I am fairly new to Maple. Suppose I have two Matrices
A := <<true, false, true> | <true, false, true> | <false, false, false>>
B := <<1, 2, 6> | <3, 4, 7> | <22, 33, 44>>
and apply select(A, B)
Why do I receive [[[(),3,22],[(),(),()],[(),7,44]]] instead of [[[1,(),6],[3,(),7],[(),(),()]]] as a result? I just want to select every element of B where A is true.
I appreciate any insight.
This is a simple algebraic, but I would like to know how to officially solve the problem,
I tried factor(6*a+12*b+18*c); it simply outputs what I input.
I tried primpart(6*a+12*b+18*c) ; the output is: a+2b+3c
I tried content(6*a+12*b+18*c), the output is 6
What I'm looking for an output is, 6*(a+2*b+3*c), this is the answer my Algebra book is looking for, I also get this answer by
using my HP Graphing Calculator, but I'm unable to get the answer from Maples. Can anyone help?
Could you Please Help me,the Maple code for Plot this equations in any Numerical Method
with(PDETools, declare):
with(PolynomialIdeals):
declare(f(x));
f(x)*`will now be displayed as`*f
eq1 := diff(f(x), x, x, x)+(1/2)*(1-phi)^2.5*(1-phi+phi*rho[s]/rho[fl])*(eta*`cos&omega;`+f(x)*`sin&omega;`)*(diff(f(x), x, x))+(1-phi)^2.5*M*sin^2*alpha*(1-(diff(f(x), x)))+(1-phi)^2.5*(1-phi+phi*`&rho;&beta;`[s]/`&rho;&beta;`[fl])*lambda[T]*theta = 0;
diff(diff(diff(f(x), x), x), x)+(1/2)*(1-phi)^2.5*(1-phi+phi*rho[s]/rho[fl])*(eta*`cos&omega;`+f(x)*`sin&omega;`)*(diff(diff(f(x), x), x))+(1-phi)^2.5*M*sin^2*alpha*(1-(diff(f(x), x)))+(1-phi)^2.5*(1-phi+phi*`&rho;&beta;`[s]/`&rho;&beta;`[fl])*lambda[T]*theta = 0
eq2 := K[nf]*(diff(theta(x), x, x))/K[f]+(1/2)*Pr*(eta*`cos&omega;`+f*`sin&omega;`)*(diff(theta(x), x)) = 0;
K[nf]*(diff(diff(theta(x), x), x))/K[f]+(1/2)*Pr*(eta*`cos&omega;`+f*`sin&omega;`)*(diff(theta(x), x)) = 0
bcs := F(0) = 0, F(1) = 0, F(10) = 1, Theta(0) = 1, Theta(10) = 0;
a1 := [M = 1, alpha = 0, phi = 0.5e-1, `cos&omega;` = 1, `sin&omega;` = 1, sin(alpha) = 0, lambda[T] = 0, Pr = 6.2, rho[s] = 5200, rho[fl] = 997.1, `&rho;&beta;`[fl] = 20939.1, K[nf] = .6842, eta = 0];
[Pr = 6.2, M = 1, phi = 0.5e-1, `cos&omega;` = 1, `sin&omega;` = 1, sin(alpha) = 0, lambda[T] = 0, `&rho;&beta;`[fl] = 20939.1, K[nf] = .6842, K[f] = .613, eta = 0]
b1 := subs(a1, eq1);
diff(diff(diff(f(x), x), x), x)+.5325197465*f(x)*(diff(diff(f(x), x), x)) = 0
c1 := subs(a2, eq2);
1.116150082*(diff(diff(theta(x), x), x))+3.100000000*f*(diff(theta(x), x)) = 0
d1 := dsolve({b1, bcs}, {bcs, c1}, numeric); d1(0)
Error, (in dsolve/numeric/process_input) invalid argument: {1.116150082*(diff(diff(theta(x), x), x))+3.100000000*f*(diff(theta(x), x)) = 0, F(0) = 0, F(1) = 0, F(10) = 1, Theta(0) = 1, Theta(10) = 0}
d1(0)
Download  Numerical Method.mw
Inverse kinematics can be done in several ways (this webinar gives a very good overview https://www.youtube.com/watch?v=X0OZ9EM6dns). A effective and simple method is to run a model in reverse direction. This can’t be done with causal modeling tools, where information flow is fixed by design (https://de.maplesoft.com/support/help/MapleSim/view.aspx?path=MapleSimUserGuide/Chapter01).
