When I export a very simple Maple 2018 (MaxOS) document to Latex, this tex file results:
%% Created by Maple 2018.2, Mac OS X
%% Source Worksheet: untitled 3
%% Generated: Sun Jul 03 16:34:49 CEST 2022
\documentclass{article}
\usepackage{maplestd2e}
\def\emptyline{\vspace{12pt}}
\begin{document}
\pagestyle{empty}
\DefineParaStyle{Maple Bullet Item}
\DefineParaStyle{Maple Heading 1}
\DefineParaStyle{Maple Warning}
\DefineParaStyle{Maple Heading 4}
\DefineParaStyle{Maple Heading 2}
\DefineParaStyle{Maple Heading 3}
\DefineParaStyle{Maple Dash Item}
\DefineParaStyle{Maple Error}
\DefineParaStyle{Maple Title}
\DefineParaStyle{Maple Text Output}
\DefineParaStyle{Maple Normal}
\DefineCharStyle{Maple 2D Output}
\DefineCharStyle{Maple 2D Input}
\DefineCharStyle{Maple Maple Input}
\DefineCharStyle{Maple 2D Math}
\DefineCharStyle{Maple Hyperlink}
\begin{Maple Normal}{
\mapleinline{inert}{2d}{restart; 1}{\[\displaystyle \]}
}\end{Maple Normal}
}\end{Maple Normal}
\mapleinline{inert}{2d}{a := b^2-sqrt(4); "_noterminate"}{\[\displaystyle \]}
}\end{Maple Normal}
}\end{Maple Normal}
\begin{maplegroup}
}\end{Maple Normal}
\mapleresult
\begin{maplelatex}
\mapleinline{inert}{2d}{a := b^2-2; "_noterminate"}{\[\displaystyle \]}
\end{maplelatex}
\end{maplegroup}
}\end{Maple Normal}
}\end{Maple Normal}
\begin{maplegroup}
}\end{Maple Normal}
\mapleresult
\begin{maplelatex}
\end{maplelatex}
\end{maplegroup}
\mapleinline{inert}{2d}{}{\[\displaystyle \]}
}\end{Maple Normal}
}\end{Maple Normal}
\end{document}
However, when trying to process the tex file in both Overleaf and TexShop the pdf output is only an empty page. No error occurs, i.e. the maplestd2e.sty file is recognised by both Overleaf and TexShop.
What is going wrong here?
eq := a*x^3 + b*x^2 + c*x + d;
 s := x1 + x2 + x3 = -b/a;
 sp := x1*x2 + x1*x3 + x2*x3 = c/a;
 p := x1*x2*x3 = -d/a;
sol:=solve({eq, p, s, sp}, {x1, x2, x3},explicit);
 a := 1;
b := -5;
c := 6;
d := -1;
 sol;
why is not successfull ?   Thank you.
I have a problem in plotting bellow function. actually because my main program is not working so I decided to do it in simple way. I found that my program in maple can't plot the function I introduced it as a procudure and is an implicit function. can you help me please?
>EQ := proc(x, t) local y, m, func;
                 m := 3;
                 func := m*x^2 + t*y^2 = 4;
>eq := EQ(x, 10);
                     eq := 3*x^2  + 10*y^2  = 4
>implicitplot(eq, x = -1 .. 1, y = 0 .. 2)
 Error, (in plots/implicitplot) invalid input: the following extra unknowns were found in the input expression: {y}
Given this "pattern" to transfporm an expression into an arrow procedure
e := 1/b:
f := unapply(e, b):
f(3)
I would like now to use this same "pattern" to transform an expression e which depends on 2 indeterminates a and b into a "double layered arrow procedure" f.
Here is a notional example
e := a/b:
f := unapply(unapply(e, b), a);
                     a
           a -> b -> -
                     b
 f(A)(B)
                              a
                              B
How can I proceed in order that f(A)(B) gives A/B ?
TIA
I was surprised to learn that implicitplot doesn't recognize the constant Pi.  I attach a simple example to illustrate.
with(plots)
f := x-y-Pi
x-y-Pi
implicitplot(f)
Error, (in plots/implicitplot) found 3 variables that the expression depends on ({Pi, x, y}), but expected only 2
evalf(Pi)
3.141592654
g := x-y-3.14
x-y-3.14
implicitplot(g)
Download implicitplot_error.mw
dgdx := (x, T) -> diff(g(x, T), x);
g := (x, T) -> T*x + x^2;#just an example
dgdx(1, 2);
Error, (in dgdx) invalid input: diff received 1, which is not valid for its 2nd argument
So, I like to introduce a new function dgdx(x,T) from the x-derivative of g(x,T) but if I insert a value for x I get an error message. It would be great if you can help me out!
