PlaneDual returns the plane dual of a planar graph G, that is, a graph with faces of G as its vertices in which two vertices are adjacent if and only if they share an edge as faces of G. Of course, this is a little different from the standard definition of plane dual. (Interlude: I estimate that the two definitions are equivalent in the case that the planar graph is 3-connected simple graph)
It's not hard to find a plane dual of a planar graph in Maple.
g:=Graph({{1,2},{2,4},{3,4},{2,3},{1,3},{1,4},{4,5},{2,5},{1,5}});
DrawPlanar(g);
dual_g:=PlaneDual(g);
DrawPlanar(
dual_g)
Since all labels of the dual graph are used numbers 1..n in maple, I cannot see how its vertices correspond to the face of the original graph.  And further, I want to know one edge of the dual graph corresponds to which edge (should be the boundary on two faces) of the original planar graph.
Maybe input {1,4} of the dual graph and output {2,4} of the original graph.
For example, Input {1} that is a vertex of  dual graph  to get the original face {2,3,4} and if we input {1,4} of the dual graph, we will output edge {2,4} of the original graph.
I don't know if there's a good way to do that.
Hi! I was wondering about drawing phase plane for differential system with some conditions. For example how can we draw this for:
with(DEtools);
ode := piecewise(1 < abs(x(t)), diff(x(t), t $ 2) - 2 = 0, abs(x(t)) < 1, diff(x(t), t $ 2) = 0);
I wanted something similar to that:
DEplot({diff(x(t), t) = y(t), diff(y(t), t) = 8*x(t)*y(t)}, [x(t), y(t)], t = -2 .. 2, x = -1 .. 1, y = -4 .. 4);
or this:
ode1 := diff(x(t), t $ 2) + 2*diff(x(t), t) = 0
DEplot(ode1, x(t), t = -2 .. 10, [[x(1) = 0.2, D(x)(1) = -1.4]]);
Edit:
I rewrite that to make integral curves and this phase plot should look similar to this:
Hi! I know that length of blue line and red line equal: Pi/4 and Pi*sin(Pi/8)/4 so from spherical pythagorem theorem green line should equals cos(Pi/4)*cos(Pi*sin(Pi/8)/4) but when I calculate this from formula for length of parametric curve I got something like this (I have just emphasized):
assume(t, real);
K := plot3d(1, theta = 0 .. 2*Pi, phi = 0 .. Pi, coords = spherical);
S2 := display(spacecurve([cos(t)*sin(t + Pi/8), sin(t + Pi/8)*sin(t), cos(t + Pi/8)], t = 0 .. Pi/4, thickness = 3, color = green)):
int(sqrt(<diff(cos(t)*sin(t + Pi/8), t), diff(sin(t + Pi/8)*sin(t), t), diff(cos(t + Pi/8), t)> . <diff(cos(t)*sin(t + Pi/8), t), diff(sin(t + Pi/8)*sin(t), t), diff(cos(t + Pi/8), t)>), t = 0 .. Pi/4)
-sqrt(2 - sqrt(2))*sqrt(2 + sqrt(2))*sqrt(2)*EllipticE(I/2*sqrt(2 - sqrt(2)), I)*I/2 + sqrt(2 - sqrt(2))*sqrt(2 + sqrt(2))*sqrt(2)*EllipticF(I/2*sqrt(2 - sqrt(2)), I)*I + EllipticE(I/2*sqrt(2 + sqrt(2)), I)*I - 2*I*EllipticF(I/2*sqrt(2 + sqrt(2)), I)
evalf(%)
0.959458136 + 0.*I
evalf(cos(Pi/4)*cos(Pi*sin(Pi/8)/4))
0.6754080210
I am not sure is Maple calculation wrong or I have missed something important?
Here is my pde and a procedure that plots the solution.
K1:=proc(g)
uses PDEtools,plots:
local pde, ic,ans;
pde:=-4*x*diff(f(u,x),u,x)+4*diff(f(u,x),u)=x^4*diff(f(u,x),x,x)+x^3*diff(f(u,x),x)+8*x^2*f(u,x)*(1-f(u,x)^2);
ic:={f(u,0) = 1, f(u,1) = 0,f(0,x)=g};
ans:=pdsolve(pde,ic,numeric,compile=true,time=u,range=0..1,'spacestep'=0.005);
ans:-plot(u=3)
K1(1+x^2-2*x^3);
It works just fine; I get a plot of f(u,x) for u =3.  (Note that unlike dsolve there is no complaint about the global variable g in the initial conditions.)
Now I want to see a plot of diff(f(u,x) for u=3.
K2:=proc(g)
local pde, ic,ans;
ans:-plot([diff(f(u,x),x,u),color=cyan],u=3)
K2(1+x^2-2*x^3);
That does not work.
I try to introduce a new variable h(u,x) = diff(f(u,x),x) so that I can plot h(u,x).
K3:=proc(g)
local pde, ic,ans;
pde:={h(u,x)=diff(f(u,x),x),
-4*x*diff(h(u,x),u)+4*diff(f(u,x),u)=x^4*diff(h(u,x),x)+x^3*h(u,x)+8*x^2*f(u,x)*(1-f(u,x)^2)};
ic:={f(u,0) = 1,f(u,1) = 0,f(0,x)=g};
ans:-plot(h(u,x),u=3)
K3(1-x^2);
Error, (in pdsolve/numeric/par_hyp) Incorrect number of initial conditions, expected 2, got 1
I have no idea what Maple is referring to; there are 3 initial conditions, not 1 or 2.
Anybody know what is going on? Any idea how to get what I need?