Inverse kinematics, which is possible with acausal modeling tools, is only an example for running a model in the reverse (i.e., inverted) direction.
Without success, I tried to find a reference who first came up with that elegant approach.
Anyone knows more?
I have a problem with calculating complex numbers in Maple.
I type forexample 8(cos(Pi/2)+I*sin(Pi/2)) and I get 8, I should get 8I
Should I re-install Maple or edit my settings?
best regards
Hi everybody,how can I solve these equations in Maple and plot the answers? tnx...
eq1 := diff(x(t), t) = 35*(y-x)
eq2 := diff(y(t), t) = -x*z-7*x+28*y
eq3 := diff(z(t), t) = x*y-3*z
Hi Dear All,
I need to extract the coordinates from spacecurve commend. For example;
h3:=spacecurve([-x,-y,z],omega=ws..0,color=green,thickness=5):
h4:=spacecurve([-x,y,z],omega=ws..0,color=blue,thickness=5):
Where, omega is a parameter difinening x, y, z.
Hello Everyone;
Hope you are fine. I have set of following ODE's;
Every variable has two ODE's. I need to take one ODE for each variable. Is that any way?
I am waiting for your kind response.
Question2.mw
The solution from LPSolve shown in the worksheet below is displayed very weirdly:
  1. The first element is rounded to 3 significant digits.
  2. The variable indices have decimal points.
  3. Zeros are displayed as just decimal points with no digit 0.
Closer inspection (with, say, lprint) will reveal that the weirdness is only with the prettyprinting; the actual entries are as expected.
<(kernelopts,interface)(version), interface~([prettyprint, typesetting])[]>;
Vector(4, {(1) = `Maple 2022.1, X86 64 WINDOWS, May 26 2022, Build ID 1619613`, (2) = `Standard Worksheet Interface, Maple 2022.1, Windows 10, May 26 2022 Build ID 1619613`, (3) = 2, (4) = extended})
(a,b,c):= (2,4,5):
X:= Matrix((a,b), symbol= x):
Y:= Matrix((b,c), symbol= y):
Z:= Matrix((a,c), symbol= z):
RegionC:= <5, 15, 8, 10, 15>:
RegionA:= <90, 75>:
RegionB:= <35, 20, 30, 15>:
Cost1:= <
    2, 1, 3/2,   3;
  5/2, 2, 7/2, 3/2
Cost2:= <
    3/2, 4/5, 1/2, 3/2,   3;
      1, 1/2, 1/2,   1, 1/2;
      1, 3/2,   2,   2, 1/2;
    5/2, 3/2, 3/5, 3/2, 1/2
Cost3:= <
    11/4, 7/2, 5/2, 3,   5/2;
       3, 7/2, 7/2, 5/2, 2
Cost__Total:= (add@(add@`*`~)~)([Cost||(1..3)], [X,Y,Z]):
CapB:= add(X[i], i= 1..a) <=~ RegionB:
CapA:= add(<X|Z>[..,j], j= 1..b+c) <=~ RegionA:
ReqC:= add(<Y,Z>[i], i= 1..a+b) >=~ RegionC:
InEqOutB:= add(<X, -Y^%T>[i], i= 1..a+c) =~ 0:
Cons:= seq~({CapA, CapB, ReqC, InEqOutB}):
Sol:= Optimization:-LPSolve(Cost__Total, Cons, assume= nonnegative);
[103.800000000310, [x[1, 1] = HFloat(0.0), x[1, 2] = HFloat(20.000000000344205), x[1, 3] = HFloat(7.999999999311598), x[1, 4] = HFloat(0.0), x[2, 1] = HFloat(0.0), x[2, 2] = HFloat(0.0), x[2, 3] = HFloat(0.0), x[2, 4] = HFloat(15.000000000688408), y[1, 1] = HFloat(0.0), y[1, 2] = HFloat(0.0), y[1, 3] = HFloat(-1.7763568394002505e-15), y[1, 4] = HFloat(0.0), y[1, 5] = HFloat(0.0), y[2, 1] = HFloat(0.0), y[2, 2] = HFloat(15.0), y[2, 3] = HFloat(5.000000000344206), y[2, 4] = HFloat(0.0), y[2, 5] = HFloat(0.0), y[3, 1] = HFloat(5.000000000000002), y[3, 2] = HFloat(0.0), y[3, 3] = HFloat(0.0), y[3, 4] = HFloat(0.0), y[3, 5] = HFloat(2.9999999993115956), y[4, 1] = HFloat(0.0), y[4, 2] = HFloat(0.0), y[4, 3] = HFloat(2.9999999996557944), y[4, 4] = HFloat(0.0), y[4, 5] = HFloat(12.000000000688413), z[1, 1] = HFloat(0.0), z[1, 2] = HFloat(0.0), z[1, 3] = HFloat(0.0), z[1, 4] = HFloat(0.0), z[1, 5] = HFloat(0.0), z[2, 1] = HFloat(0.0), z[2, 2] = HFloat(0.0), z[2, 3] = HFloat(0.0), z[2, 4] = HFloat(10.0), z[2, 5] = HFloat(0.0)]]
Download BadLPSolveDisp.mw
I am reading some expressions from file.
