When I integrate the partial derivative of v(x,y) with respect to y from y = 0 to y = Y using
int(diff(v(x,y),y), y=0..Y)
Maple simple echos the integral in typeset format. I expected to get
v(x,Y) - v(x,0)
What am I missing here? This integral comes from integrating the 2D continuity equation in boundary layer. Any help would be greatly appreciated.
Neill Smith
Here I show the results of the statistical calculation of the quartile, by several methods. All show different results for the same input data.
Hi guys. I'm trying to do something like this: add(add(f[m-k,k], k=0..m), m=1..d); and I want to get Maple to print the coefficients i.e. f[1,0]+f[0,1]+f[2,0]+f[1,1]+f[0,2] etc. I guess what I'm stuck on is how the Array for f should be defined? Any ideas? Thanks, Tom
I need help solving the following integral with Maple
int(erfc((R+3*t)/(6*t^1/2)),t=0..1)
I have a new one :) I need to find the critical points and tell their nature of a 3 variable function. It's a new thing for me and i'm not sure if i did it ok, here's what i have tried:
g := 1-2*x+3*x^2-x*y+x*z-z^2+4*z+y^2+2*y*z;
ex := extrema(g, {}, {x, y, z}, 't'); - stores the extreme value of f in ex
evalf(ex); - displays the extreme value in decimal
t; - contains the critical points of f
evalf(t); - displays the critical points in decimal
Here's what i have to do. i have a system formed of 3 equations, and i have to find the solutions ( there may be only one ), and the make sinus out of it evaluating it with 5 digits.
I am finding problems with plot first:
I am trying to find out all the real solutions of a system of 2 eqns and i just can't figure it out. Here's what i'm trying:
>eqn1:=x+y=9;
eqn2:=x+y-sin(x*y)=7;
solve({eqn1,eqn2})
After i hit enter, i get this warning:
I'm completely lost !:(
Dear all:
   I assume this is an easy question, but I simply couldn't find an answer: How to sample from a multivariate normal distribution give a mean M and covariance matrix Ccov? The statistics package seems to only contain 1-d distributions.
Thanks a lot,
Peter
In the most recent release of Matlab I read in the what's new that it's symbolic toolbox is now based on MuPad instead of Maple (the Advanced Symbolic Toolbox no longer exists)
That makes me think the Matlab is cutting ties with Maple.  Anyone have any thoughts on this?
plot (arccos(cos(x)),x);
At x=0, arccos(cos(x)) should be shown on the graph at (0,0),  As I zoom in I find that Maple draws it at closer to the point (.01,-.01) not at all at (0,0)
How do I create 3D polygone by a list of points using maple.?
I convert following differential equation to the s domain: restart: with(inttrans): > DV:=diff(y(t),t$2)+3*diff(y(t),t)+2*y(t)=diff(x(t),t): > x:=t->10*exp(-3*t): > laplace(DV,t,s); As solution I get: s^2*laplace(y(t),t,s)-D(y)(0)-s*y(0)+3*s*laplace(y(t),t,s)-3*y(0)+2*laplace(y(t),t,s) = -30/(s+3) It's not really a Maple problem but I don't understand why the right hand side of the equation is -30/(s+3) . When I transform the right hand side of the differential equation manual to the laplace domain I would do it as: diff(x(t),t) = s*X(s) = s * 10 /(s+3)
Is there a way to solve following equation in maple? I have already tryied intsolve and dsolve without succes. DV:=diff(y(t),t)+5*int(cos(t-tau)*y(tau),tau=0..t)=10; Thank you, Pieter
I create a continous random variable having an arbitrary pdf and characterize the corresponding distribution:
pdf := piecewise(a <= x and x <= b, 1, 0): f := unapply(pdf, x): R := Statistics:-RandomVariable(Statistics:-Distribution(PDF = f)): `assuming`([map(apply, [Statistics:-MGF, Statistics:-CGF, Statistics:-PDF, Statistics:-CDF, Statistics:-Moment], R, t)], [a < b]) ;
I have a big problem with the plot command :
I have tried to do a densityplot with cylindrical coords, but it doesn't work, it seems that maple can't do it. Do you have any suggestion to do this ?
So I decided to switch to plot3d - contourplot even if i would rather like densityplot. The problem is that i can't show the whole plot : maple only shows me a quarter of what i want :
contourplot( f (r,alpha), r=0..5, alpha = 0..2*Pi, coords=cylindrical );
where is the rest of the function ?
gerald
thanks for your help !
First 2197 2198 2199 2200 2201 2202 2203 Last Page 2199 of 2457