Perhaps a silly question but is it possible to stack two dataframe columns? When I use the Vector command the columns are stacked but nested.
Thank you for your help
5_6190449716501677775.pdf
I ahve a signal y_a to which adding mu(t) doesn't seem to give any plot but error , what is missing here?.
And also in second k(x,t) pdf file I want the value of k(x,t) after I did the integration. When I type k(x,t) and hit enter it's not giving me the value of k(x,t) but returns k(x,t) as it is.K(x_t).pdf
I do not remember now if this was asked before. Doing search here is hard.
But I am trying this now on 2022.1 and this gives FAIL.
What is the correct syntax to use odetest to verify solution to ode using series method with expansion around infinity? Why do I get FAIL here?
interface(version)
Physics:-Version()
`The "Physics Updates" version in the MapleCloud is 1257 and is the same as the version installed in this computer, created 2022, June 22, 16:27 hours Pacific Time.`
ode:=x^3*diff(y(x),x$2)+x^2*diff(y(x),x)+y(x)=0;
sol:=dsolve(ode,y(x),'series',x=infinity);
odetest(sol,ode,'series','point'=infinity)
x^3*(diff(diff(y(x), x), x))+x^2*(diff(y(x), x))+y(x) = 0
y(x) = _C1*(1-1/x+(1/4)/x^2-(1/36)/x^3+(1/576)/x^4-(1/14400)/x^5+O(1/x^6))+_C2*(ln(1/x)*(1-1/x+(1/4)/x^2-(1/36)/x^3+(1/576)/x^4-(1/14400)/x^5+O(1/x^6))+2/x-(3/4)/x^2+(11/108)/x^3-(25/3456)/x^4+(137/432000)/x^5+O(1/x^6))
Warning, unable to compute series necessary to test the given solution
FAIL
Download odetest_series.mw
Update
I've testsed methods given below on 6 random ode's using Maple odetest, VV method and Axel method. THis is the result obtained using Maple 2022.1
odetest was able to verify the solution zero out of 6 times.
VV method was able to verify the solution 3 out of 6 times.
Axel method was able to verify the solution 5 out of 6 times.
So based on this small test, Axel method seems to do the best. Attached worksheet. I will use this method to verify my series solution to ode's instead of Maple's odetest but will use Maple's odetest for non-series method solutions.
Example 1  Regular singular point. Complex roots
Order:=6;
ode:=sin(x)*diff(y(x),x$2)+cos(x)*diff(y(x),x)+1/x*y(x)=0;
sol:=dsolve(ode,y(x),type='series',x=0)
6
sin(x)*(diff(diff(y(x), x), x))+cos(x)*(diff(y(x), x))+y(x)/x = 0
y(x) = _C1*x^(-I)*(series(1+(1/48-(1/16)*I)*x^2+(1/57600-(217/57600)*I)*x^4+O(x^6),x,6))+_C2*x^I*(series(1+(1/48+(1/16)*I)*x^2+(1/57600+(217/57600)*I)*x^4+O(x^6),x,6))
VV method
odetest(sol,ode):
asympt(%,x);
Error, (in asympt) unable to compute series
odetest method
odetest(sol,ode,'series','point'=0);
y(t) = _C1*t^(-I)*(series(1+(1/48-(1/16)*I)*t^2+(1/57600-(217/57600)*I)*t^4+O(t^6),t,6))+_C2*t^I*(series(1+(1/48+(1/16)*I)*t^2+(1/57600+(217/57600)*I)*t^4+O(t^6),t,6))
Axel method
rhs(sol):
Y:= unapply(%, x):
eval(lhs(ode), y=Y):
MultiSeries:-asympt(%, x):
convert(%,polynom);
Example 2 Regular singular point. Dierence is integer
Order:=6;
ode:=sin(x)*diff(y(x),x$2)+cos(x)*y(x)=0;
sol:=dsolve(ode,y(x),type='series',x=0):
6
