In some coordinate systems availiable in the plot command, there are constants specified symbollically, for example,for logarithmic, the constant "a" is specified (see ?coords help page) is there a simple way to retreve the numerical value for these transformation parameters, or does it need to be obtained by appropriate manipulation of the data set?
how can I obtain the corresponding polynomial for a  propositional formula ?
I must say that using the help for this package is not intuiative. ( in general for all )
Once on a page for command i can't  go back to the home page where the mainpage is for the package
Example i was doing something with gradient command and try figure out how to make a function out of it
At the examples nothing to find about this .. via contectpanel : evalVF (evaluate vectorfield)
So i want to look at the eval command in the student vectorcalculus package
This could be easy if there was a button to see all commands ( a home button) on the gradient page
Now i must type in help again ..
evalVF gives a column vector notation , but mixing both notations ? ( as vector , as column vector)
gf := Gradient(exp(x*y^3*z^2))
This i can evaluate via contectpanel for  f(x,y,z)  in a point and as output a colomn vector
Making a vectorfunction for gf is not possible via contectpanel ? , or do i miss something
Note: perhaps showing the package commands in the working document is a idea
buy := proc(ss,windowlength,syseq1,syseq2a,syseq2b)
try:
p := dualaxisplot(listplot(ma, color = red), listplot(me, color = blue), style = line, gridlines = false);
catch:
p := dualaxisplot(listplot(me, color = red), listplot(me, color = blue), style = line, gridlines = false);
end try:
return p:
CheckGraph := proc(text,graphparam1,graphparam2)
  local maplet, choice:
  maplet := Maplet(
      [Plotter['PL1'](graphparam1)],
      [Plotter['PL2'](graphparam2)],
      #[Plotter['PL2'](graphparam2)],
      [text, ComboBox['CoB1']("No Refund", sort(["Jackpot"], lexorder))],
      [Button("OK", Shutdown(['CoB1'])), Button("Cancel", Shutdown())]
  choice := Maplets[Display](maplet):
graph1 := buy(0,100,rhs(sol[parse(result1[1])][1]),rhs(sol[1][1]),rhs(sol[2][1]));
>graph1
can show graph but after using Plotter['PL1'] , it can not show graph in dialog
CheckGraph("Has Jackpot?",graph1,graph2):
how to plot dualaxisplot in dialog?
I would like to factor an algebraic expression that contains exponentials.
Maple spits it back unfactored. Did I enter it wrong?
factor(exp(4*y) + 2*exp(2*y) + 1);
Good afternoon everybody,
I am a beginer user in maple and I am having problems to plot a system of differential equations. My code is
restart; with(VectorCalculus); with(LinearAlgebra); with(DEtools);
> p := 2*u*x*y^2; q := (x-1)/x;
> doth := simplify(-(sqrt(6)*x^3*(y-1)^2+u*((3+sqrt(6))*x^3*(y-1)^2+3*y^2-9*x*y^2+3*x^2*(y^2+2*y-1)))/p); ddotphi := simplify((y-1)*(sqrt(6)*x*y^2*(x-1)+u*(3*y^2-(6+sqrt(6))*x*y^2+x^2*((3+sqrt(6))*y^2+6*y-3)))/p);
>ode1 := diff(x(t), t) = x(t)*(1-x(t))*doth-x(t)^2*ddotphi/sqrt(6); ode2 := diff(y(t), t) = y(t)*(y(t)-1)*doth; ode3 := diff(u(t), t) = sqrt(3/2)*u(t)*(1+u(t))*q;
>DEplot3d([ode1, ode2, ode3], [x(t), y(t), u(t)], t = -2 .. 2, x = 0 .. 1, y = 0 .. 1, u = -1 .. 0, [[x(0) = .9, y(0) = .25, u(0) = -.95], [x(0) = .9, y(0) = .25, u(0) = -.5], [x(0) = .85, y(0) = .2, u(0) = -.15], [x(0) = .25, y(0) = .5, u(0) = -.5], [x(0) = .7, y(0) = .5, u(0) = -.6]], linecolor = [red, green, black, navy, maroon], thickness = 2, axes = boxed, labels = [x(t), y(t), u(t)], arrows = medium, stepsize = 0.1e-1, orientation = [30, 65]);
and the next error appears
Error, (in DEtools/DEplot/direction3d) unable to store 'HFloat(HFloat(undefined))+HFloat(HFloat(undefined))*I' when datatype=float[8]
I have no idea what to do, and searching for solutions I have only found things that I dont understand.
Thank you very much in advance
I want the legend to be produced to look like the third to last example. https://fr.maplesoft.com/support/help/Maple/view.aspx?path=plots/contourplot
However, mine keeps coming out like this.
hello how do i solve these equations and what type exactly are they ? so i can find more information
(i dont understand if this is a partial-something)
for the following function
f(y,z)=y*sin(z) + 2*cos(y)
i need to evaluate it at the following point
fy(pi/2,pi)  and  fz(pi/2,pi)
this is the part i dont understand how to do, i keep getting 0 in the equation.
thanks for you! and your time
I would like to "run" or execute parts of my code that I put in a same section. Unfortunately, selecting "Execute" when right-clicking on a section does nothing...
