hello, first post here.
i'm attempting to solve the 1 d heat equation using a finite difference scheme, with continous boundaries eg.
Where I can get right and complete instructions for read .txt files from Maple 7 ?
I follow the instructions like:
L := ImportMatrix( "data.txt", delimiter=" " );
for read a deta.txt file, or others like fopen, etc, and do not get the data.
How do I plot in the simplex with Maple [11]?
I am working with variables x1,x2,x3, each non-negative, and summing to one.  Thus, the triangular 2-simplex is an easier environment to work in.
Thank you in advance,
Colin Rowat, Department of Economics, University of Birmingham
Can I get maple to give me a hint as to what test for convergence to use with infinite series?
HI to all!
I've a math question about the Hessian Matrix. I know that it's used for clasify critical points of a 3-D function, but what happens if the Hessian is undefined (Hessian = 0) in a point?... How i can analyze the critical point?...
A particular sample is:  f(x,y) = (y-x)^2*(y+x).
The gradient vector of this function is: grad(f)= [ 3x^2 - 2xy - y^2 , -x^2 - 2xy + 3y^2 ]. To find critical points we have to do grad(f)=0 (vector). And in this case it's easy to verify that the critical points lie in the Y=X line.
hi
i have to calculate a extreme value for a box that is open on one side that should have a volume of 32.
V = x * y*z
For the surface ob the box-sides i used this function:
O = 2xz + xy + 2yz
my idea was to solve this in maple using lagrange because i ve a side condition
with(RealDomain):
L:=(x,y,lambda)->x*y + 2*x*z * 2*y*z +lambda*(x*y*z-32);
solve({diff(L(x,y,lambda),x)=0, diff(L(x,y,lambda),y)=0, diff(L(x,y,lambda),lambda)=0});
evalf(%);
it gives me for my values x = 32/x*y; y = y; z =z
Hello! I would like to know if there is a way that Maple finds the equation on its own. I have a table of x values and y values and after plotting them I would like to find a trend line by least square.
I would use the chain rule twice:
f(s,t) = e^u
u = sin(s*t);
u = sin(v);
v = s*t
v' = s;
u' = cos(s*t*)*s
f' = e^cos(s*t)*s
Maple adds *ln(exp), what's wrong with my way?
complete maple output: exp^sin(s*t)*cos(s*t)*t*ln(exp)
I want to create a list of the first 100 prime numbers.  I remember vaguely the use of seq and type but I can find it in the differents forums.  Could someone state it again for me.  thanks!
I have a matrix
A:=<<1,-3,2>|<-2,6,-4>|<2,-1,5>|<3,1,8>|<-1,-7,-4>>;
how do I find a basis of im(A)?
Chen
Hello everybody,
I am using the GF package from Maple to solve an equation with elements of a given galois field. It looks like that:
field := GF(7, 1):
eq1 := x = y^2:
eq2 := x^2 = y^4:
equationToUse := eq1:
isSolving := false:
use field in
    isSolving := is(eval(equationToUse, [x=field:-random(), y=field:-random()]));
end use:
if isSolving then
    print(`Equation solved`);
end if:
The Maple Manual says to use a parametric plot to graph a circle.  I've been fiddling with the syntax  but can't seem to get it right.  I want to plot
x^2 - 2x + y^2 = 0,           which can be written as
(x-1)^2 + y^2 = 1
Can someone please give me the PLOT command to plot this circle?
Allan
I wrote a procedure shrinkTime:=proc(n::posint); The procedure only works with a positive integers and I need to plot this function. However, whenever I goto plot it; plot(shrinkTime(n)); I get this error: " Error, invalid input: shrinkTime expects its 1st argument, n, to be of type posint, but received posint" How can I specifically instruct maple to only plot at points where x is a positive integer?
My question is concerning finding Px(k) for a problem. There is a basketball player who takes two foul shots. The P of making the first is 2/3. Then assuming she missed the first, the P of making the second is 3/4, but if she makes the first, P of making the second shot is 1/2. X is the number of shots made. I have to find Px(k) for k=0,1,2, and then E(X). My first concern and real problem is that I'm not sure how to find Px(k) for one shot made since the probabilities for making one shot have two possible answers.
First 2268 2269 2270 2271 2272 2273 2274 Last Page 2270 of 2457