sin(x)*(diff(diff(y(x), x), x))+cos(x)*y(x) = 0
VV method
odetest(sol,ode):
asympt(%,x);
convert(%,polynom);
O(x^7)
odetest method
FAIL
Axel method
rhs(sol):
Y:= unapply(%, x):
convert(%,polynom);
Example 3 Regular singular point. Repeated root
Order:=6;
ode:=(exp(x)-1)*diff(y(x),x$2)+exp(x)*diff(y(x),x)+y(x)=0;
6
(exp(x)-1)*(diff(diff(y(x), x), x))+exp(x)*(diff(y(x), x))+y(x) = 0
VV method
odetest(sol,ode):
asympt(%,x):
convert(%,polynom);
odetest method
FAIL
Axel method
rhs(sol):
Y:= unapply(%, x):
convert(%,polynom);
Example 4 Regular singular point. Repeated root
Order:=6;
6
VV method
odetest(sol,ode):
asympt(%,x):
convert(%,polynom);
odetest method
FAIL
Axel method
rhs(sol):
Y:= unapply(%, x):
convert(%,polynom);
Example 5 . Regular singular point. Complex roots
Order:=6;
ode:=x^3*diff(y(x),x$2)+sin(x^3)*diff(y(x),x)+x*y(x)=0;
6
x^3*(diff(diff(y(x), x), x))+sin(x^3)*(diff(y(x), x))+x*y(x) = 0
VV method
odetest(sol,ode):
asympt(%,x);
#convert(%,polynom);
odetest method
Error, (in odetest/series) need to determine the sign of I*3^(1/2)
Axel method
rhs(sol):
Y:= unapply(%, x):
Error, (in MultiSeries:-multiseries) need to determine the sign of -I*3^(1/2)
Example 6 . Regular singular point. Complex roots
Order:=6;
ode:=x^2*diff(y(x),x$2)+x*diff(y(x),x)+(x+1)*y(x)=0;
6
x^2*(diff(diff(y(x), x), x))+x*(diff(y(x), x))+(x+1)*y(x) = 0
VV method
odetest(sol,ode):
asympt(%,x);
odetest method
y(x) = _C1*x^(-I)*(series(1+(-1/5-(2/5)*I)*x+(-1/40+(3/40)*I)*x^2+(3/520-(7/1560)*I)*x^3+(-1/2496+(1/12480)*I)*x^4+(9/603200+(1/361920)*I)*x^5+O(x^6),x,6))+_C2*x^I*(series(1+(-1/5+(2/5)*I)*x+(-1/40-(3/40)*I)*x^2+(3/520+(7/1560)*I)*x^3+(-1/2496-(1/12480)*I)*x^4+(9/603200-(1/361920)*I)*x^5+O(x^6),x,6))
Axel method
rhs(sol):
Y:= unapply(%, x):
convert(%,polynom);
Download test_new_odetest.mw
What is the [explict] relation between Maple's WeierstrassP and Weierstrass' P-function (e.g. https://en.wikipedia.org/wiki/Weierstrass_elliptic_function) ?
How can I specify english units as the default in Flow?  Rather than Newtons (N), pound force (lbf)?
pdf.mw
with(stats)
"f(x):=statevalf[pdf,normald[0,2*4.47]]  "
proc (x) options operator, arrow, function_assign; statevalf[pdf, normald[0, 2*4.47]] end proc
plot(f(x), -20 .. 20)
int(x*f(x), x)
.5000000000*x^2*statevalf[pdf, normald[0, 8.94]]
Download pdf.mw
Want to integrate x*f(x) where x is from -20..20, I am expecting a pure float number but getting symbols like statevalf_pdf in answer.
I am using some custom procedures which return error messages if something doesn´t work as planned and would need to make a distinction (when using try..catch) between these errors and all the other potential error messages Maple can return. Is there a way to do this efficiently - without having to list all of the error messages from my own procedures after catch?
Hello Everyone;
Hope you are fine. My problem is convert into nonlinear system of ODE's and further i need make the code of apply rk-4 for the formulated ODE's. Kindly guide me. The file is attached. I am waiting for your kind response.
