I have a matrix (made by Matrix palette)
> LapMatrix := Matrix(3, 3, {(1, 1) = 1/sin(Theta)^2, (1, 2) = -cos(Theta), (1, 3) = 0, (2, 1) = -cos(Theta), (2, 2) = 1/sin(Theta)^2, (2, 3) = 0, (3, 1) = 0, (3, 2) = 0, (3, 3) = 1});
Maple calculated the 3 eigenvalues.
When I typed
(v,e):=Eigenvectors(LapMatrix)
Maple said
Error, (in LinearAlgebra:-LA_Main:-Eigenvectors) expecting either Matrices of rationals, rational functions, radical functions, algebraic numbers, or algebraic functions, or Matrices of complex(numeric) values
1) I want to transform a polynomial in variables x_1, ... , x_n into function K^n -> K
Example:
given y[10] := x[10]+x[1]^2+x[2]*x[5]+x[3]*x[8]
i want to view y[10] as a function and evaluate it at point (x_1, ..., x_n)
2) Given m such polynomials y[i] I want to define a funktion K^n -> K^m by viewing every y[i] as a coordinate function
Example:
f:=(y[1],...,y[m]) every y[i] beeing a polynomial in x_1, ..., x_n
Basically , I was doing some calculation algebracly.
I got some out like " arc(    AAAAAA  , BBBBBB) , arc( CCCCC,  DDDDDDD) "
I wonder what the comma between  A ns B mean?
meaning arc (AAAAA) and acr (BBBB)??
dose that mean I have 4 answer?
I was solving some sin,cos function
I can find the numerical values of the answer
Using fsolve I evaluate a system of 32 vars 32 eqs:
solutions:=fsolve(equations,{C1,C2,C3..etc...C30,C31,P},P=0..10);
For most vars there is a unique answer, but P is the solution to a trancendental equation. When I specify a range to find s0lutions in, fsolve returns the largest solution default. Unfortunately, I need the smallest nontrivial solution.
Does anyone know a way of retrieving the first solution in the range?
Erik
Does anyone know how to plot a solid sphere and not just one with a fixed radius? Lets say I wanna plot { (r,theta,phi) | 1 ≤ r ≤ 3 , 0 ≤ theta ≤ Pi , 0 ≤ phi ≤ Pi } ... would that be posible?
Please help!
Hi guys,
I'm having trouble trying to get this feature to work.  I've defined a function, however, when I try to get execute a VolumeofRevolution command, all I get is the repeated command written in blue. ..
I've attached the worksheet.Download 6440_volume.mws
View file details
Thanks for any help!
Hi there,
I got two ordered lists of data (X and Y coordinates of body).
How I can plot a trajectory Y vs. X via pointplot?
Thank you in advance.
> y1 := x-> piecewise(0<=x<=c, m1*x+b1, c<x<=1, m2*x+b2);
Error, unexpected relational operator
I don't know why it gives me this error, I underline where the cursor goes. Can anyone tell me what is my error?
I want to know how much memory Maple "sees" as available on command line execution. How can I get the information that appears on the classic worksheet as "Bytes" and "Available" with a Maple command?
Short question: why does > type(Not(x::posint),property); show 'true' in Maple 10 (and below), and 'false' in Maple 11? What has changed? -- Regards, Franky
first I use Maple 9.5:
solve(x^3-8*x^2+12*x-4,x);
gives back 3 complex roots - in this moment I again know, it isn't bug.
Then I use Maple 11 with the same result.
Next test in Maple 11:
with(RealDomain): solve(x^3-8*x^2+12*x-4,x);
gives back only 2 real roots! Way?
Thanks.  Jan
hey guys.. i have put input this in maple.. but it doesn't seem to solve it..
ode:= D(D(y(t)))- u*(1-(y(t)^2))*D(y(t)) + y(t)=0;
ics:=y(0)=0.2, D(y)(0)=0;
                           y(0) = 0.2, D(y)(0) = 0
dsolve({ode,ics},numeric);
Error, (in unknown) invalid input: op expects 1 or 2 arguments, but received 0
The F-distribution (also known as Snedecor's F distribution or the Fisher-Snedecor distribution) depends on two separate degrees of freedom, m and n. It is defined by (Eq. 2 in MathWorld):
In Maple notation:
> fdist:=(x,m,n)->GAMMA((m+n)/2)*(m/n)^(m/2)/GAMMA(m/2)/GAMMA(n/2)*x^(m/2-1)/(1+m*x/n)^((m+n)/2);
In order to calculate the percentage points of the F-distribution we need to find the area under the curve. For example, for known m, n the integral
defines the percentage of points under curve for x, since
This can be done easily in Maple, if we wish to find, say, 95 % confidence level for m=4, n=3, we (could) do the following:
> Fstat:=proc(perc,m,n) fsolve(int(fdist(u,m,n),u=0..x)-perc,x=0..infinity); end proc:
> Fstat(0.95,4,3);
          9.117182253
Is there a Maple built-in function I can use to calculate these values in a more elegant form instead of defining fdist and Fstat?
Is there something similar for the evaluation of the percentage points of the t-Distribution?
Graph the surfaces  y= x + z and y = 1 - z on the same axes using the domain |x| < or = 1.2 , |z| < or = 1.2 , and observe the curve of intersection of both surfaces. Show that the projection of this curve onto the xz-plane is an ellipse.
So that's that problem. I am so lost on what to do. I know it has to do something with implicitplot3d.
First 2288 2289 2290 2291 2292 2293 2294 Last Page 2290 of 2457