In the file, it is written as GAMMA(-1,x). When read into Maple using the read file command, it shows as  1/x*Ei(2,x)
I know these are the same mathematically. But I am translating these expressions to sagemath. in sagemath, Ei only accepts one argument.
Now the translator sees Ei in the input, then it keeps it as Ei as it does not know it was the GAMMA with two arguments,  which gives an error when used by sagemath since sagemath only has the one argument version of Ei.
If Maple would keep GAMMA(-1,x) as is, then the translator will just translate it to gamma(-1,x) which works in sage.
To keep things simple, I was wondering if there an option to tell Maple to keep the input as GAMMA(-1,x) and not rewrite to Ei?
Otherwise I would have to now parse each Ei to see if it is the two argument version or the one argument version, and use gamma  for the 2 argument version to keep sage happy which will complicate things for me.
expr:=GAMMA(-1,x)
               Ei(2, x)/x
Maple 2022.1
with(plottools);
Vdot := proc (U, V)local i: add(U[i]*V[i], i = 1 .. 2) end proc:
dist := proc (M, N) sqrt(Vdot(expand(M-N), expand(M-N))) end proc:
ngon := n -> local i; [seq([cos(2*Pi*i/n), sin(2*Pi*i/n)], i = 1 .. n)]:
theta := (2*Pi)/5;
poly := [seq([cos(k*theta), sin(k*theta)], k = 1 .. 5), datatype = float];
Ii := [0, 1/2]:
H := [-1/4, 0]:
r := dist(Ii, H):
theta := (2*Pi)/5:
p1 := pointplot([seq([cos(k*theta), sin(k*theta)], k = 0 .. 5)], symbol = solidcircle, color = red, symbolsize = 10):
p2 := textplot([seq([cos(k*theta), sin(k*theta), cat("M", k)], k = 0 .. 4)], align = ["above", "right"]):
cir1 := circle([0, 0], 1/2, color = green,dashdot:):
cir2 := circle([-1/4, 0], r, color = black):
cir3:=circle([0,0],1,color=red):
display([p1, p2, cir1, cir2, cir3,polygonplot(poly, thickness = 5, color = blue, transparency = 0.95)], axes = normal);
Why this error , Thank you.
I am trying to rotate a region about the y-axis. However, entering axis=vertical rotates it about the z-axis. I have also tried interchanging the x and y values. However, it produces the same output. The left image is what I'd like to rotate about the y-axis. The code below is for the right image. How would I revolve this region about the y-axis? Please help.
VolumeOfRevolution(2*x^2 + 1, x = 0 .. 1, labels = [x, y, z], output = plot, axis = vertical, orientation = [270, 0, 90])
I am transitioning from Mathcad to Maple, and I am currently working on some code to do a Gage R&R study using ANOVA. The attached math is from the 4th edition of the MSA manual. I got it to work in Mathcad, although I had to adjust things since Mathcad does not support 3D matrices.
My input matrix is a 2D matrix in which each cell contains a vector of measurements. In Maple, I seem to be able to make a 3D array with my data (if it is easier).