Question3.mw
var111 := [C[1, 1](t), C[1, 2](t), C[1, 3](t), C[2, 1](t), C[2, 2](t), C[2, 3](t), C[3, 1](t), C[3, 2](t), C[3, 3](t), ZETA[1](t), ZETA[2](t), ZETA[3](t)]:
sysM := [diff(C[1, 1](t), t) = -(3/16)*Pi*(C[2, 1](t)+4*C[1, 1](t)), diff(C[1, 2](t), t) = -5*Pi*(C[2, 2](t)+4*C[1, 2](t)), diff(C[1, 3](t), t) = -(945/4)*Pi*(C[2, 3](t)+4*C[1, 3](t)), diff(C[2, 1](t), t) = -(1/8)*Pi*(C[3, 1](t)+6*C[2, 1](t)+6*C[1, 1](t)), diff(C[2, 2](t), t) = -10.4719755119659774615421446110*C[3, 2](t)-62.8318530717958647692528676658*C[2, 2](t)-62.8318530717958647692528676658*C[1, 2](t)-2.38361014507273884349657421134*10^15*ZETA[1](t)*C[1, 1](t), diff(C[2, 3](t), t) = -494.800842940392435057866332869*C[3, 3](t)-2968.80505764235461034719799721*C[2, 3](t)-2968.80505764235461034719799721*C[1, 3](t)-1.35954060126371030332767566128*10^16*ZETA[1](t)*C[1, 2](t)-1.35954060126371030332767566128*10^16*ZETA[2](t)*C[1, 1](t), diff(C[3, 1](t), t) = -(3/8)*Pi*(2*C[3, 1](t)+3*C[2, 1](t)), diff(C[3, 2](t), t) = -62.8318530717958647692528676658*C[3, 2](t)-94.2477796076937971538793014986*C[2, 2](t)-1.12625579354686910355213131486*10^17*ZETA[1](t)*C[2, 1](t), diff(C[3, 3](t), t) = -2968.80505764235461034719799721*C[3, 3](t)-4453.20758646353191552079699581*C[2, 3](t)-6.42382934097103118322326749959*10^17*ZETA[1](t)*C[2, 2](t)-6.42382934097103118322326749959*10^17*ZETA[2](t)*C[2, 1](t), diff(ZETA[1](t), t) = -(1/3)*C[2, 1](t), diff(ZETA[2](t), t) = -(1/3)*C[2, 2](t), diff(ZETA[3](t), t) = -(1/3)*C[2, 3](t)]:
ICS := [C[1, 1] = 0.998238989835086492681507032141e-1, C[1, 2] = -0.137051161872492529218951625903e-1, C[1, 3] = -0.629146365720807620696267926206e-2, C[2, 1] = 0.923300332435106257640735267282e-1, C[2, 2] = -0.126762613568515069966837491839e-1, C[2, 3] = -0.581915808273854734025727975244e-2, C[3, 1] = -0.190143920352772604950256237747e-1, C[3, 2] = 0.261054171122321128306306984717e-2, C[3, 3] = 0.119839394846335068333097530793e-2, ZETA[1] = .464598743230343884242076682299, ZETA[2] = .429720916976380440572769663279, ZETA[3] = -0.884964696113332752036741498040e-1]:
Download Question3.mw
The worksheet here shows a couple of failed attempts at coaxing Maple to calculate the general solution of a pretty simple second order ODE.  I have also included the expected solution which I  have calculated by hand.  Perhaps I am missing a key trick.  Any ideas?
The ODE that I am actually interested in is significantly more complex. The one in the worksheet is a much simplified "bare bones" specimen that exhibits the issue that I am facing.
Attempt to solve with Heaviside
de := diff(u(x),x$2) = Heaviside(x - a)*u(x);
diff(diff(u(x), x), x) = Heaviside(x-a)*u(x)
dsolve fails:
dsolve(de);
u(x) = DESol({diff(diff(_Y(x), x), x)-Heaviside(x-a)*_Y(x)}, {_Y(x)})
Attempt to solve with piecewise
de := diff(u(x),x$2) = piecewise(x < a, 0, 1)*u(x);
de := diff(u(x), x, x) = piecewise(x < a, 0, 1)*u(x)
dsolve(de);
Error, (in dsolve) give the main variable as a second argument
dsolve(de, u(x));
The solution is easy to calculate by hand
We just solve the (quite trivial) DE over the intervals x < a and x>a
separately, and patch the two solutions by requiring the continuity
of u(x) and diff(u(x), x) at x = a.  We get
sol := piecewise(x < a,
        x*c[1] + c[2],
        ((a*c[1] + c[1] + c[2])*exp(x))/(2*exp(a)) + ((a*c[1] - c[1] + c[2])*exp(-x))/(2*exp(-a)));
sol := piecewise(x < a, x*c[1]+c[2], (a*c[1]+c[1]+c[2])*exp(x)/(2*exp(a))+(a*c[1]-c[1]+c[2])*exp(-x)/(2*exp(-a)))
Download solving-an-ode.mw
First 298 299 300 301 302 303 304 Last Page 300 of 2428
