Here's another really basic question.  Its about using suboptions.  The MAPLE help file gives the following info:
legendstyle=s
Hi.
I am trying to evaluate:
sin(pi*n)/(pi*n) assuming n::integer
Maple returns 0.
It seems to me that it really should not evaluate since it does not know if n=0 (where the correct result is 1) or not.
If it does evaluate, it should evaluate to a dirac function at n=0.
Regards.
Greetings all I know I can get the odd numbers and even numbers using the following command
oddnum := seq(2*j+1, j = 0 .. 13);
1,3,5,7,9,.....
evennum := seq(2*j, j = 0 .. 13);
0,2,4,6,8,......
How do I change the font on the labels of the horizontal axis of a plot ( I am not using the Interasctive Plot Builder)?
<p><span><a href="http://mapleoracles.maplesoft.com:8080/maplenet/primes/worksheet/2031_29.mw">View 2031_29.mw on MapleNet</a> or <a href="http://beta.mapleprimes.com/files/2031_29.mw">Download 2031_29.mw</a><br />
<a href="http://beta.mapleprimes.com/viewfile/2575">View file details</a></span><span><a href="http://mapleoracles.maplesoft.com:8080/maplenet/primes/worksheet/2031_27.mw">View 2031_27.mw on MapleNet</a> or <a href="http://beta.mapleprimes.com/files/2031_27.mw">Download 2031_27.mw</a>
hi all,
i have 10 question out of like a billion, that i am unable to do and would appreciate if someone was able to send me the maple coding they put in into classic worksheet format.
File is below.
 Download 8646_sample1.pdf
View file details
> R := 0.6e-1*(arctan(10*s/1.3+(-10)*.3)/Pi+1/2) / /10 s \ \ |arctan|---- + (-10) 0.3| | | \1.3 / 1| s -> 0.06 |------------------------ + -| \ Pi 2/ > y := -R(s)*cos(6*Pi*s/1.3) > y(0.26); ???what can I do to get the result of y,when s=0.026 Need help from anyone! Thank you! liu
I have the following situation (related to the design of steel structures). Using Maple you compute for a given loading the minimum required section modulus (a cross-sectional property). With that value you enter the section data base (an EXCEL spreadsheet) find all candidate sections whose modulus equals or exceeds the minimum and select the correct one based on some criteria (e.g., weight which is also included in the spreadsheet). Right now this is done manually. Any way to have MAPLE do that for me?
dimitrios karamanlidis
View 285_Stat Mech Integral.mw on MapleNet or Download 285_Stat Mech Integral.mw
View file details
Can someone help me evaluate the last integral?
thanks,
v/r,
Problem: find the length of the curve y=(x/2)^{3/2}. Using VectorCalculus Maple11 says
For the polar equation, r = 2 sin(theta), will some kind soul please give me the syntax for a parametrized plot?
     polarplot (   [    ,      ,     ] )
Alla
Greetings All
When I run these commands
with(combinat, fibonacci);
modp(fibonacci(3)-1, 9)+1
I get the answer of 2
but when I run with these commands
the single digit modp doesn't work  Why is this?
How can I check a large matrix and determine whether there are rows or columns that are multiples of one another?
When multiples exist, how can I determine which rows are multiples?
Thanks for your help.
I have the following expression which is a sum of three terms.  The first term has a -(H1+H2)^2 and the second one has a (H1+H2)^2 term and I would like to simplify this by dividing the equation by (H1+H2)^2 but I can't figure out how to force maple to do that.  Any help would be greatly appreciated.
(-2*H1*H2-H2^2-H1^2)*`&varphi;t`+(H1^2+2*H1*H2+H2^2)*`ηt`*Ut+4*H2*H1*Uc*`ηc` = 0
Also, f someone can direct me to where I can learn to present equations better in this file that would be icing on the cake.
Following set of equations will solve and give exact solutions for x1, x2, x5.
solve({
x1^2-x2^2-x3+x4=0,
(x2+1)^2-x5 = 0,
125+x1 - x2 = 0,
1+x3 - x4 = 0,
x8*x6+x7 - x8^2= 0,
x9*x6+x7 - x9^2-x3 = 0,
y2*x6+x7 - x5-y2^2 = 0,
y1*x6+x7+x5 - x5-y1^2-x4 = 0
[x1, x2, x3, x4, x5, x6, x7, x8, x9, y1, y2]);
First 2264 2265 2266 2267 2268 2269 2270 Last Page 2266 of 2457