I have searched for a couple days for the right syntax. I am able to get the "right" number for SSA using my 2D Mathcad matrix--at least it is really close--but the other varibles are woefully off.
I would appreciate it if someone could at least point me in the right direction. Thanks.
Jno.
Hello Everyone;Hope you are fine. I am trying to convert the nonlinear system of ODE's into matric form using the following comand but not working it.
Kindly help me to do this. The cose is pasted and also attached. I am waiting for your kind response.
Question1_NEW.mw
restart; with(PDEtools, Solve); with(LinearAlgebra); with(plots); with(plottools); printlevel := 2
ZETA[0] := proc (t) options operator, arrow; 0 end proc:
sys222 := [(3/16)*Pi*C[2, 1](t)+(3/4)*Pi*C[1, 1](t)+diff(C[1, 1](t), t) = 0, 5*Pi*C[2, 2](t)+20*Pi*C[1, 2](t)+diff(C[1, 2](t), t) = 0, 800*ZETA[0](t)*C[1, 1](t)*Pi+(3/4)*Pi*C[2, 1](t)+(3/4)*Pi*C[1, 1](t)+diff(C[2, 1](t), t) = 0, 4320*ZETA[1](t)*C[1, 1](t)*Pi+4320*ZETA[0](t)*C[1, 2](t)*Pi+20*Pi*C[2, 2](t)+20*Pi*C[1, 2](t)+diff(C[2, 2](t), t) = 0, diff(ZETA[1](t), t)+(1/3)*C[2, 1](t) = 0, diff(ZETA[2](t), t)+(1/3)*C[2, 2](t) = 0]
[(3/16)*Pi*C[2, 1](t)+(3/4)*Pi*C[1, 1](t)+diff(C[1, 1](t), t) = 0, 5*Pi*C[2, 2](t)+20*Pi*C[1, 2](t)+diff(C[1, 2](t), t) = 0, (3/4)*Pi*C[2, 1](t)+(3/4)*Pi*C[1, 1](t)+diff(C[2, 1](t), t) = 0, 4320*ZETA[1](t)*C[1, 1](t)*Pi+20*Pi*C[2, 2](t)+20*Pi*C[1, 2](t)+diff(C[2, 2](t), t) = 0, diff(ZETA[1](t), t)+(1/3)*C[2, 1](t) = 0, diff(ZETA[2](t), t)+(1/3)*C[2, 2](t) = 0]
var1 := {C[1, 1](t), C[1, 2](t), C[2, 1](t), C[2, 2](t), ZETA[1](t), ZETA[2](t)};
f, diffs := eval(GenerateMatrix(`~`[`-`](`~`[rhs](sys222), `~`[lhs](sys222)), var1))
f, diffs := Matrix(6, 6, {(1, 1) = -(3/4)*Pi, (1, 2) = 0, (1, 3) = -(3/16)*Pi, (1, 4) = 0, (1, 5) = 0, (1, 6) = 0, (2, 1) = 0, (2, 2) = -20*Pi, (2, 3) = 0, (2, 4) = -5*Pi, (2, 5) = 0, (2, 6) = 0, (3, 1) = -(3/4)*Pi, (3, 2) = 0, (3, 3) = -(3/4)*Pi, (3, 4) = 0, (3, 5) = 0, (3, 6) = 0, (4, 1) = 0, (4, 2) = -20*Pi, (4, 3) = 0, (4, 4) = -20*Pi, (4, 5) = 0, (4, 6) = 0, (5, 1) = 0, (5, 2) = 0, (5, 3) = -1/3, (5, 4) = 0, (5, 5) = 0, (5, 6) = 0, (6, 1) = 0, (6, 2) = 0, (6, 3) = 0, (6, 4) = -1/3, (6, 5) = 0, (6, 6) = 0}), Vector(6, {(1) = diff(C[1, 1](t), t), (2) = diff(C[1, 2](t), t), (3) = diff(C[2, 1](t), t), (4) = 4320*ZETA[1](t)*C[1, 1](t)*Pi+diff(C[2, 2](t), t), (5) = diff(ZETA[1](t), t), (6) = diff(ZETA[2](t), t)})
Download Question1_NEW.mw
Hhow can i solve R it says here root of
Calculate.mws
First 299 300 301 302 303 304 305 Last Page 301 of 2428