For entering system of linear ode's, from textbook, such as this example
I can either use x[1],x[2]  or x__1 and x__2.
Maple dsolve works with both. The Latex generated is also exactly the same Which is x_{1} and x_{2}.
The only minor difference I see is on the screen in the worksheet (I only use 1D), where the subscript looks a little nicer in the case of x[1] vs. x__1
The subscript in the case of x[1] is upright while the one in x__1 is italic. I like the first one more.
Other than this cosmetic difference, Are there are subtle sematic differences between the two forms in terms of computation? I know x[1] create table x. OK.  While x__1 is a separate symbol. No table is created.,
Which would be  a safer/better option to use in this case?   Or is it just a matter of choice?
sys:=[ diff(x[1](t),t)=x[1](t)+x[2](t),diff(x[2](t),t)=x[1](t)+3*x[2](t)];
sys:=[ diff(x__1(t),t)=x__1(t)+x__2(t),diff(x__2(t),t)=x__1(t)+3*x__2(t)];
In some way, using x__1(t) might be a little easier to read on the eye than x[1](t) since there is only one type of paranthesis involved.
ps. I tried to search for __ in Maple help to read more about it, but ?__ do not show it. I am sure __ is in the help under some other name.
How do I insert an empty or null value into a matrix imported from a csv file?  The imported data assumes the value is zero.
For display only purposes, to get the Latex looking better, I replace the constant of integrations Maple using which is _C1, _C2., etc... to c[1],c[2],.....
This is something I do at the very end of computation, just before I get the Latex of the expression.
The way I do this now, is not good. .And I am asking if there is a better way to do this replacement. In Mathematica, I can do this using a patterm where I tell it to replace  C?  by c[?] where ? means anything.
Is it possible to do something like this in Maple? Here is an example
sol:=dsolve(diff(x(t),t$3) = x(t));
This gives solution as
And just before ask for the Latex of this, I change it to
This is done using a function. Please see worksheet below.
The problem with the current solution is that I do not know how many _C there are, so I assumed 10 as worst case, which works for my case. But I prefer a more general solution, may be using pattern in the subs command?
replace_all_C:=proc(expr::anything)
local n,N,c;
local new_expr;
local max_count :=10; #worst case, since do not know how many
    new_expr:=expr;
    for n from 1 to max_count do
        N:=convert(n,string);
        new_expr:=subs( :-parse(cat("_C",N))=:-parse(cat("c[",N,"]")),new_expr);
    return new_expr;
tmp:=replace_all_C(sol)
x(t) = _C1*exp(t)+_C2*exp(-(1/2)*t)*sin((1/2)*3^(1/2)*t)+_C3*exp(-(1/2)*t)*cos((1/2)*3^(1/2)*t)
x(t) = c[1]*exp(t)+c[2]*exp(-(1/2)*t)*sin((1/2)*3^(1/2)*t)+c[3]*exp(-(1/2)*t)*cos((1/2)*3^(1/2)*t)
Download q.mw
And now I get the latex of tmp in the above, instead of sol which looks better.
Can anyone help with plotting the logistic map as a function in Maple
Logistic map x_(n+1)=f(x_n); f(x_n)=r*X(1-x) with the following values:
r=2.0; x(1)=0.3 f=r.*x.*(1-x)
Please help? Thanks.
I created some simple maple 9 code to do some z->w mappings long time ago, on my web page:
https://ingalidakis.com/math/ComplexMaps.html
Upon revising my webpage, I've stumbled upon a page for comformal mappings, by David Bau:
http://davidbau.com/conformal/#exp(z)
Here's the current version of my code in Maple 18:
rrestart;
NULL;
xMax := 1;
yMax := 1;
N := 10;
step := abs(xMax)/N;
GL := proc (x, y) options operator, arrow; x+I*y end proc;
f := sin;
G := {};
for k from -N+1 to N+1 do
G := `union`(G, {complexplot(f(GL(x, (k-1)*step)), x = -xMax .. xMax, color = brown)});
G := `union`(G, {complexplot(f(GL((k-1)*step, y)), y = -yMax .. yMax, color = brown)})
display(G, scaling = constrained);
The code is pretty simple: I am simply scanning the 1x1 unit square complex grid and create a complex plot of it on the w-plane, by passing it through whatever function is at: f:=x.
Does anyone have any idea why the grid lines on the w-plane do not agree with Bau's grid lines mapping of the w-plane? To try it for exp for example, input "exp(z)" in Bau's home page.
The difference is quite noticeable, especially on exp and log, where the orientation of the w-grid on the left and right half-planes, seem to be opposite of what my code displays.
The reason may be Mathematical, but from what I see from the description on Bau's page, there's no difference on the identity function, so I am clueless.
Many thanks in advance
Any idea why the result of the FirstChild function of the attached file is
_XML_Text("\n  ")
Test.zip
I also miss a more complete example on Maple Help for writing, reading and processing xml files.
First 501 502 503 504 505 506 507 Last Page 503 of 2428
