I knowI can use a loop but I would like something neater. igcd can be applied to a list. Is there a way to map or use @ to apply gcd to a list?
lst:= [4, 2, 8, 4];
lst1 := [a^3/10, -a^2/2, a, a^4/4]
                      lst := [4, 2, 8, 4]
                        [1   3    1  2     1  4]
                lst1 := [-- a , - - a , a, - a ]
                        [10       2        4   ]
gd:=igcd(lst);
                            gd := 2
gd1=(gcd@op)(lst1);
Maple's Student:-ODEs:-ODESteps solves an ode by doing change of variable on the independent variable, but the resulting ode is wrong and final answer is wrong.
Here is one such example
ode:=diff(diff(y(x),x),x)*sin(x)^2 = 2*y(x);
Student:-ODEs:-ODESteps(ode):
But this result is wrong. First of all, we can not have both x and t  in the same ode. This is what dchange gives
ode:=diff(y(x),x$2)*sin(x)^2-2*y(x)=0;
tr:={PDEtools:-Solve(t=ln(x),x)};
simplify(PDEtools:-dchange(tr,ode,[t]))
It looks like Student:-ODEs:-ODESteps is trying to solve  sin(x)^2*y'' + 2 y=0 as EULER type ode.
But Euler type ode will look like  x^2*y'' +2 y=0
It seems to have confused sin(x)^2 with x^2. This change of variable it used only works for EULER type ode with polynomial coefficient, not trig coefficients.
Maple 2024.2 on Windows 10
Let x be some name:
x := asdf;
asdf
I wish to make a new name, y, whose value is the first character in x:
convert(x, string):
y := convert(%[1], name);
a
That works but seems too convoluted.  Is there a better way of doing that?
i already use this method for a lot of equation but this time something not normal hapening what is problem?
with(PDEtools)
with(LinearAlgebra)
with(Physics)
with(SolveTools)
eq0 := -4*alpha*k^2*m^2*n^2*A[0]^2+4*beta*k*m*n^2*A[0]^3-4*gamma*k*m*n^2*A[0]^3+4*delta^2*m*n^2*A[0]^2-4*n^2*sigma*A[0]^4-4*m*n^2*w*A[0]^2 = 0
eq1 := -8*alpha*k^2*m^2*n^2*A[0]*A[1]+12*beta*k*m*n^2*A[0]^2*A[1]-12*gamma*k*m*n^2*A[0]^2*A[1]+8*delta^2*m*n^2*A[0]*A[1]-16*n^2*sigma*A[0]^3*A[1]+2*a*alpha*m*n*A[0]*A[1]-8*m*n^2*w*A[0]*A[1] = 0
eq2 := -4*alpha*k^2*m^2*n^2*A[1]^2+12*beta*k*m*n^2*A[0]*A[1]^2-12*gamma*k*m*n^2*A[0]*A[1]^2+4*delta^2*m*n^2*A[1]^2-24*n^2*sigma*A[0]^2*A[1]^2+a*alpha*m^2*A[1]^2+3*alpha*b*m*n*A[0]*A[1]-4*m*n^2*w*A[1]^2 = 0
eq3 := 4*beta*k*m*n^2*A[1]^3-4*gamma*k*m*n^2*A[1]^3-16*n^2*sigma*A[0]*A[1]^3+alpha*b*m^2*A[1]^2+alpha*b*m*n*A[1]^2+4*alpha*c*m*n*A[0]*A[1] = 0
eq4 := -4*n^2*sigma*A[1]^4+alpha*c*m^2*A[1]^2+2*alpha*c*m*n*A[1]^2 = 0
C := solve({eq0, eq1, eq2, eq3, eq4}, {a, b, c, `__ `*A[0]})
Download problem.mw
Can someone tell me how to calculate the Christoffel symbols in spherical coordinates in Euclidean three dimensional space?
Thank you very much in advance!
I am working on my vector file and have another question:
1. How do I display any vectors in a matrix notation next to each other or above each other (like: [1;2;3])
Find attached the file:question_vector_.mw
I really appreciate any help you can provide.
