D, axes=boxed);
This post was generated using the MaplePrimes File Manager
View 9249_mapleprimes08.mw on MapleNet or Download 9249_mapleprimes08.mw
View file details
My professor wants us to verify the following
(p \/ q) V r = p V (q \/ r)
using the following Maple equivalent statement
with(Logic):
Equivalent(a &and (a &or b),a);
The issue I have is I really do not know that the statement is asking for and where it would go.
Int(exp(-1/100+1/1000*I*u)/(4*u^2+1)*exp(1/2*I*u),u = 0 .. 1)
The integrand has positive real and imaginary parts over the
range (just use plot it) and numerical evaluation gives it as
0.53434219089626 + 0.98249392969436e-1 * I (using Digits:=14).
A symbolic integration and using evalf gives the same.
Now writes this as
  tstData:=[a=0, b=1, m=1/2, b0 = -1/100, b1 = 1/1000];
  J:=Int(exp(b0+b1*u*I)/(4*u^2+1)*exp(u*m*I),u = a .. b);
  eval(J,tstData...
I'm student from Malaysia.
I prefer to study about prime factorization.
Can I know the two latest prime factorization algorithm which are widely use?
First 2195 2196 2197 2198 2199 2200 2201 Last Page 2197 of 2457
