 The following code:
for i to np do
    pl_pp[i] := point([h_p[i], m_p[i]], color = red);
    pl_np[i] := point([h_n[i], m_n[i]], color = blue);
    pl_pn[i] := point([-h_n[i], -m_n[i]], color = red);
    pl_nn[i] := point([-h_p[i], -m_p[i]], color = blue);
end do
Gives following error:
Error, (in plottools:-point) incorrect arguments for creating points structure, try providing the dimension option
Please Help,
I am trying to plot some movement equations, but the following error keeps happening:
when I tryed to rewrite the equation the error became:
Can someone help me with those errors?
Here is the code
pp.mw
I find it difficult to use dsolve to solve system of ordinary differential equations with assigned parameters and initial conditions. The error message "Error, (in dsolve/numeric) 'parameters' must be specified as a list of unique unassigned names" kept coming up.
Pls see the uploaded equation for more understanding
interface(imaginaryunit = F)
I
I
I
sqrt(-4)
2*I
Suscep := diff(S(t), t) = theta*epsilon+v__2*S__v(t)-S(t)*lambda-S(t)*(µ+v__1)
diff(S(t), t) = theta*varepsilon+v__2*S__v(t)-S(t)*lambda-S(t)*(µ+v__1)
Vacc := diff(S__v(t), t) = (1-theta)*epsilon+v__1*S(t)-(µ+alpha+v__2)*S__v(t)-(1-w)*S__v(t)*lambda
Immun := diff(V(t), t) = alpha*S__v(t)+`ρ__A`*A(t)+(1-k)*`ρ__Q`*Q(t)+`ρ__I`*(I)(t)-µ*V(t)
Exp := diff(E(t), t) = S(t)*lambda+(1-w)*S__v(t)*lambda-(q__E+delta+µ)*E(t)
Asymp := diff(A(t), t) = delta*a*E(t)-(`ρ__A`+µ)*A(t)+k*`ρ__Q`*Q(t)
Inf := diff((I)(t), t) = delta*(1-a)*E(t)-(`ρ__I`+q__I+`δ__I`+µ)*(I)(t)
Quar := diff((I)(t), t) = q__E*E(t)+q__I*(I)(t)-(`ρ__Q`+`δ__Q`+µ)*Q(t)
init_conds := S(0) = S_0, S__v(0) = S__v*_0, V(0) = V_0, E(0) = E_0, A(0) = A_0, (I)(0) = I_0, Q(0) = Q_0
S(0) = S_0, S__v(0) = S__v*_0, V(0) = V_0, E(0) = E_0, A(0) = A_0, I(0) = I_0, Q(0) = Q_0
sys := {Asymp, Exp, Immun, Inf, Quar, Suscep, Vacc, init_conds}
sol := dsolve(sys, numeric, parameters = [`δ__Q`, `δ__I`, a, k, epsilon, v[1], q[E], q[I], q[A], eta[A], eta[Q], rho[A], rho[Q], rho[I], v[2], alpha, mu, delta, alpha, beta, w, lambda, S_0, S__v*_0, V_0, E_0, A_0, I_0, Q_0], method = rkf45)
sol(parameters = [delta = .125, `δ__Q` = 0.6847e-3, epsilon = .464360344, `δ__I` = 0.2230e-8, a = .6255, q[E] = 0.18113e-3, k = .15, v__1 = 0.5e-1, v__2 = 0.6e-1, `ρ__Q` = 0.815e-1, `ρ__A` = .1, `ρ__I` = 0.666666e-1, q__I = 0.1923e-2, q__A = 0.4013e-7, `η__A` = .1213, `η__Q` = 0.3808e-2*alpha and 0.3808e-2*alpha = .4, w = .5925, mu = 0.464360344e-4, lambda = 0.1598643e-7, S_0 = 1.0, S__v*_0 = 0.6e-4, V_0 = 0.35e-4, E_0 = 0.5e-4, I_0 = 0.32e-4, A_0 = 0.15e-4, Q_0 = 0.1e-4])
sol(parameters = [delta = .125, delta__Q = 0.6847e-3, varepsilon = .464360344, delta__I = 0.2230e-8, a = .6255, q[E] = 0.18113e-3, k = .15, v__1 = 0.5e-1, v__2 = 0.6e-1, rho__Q = 0.815e-1, rho__A = .1, rho__I = 0.666666e-1, q__I = 0.1923e-2, q__A = 0.4013e-7, eta__A = .1213, false, w = .5925, mu = 0.464360344e-4, lambda = 0.1598643e-7, S_0 = 1.0, S__v*_0 = 0.6e-4, V_0 = 0.35e-4, E_0 = 0.5e-4, I_0 = 0.32e-4, A_0 = 0.15e-4, Q_0 = 0.1e-4])
Evaluate*the*system*at*t = 2
sol(2)
sol(2)
sol(1)
sol(1)
sol(.1)
sol(.1)
sol(.3)
sol(.3)
sol(.5)
sol(.5)
sol(.7)
sol(.7)
sol(.9)
sol(.9)
sol(1.1)
sol(1.1)
(14)
sol(1.3)
sol(1.3)
(15)
sol(1.5)
sol(1.5)
(16)
Download Covid19_Simulation.mw
Dear Maple community,
I am trying to define an operator in Maple that multiplies to an expression and substitutes the indices.
