How to I get MapleTA's eqution editor to work on a Mac? I can't get the applet to start in Firefox, but I can with Sea Monkey. Even so, I can't get the pallets to appear. Anybody know how to do this?
In the attached file there seems to be a little calculation bug.
Simply let the file run through. In the fourth line from the bottom CSBt equals a number greater than zero. I copied the same expression in the file's very last line. There the result of CSBt is zero.
The identical expression gives two different results. The "correct" result is zero.
It seems to me that the file is somehow damaged. Has this happened to anyone before and what can you do about it?
Many thanks for your help!!
Florian
I'm trying to use Physics package of Maple 11 to perform some basic QFT calculations. I need to calculate traces like Trace((p[mu]*Dgamma[mu]+m)*(k[nu]*Dgamma[nu]+m)) but it seems that maple can't compute this. Am I doing something wrong or is this a limitation of Maple ?
I would like to print on the screen
[; -T\leq x\leq T ;]
where [;T;] is a variable which obtains its value from calculation, and [;x;] is a string only.
I tried
T:=2;
Error, unexpected relational operator
Is it possible to solve this problem?
Sandor
I have a procedure
smth:=proc(T::positive)
bbbb;
When I type
smth(Pi);       or     smth(pi);
I obtain the error message
Error, invalid input: smth expects its 1st argument, T, to be of type positive, but received pi
How can i give the Pi/pi to T  if I want to keep  the T::positive  ?
(evalf is not acceptable.)
Sandor
I'm creating matrix questions and wish to dynamically set the size of the matrix. So I'm trying something like this:
\qutext{Find the transpose of the matrix $$A=\left[\begin{array}{ccc} 1 & 2 & 3\\ 0 & 1 & -2\end{array}\right]$$}
\code{$a=3;}
\size{$a}{2}
<snip>
But this doesn't seem to work.
 Colin
Whenever I import a question bank I get the following error:
Error Message:
Errors loading the question bank, first : Reason: Error at line 0. Stream closed
However, the question bank seems to have imported correctly. Any thoughts?
Colin
How do I add a new line in the middle of an existing execution group without using split/join commands in Maple 11.
What is wrong in here, please help:
dustplot0:=(points)->odeplot(duffing, [x(t),y(t)], 0..(2*Pi*points), numpoints=points);
plot1 := dustplot0(100):
plot1;
plot2:=PLOT(POINTS(op(op(1,op(plot1))),COLOUR(RGB, 0, 0.2,0.5),SYMBOL(POINT))):
plot2;
Error, invalid input: op expects 1 or 2 arguments, but received 3
I do not understand the reason for this error.
My problem is that Maple does not give answer at all for the initial value problem, so I need a help. If does exist a solution how can I obtain it?
Thanks in advance,  Sandor
infolevel[dsolve]:=5;
                                      5
What is the (symbolic) equivalent in Maple for
   [ V  D ] = eig( A, B, 'chol' )
for given matrices A, B ?
I was trying to install Maple11 on my computer (Windows Vista Home Premium, 2GB on RAM) but I cannot do it, when I executed maple11windowsinstaler.exe appear this message:  "Installer user inferface mode not suported": Unable to load and to prepare the installer in GUI mode... Why appear?? I need to intall maple as quick as possible. I tried to run the installer with  "run as administrator", but i cannot install.
Please, help me!!!! =(
Hi, I am just courious and I want to delay the output like: If I ask maple to do an integration, first it displays the question: Int(x,x); then after some time it displays the answer int(x,x); is there a way to do that?
I'm a teacher and I'm teaching my students about graphing trig functions. Well, they do not know about radians yet and I need to keep everything in degrees and would like to plot my graphs in degrees and show that the graph is in degrees on the axis, but I can't find a way to do this. Can anyone help me with this!
thanks,
Clinton
I am trying to convert tan(z) to sum form using the convert(...,Sum) command and using some information from FunctionAdvisor.
The second operand of FunctionAdvisor( sum_form, tan) gives me the domain of validity.
I would like to use this info during the conversion as assumption, but it doesn't work for me.
(Of course, the first operand is the required sum form, I am just playing with maple).
Here is my problem:
First 2301 2302 2303 2304 2305 2306 2307 Last Page 2303 of 2457