At the end of this link - (2.14) and (2.15) - the problem and the solution have the same maple code, so I don't understand how to solve the problem.
https://www.maplesoft.com/support/help/Maple/view.aspx?path=isimplicitlydeclaredlocal
Is it possible to have a variable in a filename ?
as an example if I save a file by
save M, "Result(Variable).txt";
So If Variable is e.g. set to
Variable:=10;
then the filename saved should be
Result(10).txt
It is not that this a terribly difficult to work out, but I feel I am probably missing something. I need to check if a 3D point lies on a 3D line. What is a good approach here. I started of with the idea all alpha's are equal. but there are exceptions. See P3 and P4
l := `<,>`(3+2*alpha, 1+6*alpha, 4-5*alpha)
Vector[column](%id = 36893489809910741940)
P := [9, 19, -11]
[9, 19, -11]
seq(solve({l[i] = P[i]}, alpha), i = 1 .. 3)
{alpha = 3}, {alpha = 3}, {alpha = 3}
l1 := `<,>`(3+2*alpha, 1+0*alpha, 4-5*alpha)
Vector[column](%id = 36893489809910721460)
P1 := [9, 1, -11]
[9, 1, -11]
seq(solve({l1[i] = P1[i]}, alpha), i = 1 .. 3)
{alpha = 3}, {alpha = alpha}, {alpha = 3}
l2 := `<,>`(3+2*alpha, 1+0*alpha, 4-0*alpha)
Vector[column](%id = 36893489809910705556)
P2 := [9, 1, 4]
[9, 1, 4]
seq(solve({l2[i] = P2[i]}, alpha), i = 1 .. 3)
{alpha = 3}, {alpha = alpha}, {alpha = alpha}
l3 := `<,>`(3+2*alpha, 0+0*alpha, 4-0*alpha)
Vector[column](%id = 36893489809963852012)
P3 := [9, 0, 4]
[9, 0, 4]
seq(solve({l3[i] = P3[i]}, alpha), i = 1 .. 3)
P4 := [9, 0, -2]
[9, 0, -2]
seq(solve({l3[i] = P4[i]}, alpha), i = 1 .. 3)
(14)
Download 2024-12-21_Q_3D_point_lies_on_3D_line.mw
I don't know what that line above the question is. Thanks in Advance.
I'm quite new to Maple Flow and I really like it. However, since the 2024.2 update, Flow sometimes does not let me save a worksheet. Just nothing happens when I click Save or Save As or press Ctrl+S. Same thing when I click "Yes" in the dialogue (which asks me if I want to save the changes) after I close the worksheet.
As a workaround in these cases, I copy the whole content of the worksheet, close Flow altogether and open a new worksheet into which I paste the previously copied contents. Am I the only one experiencing this behaviour? Am I doing something wrong?
NULLComplex Numbers
Key Skills 11-48
NULLc11 := 2-3*i+(6+8*i)"(=)"8+5*i
c12 := 4+5*i-8+2*i"(=)"-4+7*i
c13 := -3+2*i-4+4*i"(=)"-7+6*i
c14 := 3-4*i+(3+4*i) = 6NULL
c15 := 2-5*i-8-6*i"(=)"-6-11*i
c16 := -8+4*i-2+2*i"(=)"-10+6*i
c17 := 3*(2-6*i)"(=)"6-18*i
c18 := -4*(2+8*i)"(=)"-8-32*i
NULLc19 := 2*i(2-3*i) = 2*i(2-3*i)NULL
c20 := 3*i*(-3+4*i) = 3*i*(-3+4*i)
c21 := (3-4*i)*(2+i) = (3-4*i)*(2+i)NULL
c22 := (5+3*i)*(2-i) = (5+3*i)*(2-i)
Download 1.3-Complex_Numbers_bad.mw
I'm trying to get my problems in standard form  a + bi . Questions 19 - 22 are wrong.
How can I display the symbol (blue solid circle) and the line (blue line) together in the legend box (( from   to ))?
plot(sin(x), x = -3 .. 3, colour = [blue], style = pointline, symbol = [solidcircle], numpoints = 20, legend = ["sin(x)"])
Download Plot1.mw
As a Maple beginner, I am now interested in symbolic calculations in Maple. As before, I set a problem from a subject area that interests me in order to learn from professional answers.
Determine all regular square (n;n) matrices (determinant not equal to zero) that are commutable with every regular (n;n) matrix with respect to matrix multiplication.
(I know the solution from long ago.)
Example code
printlevel :=1
for indx1 from 1 by 1 to  3  do
f[indx1] :=indx1;
This prints
f1:=1
f2:=2
f3:=3
How do I use the "save" command to save exactly the loop's results above to a file so that I can read the file later and execute it in another  maple worksheet.
The maple manual https://www.maplesoft.com/support/help/Maple/view.aspx?
for "save"   contains no examples, and definately not how to save results of a loop using the save command. e.g. how do you append  with a file using the "save" command ?
Note: I dont need any help with reading the results, from the saved file, my question is only about writing the results with "save" command. The "save" command gives me the best results for reading files back into a speadsheet, and text file save routines just gives me ascii garbage and not the exact results in executable maple format as "save" does, saving exacltly what you see on screen. Therefore text save routines are useless to me.
First 44 45 46 47 48 49 50 Last Page 46 of 2425
