Hi, I've been using maple10 worksheets under os x, setting the default zoom to 75%. This is fine. However, I've recently migrated to a linux system. Now, if I display a matrix under maple10 (or maple11) with 75% zoom, all of the spaces around the entries of the matrix are lost! This makes for unreadable 2d output. This is also true under 50% zoom (which is already unreadable) and if I change the default zoom in my .maple10rc file to _anything_ less than 100%, the same loss of spacing results. Does anyone else find this to be a problem. Sure, I can work with 100% zoom, but if there's a s
The first function I am trying to plot with maple is r(t)=3cos(2t)i-2sin(2t)j, and the second is r(t)=(t)^(1/2)i+(t^2-2t)j. If anyone can help me with the command lines that I must type to properly plot these function in maple I would be very grateful. :)
I am just starting to work with Maple 11, and having problems plotting two (single variable) functions in the same set of equations. I had thought that the way to do this was to plot a function, create a second expresssion in Math mode, and then simply drag the expression into the plot area. What happens is that the expression disappears, and nothing happens to the plot. when I use plot({expression1,expression2}) , the plots appear just fine. Are there any tips for me? I'm trying to write an "introduction to Maple" for beginning Calc I students, so I want to be able to give them the simplest instructions possible.
Hello, I am using dsolve to solve a set of coupled differential equations. After they are solved I do some further manipulations on them. Every time I restart maple and execute the document, maple solves the equations but puts them in a different order and has the constants mixed up. Thus I have to keep hitting the (!!!) button until I happen to get the solution I had when I did the further manipulations. Is there a way to proscribe maple's output to a certain order? Here is an example: One time the solution will look like: {F(x) = f(x)*_C1 + g(x)*_C2, G(x) = m(x)*_C3 + v(x)*_C4}
I'm using the following bit of code: step1:=1:for w[x] from start by jump to finish do: fsolve(test2,k,complex): answer:=%: k1:=Re(answer[1]): k2:=Im(answer[1]): k3:=Re(answer[2]): k4:=Im(answer[2]): data[step1,1]:=w[x]: data[step1,2]:=k1: data[step1,3]:=k2: data[step1,4]:=k3: data[step1,5]:=k4: step1:=step1+1: end do: Obtain All Data Points from Array points1:=seq([data[d,2],data[d,1]],d=1..nopoints): points2:=seq([data[d,3],data[d,1]],d=1..nopoints): points3:=seq([data[d,4],data[d,1]],d=1..nopoints): points4:=seq([data[d,5],data[d,1]],d=1..nopoints): Obtain Relevant Data Points
It's me again, got another problem i have another hyperbolic paraboloid equation 3*x^2-5*y^2=z and it's conic sections at xy(z=0), xz(y=0), and yz(x=0) plane 3x^2-5y^2=0 3x^2-z=0 5y^2+z=0 but i have problems converting those conic equations into parametric equation, so it can be plotted using the spacecurve command Can someone help??
I am stock on this my prof gave me an equation to draw on maple 16x^2=y^2+4z^2 and this is the code i keyed in restart: with(plots): > p1:=implicitplot3d(16*x^2=y^2+4*z^2,x=-100..100,y=-100..100,z=-100..100,numpoints=2000,style=wireframe): > display(p1); and the graph suppose to be a cone rotating around the x-axis but i don't know wut i did wrong, i just couldn't get the graph look like a cone, instead, it looks like a hyperboloid of two sheets, and the sheets are very close to each other Can someone help?? Thx
I am trying to compile the OpenMaple example omexample.c using Bloodshed Dev-C++, but I am getting linker errors. I have tried adding maplec.lib to the linker parameters under project options, and I have also tried copying the library to my working directory and passing it as a compiler command option. Neither has worked. Thanks in advance for your help. Regards, layne
When I use: >with(process) >launch("notepad") then notepad is open in the background, but, how do I to run another aplication? with matlab is easy, but e.g. How do I with Origin? or How many formats (i.e. .pdf,.txt, etc.) accept maple? Thanks a lot
The equation of a sphere is x^2+y^2+z^2=1, and its traces are x^2+y^2=1-k^2 z=k x^2+z^2=1-k^2 y=k y^2+z^2=1-k^2 x=k can somone help me how to graph the traces using spacecurve command so the traces matches the sphere? thx!!
Greetings, For a school project i am trying to calculate a trajectory of a spacecraft to mars. Using newtons equations and the numerical D.E. solver i calculated the orbits of earth and mars around the sun(which i am also using as my coordinate origin.) Then i use these results in a differential equation to find the position of a rocket launched from earth. I am shooting it in an arbitrary direction just to get started. The solver does its job and i rename the X,Y,Z coordinates of the rocket (formely called Xr,Yr,Zr) to X3,Y3,Z3. The problem is when i want a numeric answer, i.e i type in X3(400)...i get
Hi I am using Maple (9.5) to calibrate the value of an expression for a bond to obtain "issue-at-par-value". Part of the procedure is to minimize the valuation-expression by changing the bankruptcy-level. I use the following: B3 := Minimize(HYB(100,10,x,0.06,0.0023),x=0..65); and get typically: [70.003...,[x=50.15...]] When I then need to use these results in the next iteration, I can pick the value (70.003...) by typing V := B3[1]; No problem so far, but I need help to be able to assign the value of 'x' to a variable I can use later. I have studied manuals, Help-pages etc., but as my PhD-thesis is due in shortly, I hope someone may help me..
The deflection curve of a prismatic bar can be represented by a trigonometric series (S. Timoshenko, Theory of Elastic Stability, 1st Ed. 1936, p. 23). I am trying to find a way to enter a sine series into Maple of the form: y=a1*sin(Pi*x/l)+a2*sin(2*Pi*x/l)+a3*sin(3*Pi*x/l)+... I have downloaded the FourierTrigSeries package and have not had any success in entering the sine series as defined above. Any suggestions? Thank you for your assistance.
Hi, New to Maple 11. Using the tutor to solve definite integral. Would like to enter pi/2 as one of the limits. I know control space works in main program, but it does not seem to work while in the tutor. Any help appreciated. Thanks!
I have downloaded the FourierTrigSeries package which contains two files: maple.ind and maple.lib. Could someone tell me how to make the routines available in a session? Thank you for the response.
First 2330 2331 2332 2333 2334 2335 2336 Last Page 2332 of 2457