The issue is that I don't want to add the expression as input of the operator/function, sth like:
p := proc(i, j, z) option operator; subs({i = j, j = i}, z); end proc
I want it to act on expression, like:
P(i,j)*X(i,j,k)=X(j,i,k)
and X can be any tensor or matrix.
Hi Guys, can someone explain how to resubstitute equations I already stated, into my final form (e.g. a derivative)?
I'm unable to substitute my g(x) expression (eq. (2)) into my derivative of f(x) (eq. (4). It only works if I state explicitly which variables to substitute via algsubs (last statement). However, for that I have to rename g(x)-->h(x). Can someone explain what I'm doing wrong here? I'd love to be able to tell maple just to use already given equations (that is g(x), eq. (2)) to simplify my derivative.
Thanks guys!
The shortcut key Ctrl+Delete is used to clear a math region or delete a cell within a group, so I can delete some output manually. However, I find that there exists some long-standing functions like PrintTemporary and Monitor in Mathematica, which can be used to print intermediate values of variables temporarily (and dynamically, if possible). The term "temporarily" means that the printed output disappears at the end of a computation / when a computation is complete / when the evaluation finishes / before returning the result of an evaluation. For instance:
(Note that certain operations require a front end.)
Is it possible to implement such functionalities in Maple?
I get a problem while selecting elements from sets.
I have a list of two sets apparently ordered in the same order.
When I pick this, for instance, first set from each of these two samples I get the first one from the first set, and the second one from the second set.
DF := [ {diff(Theta(x), x), diff(Theta(x), x, x)}, {diff(g(x), x), diff(g(x), x, x)} ]
[{diff(Theta(x), x), diff(diff(Theta(x), x), x)}, {diff(diff(g(x), x), x), diff(g(x), x)}]
# Why are the elements of DF[2] not returned in their correct order?
i := 1;
DF[i], DF[i][1], DF[i][2];
print():
i := 2;
{diff(Theta(x), x), diff(diff(Theta(x), x), x)}, diff(Theta(x), x), diff(diff(Theta(x), x), x)
{diff(diff(g(x), x), x), diff(g(x), x)}, diff(diff(g(x), x), x), diff(g(x), x)
# I suppose we must not trust what is displayed and that lprint is more
# trustworthy?
lprint(DF)
# I expected that converting each element of DF into a list would fix this
# problem. but anothr does appear:
# "Why does the conversion into list change the order of the elements?"
# I had never seen that before
LDF := convert~(DF, list)
[[diff(Theta(x), x), diff(diff(Theta(x), x), x)], [diff(diff(g(x), x), x), diff(g(x), x)]]
Download Selection_from_a_set.mw
Running this command
map(sort, LDF)
displays LDF, which suggests that LDF is already sorted according to some order.
What is this order which makes diff(Theta(x), x$2) the successor of diff(Theta(x), x)  but diff(g(x), x) the successor of diff(g(x), x$2)  ?