One more comment. I have never knowingly used a module in all the years I have been using and teaching Maple. I am sure there are good reasons for the construct but I think it would be difficult to teach. For ode's the result of dsolve is a procedure and it is relatively easy to teach because procedures are the bread and butter of using Maple. Why does pdsolve return a module?  I spent a good deal of time figuring out the use of pdsolve and would not like to force my students to do the same. I get them up to speed solving ode's using dsolve and DETools in a one hour lab. I wonder how much time it would take to do pdsolve.
Hello there,
Would you allow me to a question regarding the correct way of using 'alias?
In the attached worksheet, an alias is defined, then a. the defined alias is not working (please have a look at the line with the same comment), b. the alias works in the other way around (please have a look at the line with the corresponding comment, Alias is working backward). When I tried to substitute the function with the 'subs' command (please have a look at the expression 'Desired'), then I was able to get the result, expected from alias command.
Perhaps, I am confused with how the 'alias' command works. I would appreciate it if the correct way is explained.
Thank you,
In Kwon Park
Maple Worksheet - Error
Failed to load the worksheet /maplenet/convert/Q20210724.mw .
Download Q20210724.mw
I am presently carrying out some computation of which I intend to solve some equations and get the preceeding values. But it would appear that my maple software just keeps showing evaluating without actually producing any results for hours even days. Is this due to my low laptop specs?
I would love if the community can take a look at the code, and possibly run it to see if it's ok. I have attached the code for reference.
test.mw
    here a problem when i solve equations.i guess solve lost a root.how can i do.
An_unexpected_solve_bug_.pdf
Download An_unexpected_solve_bug_.mw
I'm having an issue with MacOS Big Sur 11.4 recognizing a package from saved documents. The package works great from new documents!
Specifically:
I've followed the instructions on
https://www.maplesoft.com/support/help/Maple/view.aspx?path=worksheet/reference/initialization
to add  a .mapleinit
file to my user home directory under MacOS Big Sur 11.4
The .mapleinit file has code as follows to run the VLA package:
VLAlibpath := "/VLA/library/":
libname := `VLAlibpath`, libname:
and I have the VLA package files with the library inside of it in my home directory too.
When I open a new Maple document and run and use the package, it works just fine!
The problem though is that if I save the Maple file and reopen it, it will no longer recognizes the package. I get:
Error, invalid input: with expects its 1st argument, pname, to be of type {`module`, package}, but received VLA
It is very odd since the file still recognizes the libname just fine:
libname;   "VLA/library/", "/Library/Frameworks/Maple.framework/Versions/2021/lib"
The workaround is to copy and paste into a new document and start a fresh but that is obviously not ideal.
Any ideas? It is a really really old package, but great for visualization.
Sarah
Hi! Do you know how to compute this point of intersection? I thought that would be points given from
solve(f(t)=g(t),t)
but it's not true. I don't want to calculate this numerically because I think it should be seen from formula but ofc I can be wrong.
I'll give the code below:
f := t -> exp(t) + exp(-t^2 - 2*t);
g := t -> exp(-t^2) + exp(-t^2 - 2*t);
display(plot([f(t), g(t), t = -3 .. 3], discont = true, color = red), pointplot([[2, 2], [exp(-1) + exp(1), exp(-1) + exp(1)]], color = blue, symbol = solidcircle), view = [0 .. 6, 0 .. 4], plot([2, t, t = 0 .. 4]));
I am currently working on structural dynamics problem where I'am trying to obtain the dynamic response of a high-rise building.
To do so I am working in the frequency domain where I was able to find my solution and now I want to obtain the solution in the real time domain by using the inverse fourier function.
Now the problem comes when applying the inverse fourier transform. The expression which I am trying to tarnsform is extremely long and so Maple requires a lot of time. I tried to run it but after half a day it would still be evaluating. Would there be a way to speed up this process? I attached the worksheet if you're interested.
Thanks in advance :)
nieuw.mw
I have a system of PDEs from Mathematica as a list of equations stored in a text file. I would like to bring it to Maple to solve it. I know how to use , however, I want to import or read the file without displaying its content (being too big), and assign it to a Maple variable. Is there a way of doing it on Maple.
It seems that DrawGraph cannot display the weights of more than 45 arcs of a directed graphs (the arcs themselves are keeping to be displayed correctly).
Maybe a version issue?
WeightedGraphs.mw
I would like to matrixplot consecutive powers of a matrix. As the name of the matrix is not always the same I wrote a simple "embedded" procedure WM to do this.
This produre works well when called directly, but I don't understand how to make it work when called from animate
WM := P -> n -> plots:-matrixplot(P^n, heights=histogram):
U := Matrix(2$2, [0.8, 0.2, 0.4, 0.6]);
WM(U)(1);  #ok whatever the value of the argument of W(U)
plots:-animate(WM(U), [n], n=1..2);  # produces an error
# even this simpler command doesn't work
plots:-animate(plots:-matrixplot, [U^n], n=1..2)  # same error as above
Can you help me to fix this?
TIA
PS: I firstly defined WM this way
WM := proc(P, n)  plots:-matrixplot(P^n, heights=histogram) end proc:
but I met difficulties to tell animate that only n was the parameter to change
I am using Maple in Document mode and I want to print my worksheet. Is there a possibility to show the page margins as an overlay so that I can adjust the lines of my worksheet in order to avoid automatic breaks making the print difficult to read?
This worksheet produces a very strange error.
I have examined every assignment and cannot find one which relates to the error message.
Can anyone help here?
Strange_Error.mw
First 418 419 420 421 422 423 424 Last Page 420 of 2458
