Unfortunately piecewise() is a builtin so I can't see the library code.
I'm trying to construct a sequence of arguments to piecewise() programmatically, and to assign the result to a function but I just can't seem to set it up correctly.
I have a 10x18 matrix, each row of which will be used to define a piecewise linear function, so the columns in a row define the endpoint values of each line segment.
Essentially what I'm trying to do is the following (giving some Maple pseudo-code which doesn't work, but hopefully will get the idea across):
On page 99 of Dr. Euler's Fabulous Formula, Nahin says that:
int(int(`f`(s), s = 0 .. t), t = 0 .. x) = int(`f`(s)*(x-s), s = 0 .. x)
is true and I believe it, but I can't get Maple to confirm it.  How can I get Maple to agree with Nahin?  Are there assumptions that will make it happen?
I want to evalute in degrees.
restart:with(Units[Natural]):
sin(45 * deg);  # it works
>alpha[1]:=4.25 * deg;
> theta[1]:=11.31 *deg;
> theta[2]:=78.69 *deg;
> alpha[2]:=-9.25 *deg;
> a:=1400.00;  #  a and b should be real values
> b:=509.90;
>-b*sin(alpha[2]+alpha[1]-beta[1]-theta[2])+b*sin(beta[1]-theta[2]):
Error, (in Units:-Standard:-+) the units `arcdeg` and `1` have incompatible dimensions
not working...
How to input the character underline('_') in Maple,for example,typing variable name "cs_e"?
The code generates lines parallel to the opposite side of a given triangle. How can I control the animation to stop at x=10 or not to go outside the triangle.
Fourier Series Expansions and it’s Coefficients question revised
Greetings
I've worked through a Fourier Series Expansion and it’s Coefficients and
have a better gasp at a how to explain my question.  If I'm giving a
repeating wave at (T) period of 10 seconds with amplitudes
At 14, 18.7,9,4.1,6.7,6,6.3,8.4,4,2.9 how can I find the Fourier Series
Expansions in Trigonometric form using Maple 11.  I’ve included an
Hi, I really have no idea how to do that.. http://img228.imageshack.us/img228/2839/euleric0.jpg can someone give me some hint or example,please ? thanks so much. Chen
I've just started using MapleTA and I'm exploring the Latex capabilities. The test question that I have constructed looks like:
\begin{question}{blanks}
\qutext{Test  \blank[formula]{\var{ans}} Test.}
\code{
$a2=Matrix([[1,2],[3,4]]);
$c=LinearAlgebra[MatrixInverse]($a2);
$a=rand(5,9,2);
$inc=int(rint(3)+2);
$b=$a-$inc;
$ans=int(10^$inc);
\end{question}
\end{topic}
However, I get the following error during latex conversion:
What practical limits are there to the size of a system of simultaneous nonlinear equations that fsolve() can solve?
http://img20.imageshack.us/img20/3518/56351860db7.jpg in exercise the only input is f how can i simplify a[n] and b[n]? and can someone just write this procedure for me, please? thanks
I'm a new user with Maple. Please give me a clue about this, i tried search over HELP but i cannot find anything. My first question is: how can i get just a real solutions when i solve for an equation ( this one got 2 complex solutions ). The 2nd is about the linear system, I got ROOTOF solution, i think it came from the complex solution. Please download my maple file to take a look. Thank you.
Hi, i have some procedure like from 1 to 300 do ........... od; and it has 300 outputs can i make it dissapear? thanks
Hallo everybody,
I am using maple 8 to numerically evaluate the roots of a 1d polynomial in a given interval. Does anyone know how to force fsolve to compute all the roots  in a given interval  and  not just a single one. Alternatively, does anyone know if it is possible to specify an interval to compute the roots with the solve command? Thank you in advance.
A Maple user in Ireland asks:
Basically when we call BooleanSimplify using the openMaple API, with very long expressions, after a significant period of time maple calls the textCallBack with the tag MAPLE_TEXT_QUIT and nothing in the string passed to the same function. Could you shed some light on what maple_text_quit is and why maple might be returning this. i.e. could it be that it has hit some internal limit, or that It is hitting some external limit. i.e. malloc
How do I enter a nested for, if loops in Maple in multiple lines. I can enter the loops in multiple lines with no error message, while in the classical worksheet. But entering the same loop sequence in standard worksheet gives me "error, invalid loop" message after entering the first
for i from 1 to 100 do
statement . The error does not ocurr if I enter the for, if statements in one single line
First 2302 2303 2304 2305 2306 2307 2308 Last Page 2304 of 2457
