I am solving a constrained maximization problem using the Lagrangian and getting back an empty set of solutions, i.e.: solns_LSW:= How do I go about diagnosing why Maple is having difficulty finding solutions? (Once I know that, I would of course also like to know how, if possible, to change the set-up so that Maple might actually find the solution(s)!) I can see that the Lagrangian becomes non-concave for cases where lambda2>p (p is one of the variables I am solving for: there are two, s and p -- see attached worksheet). This would clearly be the case for, say, p=0 optimal (which I have reason to believe it is, based on some numerical simulations I ran).
Dear all, In the attached file I try to solve expression Y for p. As Y includes dCS(p)/dp, the solve command produces an error message. I do understand that Y can't be solved for p since expression dCS(p)/dp is not fully defined. However, the result I am aiming for is simply: p = -(1/2)*(dCS(p)/dp) (with p simply being a funtion of dCS(p)/dp) Which command leads to this result? I haven't found it in the help section. Many thanks for your help! Florian View 5919_Question_solve
Hello everyone, I was wondering if the grid resolution for "patchedcontour" wireframe 3d plots is adjustable? The only setting I know of is 'numpoints', and I can set that to a high number to get a better looking 3d plot, but this results in a dense amount of wiring for the plot. So I was curious if there is a way of getting the 'better' look for a graph while keeping the number of wires low enough so that contours are easily visible (and usable). Any takers? Thanks in advance. :o)
I have been told my code is not 'perfect', I'm not too hot on maple and it has taken me a week to get to this stage. Any help or suggestions would be very welcome! h:=0.1: k:=0.001: r:=k/h^2: xl:=0: xr:=1: # left and right ends of interval in x nxpoints:=round((xr-xl)/h): ntsteps:=5: # total number of time steps iprint:=1: # print output every iprint time steps printf(cat(" x,t ","%7.3f"$(nxpoints+1),"\n"),seq(i*h,i=0..nxpoints)): format:=cat("%7.3f"$(nxpoints+2),"\n"): # format for printing output Boundary conditions for j to ntsteps+1 do u[0,j]:=0: u[nxpoints,j]:=0
hello all ... peculiar problem here ... please help the expression is true that 1/n(n+1) = 1/n-1/(n+1) since 1 = n + 1 - n gives 1/n = (n+1)/n - 1 Is there a way to demonstrate this identity in Maple ? ? I cant find any trick with "expand" or such that works. This impact is also seen when evaluating ... the following ... sum(1/n-1/(n+1), n = 1 .. infinity) = 1; = print(`output redirected...`); i get the proper answer of 1 but no answer with :::
I know maple has two functions max and min to compute the maximum and minimum of some arguments. But I have a list,such as l:=[1,2,3]; when I use the maple function min,I need to write: min(l[1],l[2],l[3]); How can I simplify the expression? If l is list with too many items,how to use min to calculate the minimum?
I need to make a list of 12 random integers from 0 to 1. Take the sum of those values and subtract 6. I have that part....now the part I don't have is how do I run that 10^6 times and keep track of my values? with(RandomTools): with(stats): with(ListTools); > L := seq(Generate(integer(range = 0 .. 1)), i = 1 .. 12); 1, 1, 1, 1, 1, 1, 1, 0, 0, 1, 1, 0 > > G := add(i^2, i = L); 9 > Z = G-6; Z = 3 That is my program so far. Any help is appreciated.
Does anyone know if there is a way to obtain the coordinates of an ordered pair on a graph? I see that Maple states the ordered pair your cursor is currently situated at, but what I want is to 'grab' these coordinates and use them in other calculations. Essentially what I want is a Maple command similar to ginput on Matlab. Thanks.
> plot([(12-2x)^(0.5)], x=-10..10); Error, missing operator or `;` this line looks right to me but i keep getting that error in maple. i have also tried: > plot((12-2x)^(0.5), x=-10..10); does anyone have any ideas how i can fix this? any help would be great thanks
On Maple 11 Modern Version: If I have two parametric curves, say y = 4t + t^4 and x = 5t - 7t^2 how can I plot an equation such as (y'') * (x') + (3x'') with ' being differential and '' being second differential. I have tried it in numerous ways but get the following error message - "Warning, unable to evaluate the functions to numeric values in the region; see the plotting command's help page to ensure the calling sequence is correct". I have been trying to plot for t=-1..1. Thanks
Several weeks ago I submitted a request titled "Plot This! - Elliptic Integrals", which Dr. Robert Israel responded to with the following code which successfully plots the relationship of two variables, beta and k, over the range of interest. > with(plots); Digits := 15; > implicitplot(2*EllipticE(sin(beta), k)-EllipticF(sin(beta), k) = tan(beta)*sqrt(1-k^2*sin(beta)^2), k = 0 .. .99, beta = 3.5 .. 5.5, view = [0 .. 1, 3.5 .. 5.5]); However, the plot indicates that for the range of k=0..0.99, beta is approximately equal to 4.77 radians (273 degrees), whereas the paper that I am researching indicates a value of beta equal to 257 degrees 28 minutes. I have attached worksheet that includes the commands provided by Dr. Israel for information.
I'm looking for some examples of how Maple is being used by others to solve good, old-fashioned freshman physics homework problems. I have been getting the job done but my command of the program is so limited that I wind up using it like just an old graphing calculator. I'd really like to see how other, more advanced users are using it. Any suggestions?
Hello everybody, I hope some of you have experience with multivariate Ore polynomials in Maple and will be able to answer the title question. So far I've needed only univariate Ore polynomials, used the OreTools package for them and have been very satisfied with it. However, now I've come across a problem that needs to employ multivariate ones - therefore I am forced to try the Ore_algebra package, which should make computations with multivariate Ore polynomials possible (as far as I know, OreTools cannot handle multivariate Ore polynomials - or am I wrong? I wish I was) And here comes my trouble! Not only that I am not able to solve my multivariate problem with Ore_algebra, I don't even know how to do simple calculations (which can be so easily performed with OreTools) using Ore_algebra.
Hi everyone, I m a beginner with maple, so please, be patient with me! I m trying to use some complex algebra in maple. In particular, I want to define a function f(r,z) and I want to impose it to be REAL. So I thought, let's first impose the variables to be real(I'm using Maple 10, so I write everything as if I was in a document, ok?): assume(r,real) assume(z,real) after I have done this, I define the function, using the appropriate f(x,y) button in the toolbar: F:=f(r,z) and I impose it to be real: assume(F, real) but for some reason this does not work. Anyone knows why? The reason why I need to impose the function to be real is that F will be later multiplied by exp(Iz) to form a complex number.
Here is a technique which I need to do over and over and over in Maple. I am currently writing a research paper for the International Journal of Mathematics and Mathematical Sciences. I need to get this example out as soon as possible. Suppose I want to create a matrix where the (i,j) entry is the polynomial x^i + (x+1)^j whatever the entry is.. it doesn't matter. Point is that the entry depends upon the row i and column j How can I create and fill such a matrix? My matrices a slightly more complicated, involving entries such as diff(x^i + (x+1)^j,x) where it is actually easier
First 2326 2327 2328 2329 2330 2331 2332 Last Page 2328 of 2457