odeSys := {diff(Theta(x), x, x)+Pr*(R*(diff(Theta(x), x))*f(x)+Nb*(diff(Theta(x), x))*(diff(Phi(x), x))+Nt*(diff(Theta(x), x))^2), N2*(diff(G(x), x, x))-N1*(2*G(x)+diff(f(x), x, x))-N3*R*((diff(f(x), x))*G(x)-f(x)*(diff(G(x), x))), diff(Phi(x), x, x)+R*Sc*f(x)*(diff(Phi(x), x))+Nt*(diff(Theta(x), x, x))/Nb, (1+N1)*(diff(g(x), x, x))+R*((diff(g(x), x))*f(x)-g(x)*(diff(f(x), x)))-M*g(x)+2*Kr*(diff(f(x), x)), (1+N1)*(diff(f(x), x, x, x, x))-R*((diff(f(x), x))*(diff(f(x), x, x))-f(x)*(diff(f(x), x, x, x)))+N1*(diff(G(x), x, x))-M*(diff(f(x), x, x))-2*Kr*(diff(g(x), x))}; cond := f(0) = 0, (D(f))(0) = 1, g(0) = 0, Theta(0) = 1, G(0) = -n*((D@@2)(f))(0), Phi(0) = 1, f(1) = lambda, (D(f))(1) = 0, g(1) = 0, Theta(1) = 0, G(1) = n*((D@@2)(f))(1), Phi(1) = 0; ans := {};
n := .5; N1 := 0.; N2 := 1.0; N3 := .1; lambda := .1; M := .1; Kr := .1; Sc := 1.0; Nb := .1; Pr := 1.0; Nt := .1; R := .5;
ans := dsolve*{cond, eval*odeSys};
hello these are the pde and Boundary conditions  i want to calculate the value of f''(0) ,Theta(0) and  Phi(0)
what is the proper cammand to get the table values for the given equation
NBVs := [eval(ans(N1*G(x)+(1+N1)*(diff(f(x), x, x))), x = 0), eval(ans(-(diff(Theta(x), x))), x = 0), eval(ans(-(diff(Phi(x), x))), x = 0)];
I have this piece of command in maple which I want to get a numerical value out of it, but instead of that it shows the sines without their numerical values. What to add to these commands to get a numerical value for x? (I checked maple's help for "numerical value", but perhaps I am a bit impatient and didn't find such a thing):
with(Degrees);
solve(x^2 = (4/sind(10))^2 + ((4 + x)/sind(20))^2 - 8*(4 + x)/(sind(10)*sind(20)), x);
I get the following:
                      1                        /  /
---------------------------------------------- \8 \16
4 Degrees:-sind(10)  - 4 Degrees:-sind(10) + 1
                   2                                        2
  Degrees:-sind(10)  Degrees:-cosd(10) - 8 Degrees:-sind(10)  -
  /                     4                  2
  \256 Degrees:-sind(10)  Degrees:-cosd(10)
                          4
   - 192 Degrees:-sind(10)  Degrees:-cosd(10)
                         4
   + 32 Degrees:-sind(10)
   - 64 Degrees:-sind(10)  Degrees:-cosd(10)
   + 24 Degrees:-sind(10)
   + 16 Degrees:-sind(10)  Degrees:-cosd(10)
   - 2 Degrees:-sind(10)/^(1/2)//,
                        1                        /  /
                   2                                        2
  Degrees:-sind(10)  Degrees:-cosd(10) - 8 Degrees:-sind(10)  +
  /                     4                  2
                          4
                         4
IndependencePolynomial returns the independence polynomial for the graph G in the variable x.
For the following example, its calculation took over 20 minutes and still hasn't produced a result, and what's fatal is that it  has consumed 4G  memory.
with(GraphTheory):
G:=ConvertGraph("W|tNHEpCKoh`@@Po_WHB@CKC?WGO{G?KKCB`?OMG?_y_?Sn");
G1:=LineGraph(G);
IndependencePolynomial(G1, x) # be careful
I use  codes in  the link https://github.com/pernici/hobj.
It produced results quickly (It takes approximately 5 seconds.). So I think the built-in function " IndependencePolynomial " should be able to be improved. (Of course we are usually very concerned about their coefficients)
Their coefficients of the independent polynomial of G1 are as follows.
[340649, 12329124, 68797662, 140606548, 139481127, 77027880, 25546428, 5303544, 700911, 58580, 2982, 84, 1]
It tells me the total number of independence sets with size 12 is 340649.
Hi guys,
I'm wondering whether it's possible to reverse my "substitution" in order to gain a nicer looking form:
In this example, I'd like to get the last "subs" statement without having to define a new variable "g_new" but instead, maple shall use the old name, and do the "resubstituion" automatically.
I hope someone can help. I'm also happy to get other advice, regarding my problem. Thanks!
Have a output of similar below form
say
output := table([(3, 6) = ["C-C", 0.99414575], (3, 4) = ["C-C", 1.00000000], (6, 13) = ["C-H", 1.11484141], (2, 7) = ["O-C", 0.99996130], (3, 5) = ["C-C", 1.60953223], (4, 7) = ["C-C", 0.99414575], (3, 7) = ["C-C", 1.61174619], (10, 16) = ["C-H", 0.61996904], (3, 8) = ["C-C", 0.99997800], (6, 7) = ["C-C", 1.60940000], (5, 12) = ["C-H", 0.61992962], (5, 6) = ["C-C", 0.99404781], (8, 10) = ["C-C", 0.99997800], (5, 13) = ["C-H", 0.61992962], (11, 17) = ["C-H", 0.61996904], (4, 5) = ["C-C", 1.60953223], (9, 15) = ["C-H", 0.62000000], (9, 11) = ["C-C", 0.99997800], (4, 6) = ["C-C", 1.61174619], (4, 9) = ["C-C", 0.99997800], (5, 7) = ["C-C", 0.99404781], (10, 11) = ["C-C", 1.00000000], (1, 6) = ["O-C", 0.99996130], (7, 12) = ["C-H", 1.11484141], (8, 14) = ["C-H", 0.62000000]])
Create a function which take the above table as and ouputs an weighted undirected Graph G.
I would like to get undirected graph such that
condition
1) We need to form a square matrix say A1 of dimension n cross n where n is the larges among all the integers in the (i,j) that list the above example 17 is the highest among all of the (i,j) sets.
2) then form a weighted square matrix 17 cross 17 where second element of the inside list has to be wiegth in that position
That is the in the matrix (3,6) and (6,3) should have weight  0.99414575,  in the matrix (3,4) and (4,3) should have weight 1.00000000 etc.
3) Then we need to remove all rows and columns which matches to H
That
(10, 16) = ["C-H", 0.61996904] here H goes for 16 so we remove Row 16 and Column 16 of A1
again (5, 12) = ["C-H", 0.61992962] here H goes for 12 so we remove Row 12 and Column 12 of A1
so if we could remove all rows and coulmns where H is their in A1 in one go
as if I remove one row and columns then immedialety row and column number will changes so need to be very careful.
Then the function changes the square weighted matrix to a graph outputs the graph.
The table will of similar form but only thing is number of elements in the table can change.
Kind help
dear all
I would like to solve the following differential equation in Maple Numerically.
pde := I*10*diff(u(k, t), t) + (diff(u(k, t), t, t)) -16* u(k, t) = 0;
ics := u(k, 0) = sqrt(Pi/2)*csch(Pi/2*k), (D[2](u))(k, 0) = -(1/4)*sqrt(2)*Pi^(3/2)*csch((1/2)*Pi*k)*coth((1/2)*Pi*k)
bcs := u(0, t) = 0, u(100, t) = 0;
sol := pdsolve(pde, {ics, bcs}, numeric, range = 0 .. 1, output = listprocedure);
sol;
here the sech(x)^2 in real space and corresponding fourier transformaation is the initial condition
the Gaussian function as initial condition is also an alternative.
How can I solve it?
Hello, I am trying to evaluate this summation, but it keeps giving me a "Error, (in H) bad index into Vector", I can`t find the problem in function, would somebody helps? thanks.
My function:
with(linalg); H := proc (z, aa, AA, bb, BB, m, n, p, q) mu0 := sum('BB'[i], i = 1 .. q)-(sum('AA'[i], i = 1 .. p)); beta0 := (product('AA'[i]^(-'AA'[i]), i = 1 .. p))*(product('BB'[i]^(-'BB'[i]), i = 1 .. q)); if z <> 0 and 0 < mu0 or 0 < abs(z) and abs(z) < 1/beta0 and mu0 = 0 then do s := Vector([seq(-('bb'[i]-v)/'BB'[i], i = 1 .. m)]); Hz := sum(sum((product(('`if`')(i <> h, GAMMA('bb'[i]+'BB'[i]*'s[h]'), 1), i = 1 .. m))*(product(('`if`')(i <> h, GAMMA(1-'aa'[i]-'AA'[i]*'s[h]'), 1), i = 1 .. n))*(-1)^v*z^(('bb[h]'+v)/'BB[h]')/(('`if`')(m < q, product(('`if`')(i <> h, GAMMA(1-'bb'[i]-'BB'[i]*'s[h]'), 1), i = m+1 .. q), 1)*`if`(n < p, product(('`if`')(i <> h, GAMMA('aa'[i]+'AA'[i]*'s[h]'), i = n+1 .. p), 1), 1)*factorial(v)*'BB[h]'), h = 1 .. m), v = 0 .. 10) end do end if; return Hz end proc
>evalf(H(.547, Vector([-23-j]), Vector([.5]), Vector([0, -24-j]), Vector([1, .5]), 1, 1, 1, 2))
First 232 233 234 235 236 237 238 Last Page 234 of 2427
