On the website "Learning Physics using Maple" of professor Gould, in the example "Vectors: Calculation & Visualization". If you click on the PDF file under that title, you see an example of vectors in 2d.
But when you look at the solution, you see him use the vector v with an arrow to create a fucntional depending of two variables. Since he doesn't load any package, I cannot reproduce this notation to work. I am talking about this:
Is there a trick that I am not aware of in Maple?  The only way I know to have the arrow is to load the Physics package and the Vector package. And then you use the notation r_ to show r with an arrow.
I asked the question in the YouTube channel but did not receive any answer.  Too bad.
Thank you in advance for any help on that matter.
Hello everyone.
Please tell me how to take this integral.
int(1/((a^2 + x)^(3/2)*x), x = 0 .. infinity)
Assuming that a is greater than zero and real. Thanks in advance
Maple defaults to expressing output in terms of Cosines.
Is it possible to instruct maple to rather calculate the output  with Sine as the default ?
 hello
 how to get curve fitting parameters right?  is that any stragey to get a good estimate.
with(Statistics):with(plots):with(Optimization):with(LinearAlgebra):
# given data from strain rate curve
E_0[theta] := 7.883352314*10^9;
alpha[theta]:= 0.982
7883352314.
.982
# experimental creep data under 44 at 100 degree celcius
c_strain := Vector ([<<0>,<0.0284698>,<0.0533808>,<0.0782918>,<0.0996441>,<0.124555>,<0.142349>,<0.156584>,<0.16726>,<0.177936>,<0.181495>,<0.188612>,<0.192171>,<0.19573>,<0.19573>,<0.202847>,<0.206406>,<0.206406>,<0.209964>,<0.209964>,<0.209964>,<0.206406>,<0.209964>>]):
c_time := Vector ([<<0>,<0>,<0.048>,<0.192>,<0.352>,<0.544>,<0.704>,<0.896>,<1.088>,<1.312>,<1.52>,<1.76>,<1.984>,<2.208>,<2.464>,<2.736>,<3.088>,<3.392>,<3.664>,<4.016>,<4.352>,<4.592>,<4.832>>]):
sigma[0] := 44*10^6;
epsilon[0] := sigma[0]/E_0[theta];
44000000
0.5581381911e-2
# change vector to list
c_strain := convert(c_strain,list):
c_time := convert(c_time,list):
# extract zero from list
c_strain := c_strain [2..-1];
c_time := c_time [2..-1];
[0.284698e-1, 0.533808e-1, 0.782918e-1, 0.996441e-1, .124555, .142349, .156584, .16726, .177936, .181495, .188612, .192171, .19573, .19573, .202847, .206406, .206406, .209964, .209964, .209964, .206406, .209964]
[0, 0.48e-1, .192, .352, .544, .704, .896, 1.088, 1.312, 1.52, 1.76, 1.984, 2.208, 2.464, 2.736, 3.088, 3.392, 3.664, 4.016, 4.352, 4.592, 4.832]
# for further calculation need to know how many elements are in the list
M := nops(c_strain);
N := nops(c_time);
22
22
# constitutive equation
creep_strain := proc(t)
local i;
options operator, arrow;
epsilon[0]*(1 + alpha[theta]*add(-(B[i]*(-beta[i]*t + exp(-beta[i] *t) -1))/beta[i],i=1..3))
proc (t) local i; options operator, arrow; epsilon[0]*(1+alpha[theta]*add(-B[i]*(-beta[i]*t+exp(-beta[i]*t)-1)/beta[i], i = 1 .. 3)) end proc
#define objective function
Digits := 9:
obj := add(
           creep_strain(c_time[j])
           c_strain[j]
         )^2
         , j=1..N
# curve fitting
opt := NLPSolve(obj,
  beta[1] >= 0,
    beta[2] >= 0,
    beta[3] >= 0,
    B[1] >= 0, B[1]<= 0.2,
    B[2] >= 0, B[2] <= 0.3,
    B[3] >= 0, B[3] <= 0.4
[.467521159408790410, [B[1] = HFloat(0.19999999999999996), B[2] = HFloat(0.30000000000000004), B[3] = HFloat(0.4), beta[1] = HFloat(1.2600715880722035e-9), beta[2] = HFloat(5.152129055134073e-9), beta[3] = HFloat(5.057870561183067e-9)]]
# plot the result
display(
   ScatterPlot(c_time, c_strain, symbol=circle, color=blue),
  plot(eval(creep_strain(t), opt[2]), t=0.00..max(c_time), color=black)
Download at_44_Mpa_at_100C.mw
Why do maple not contract over inert differentials ?
The last command just return the defining equation and refuses to contract.
See example below
with(Physics);
g_[[5, 29, 1]];
eq1 := g_[~mu, ~nu]*Diff(w(r, theta), mu)*Diff(w(r, theta), nu);
SumOverRepeatedIndices(eq1);
However Check return empty coordinates, which is completely contradictory.
Check(eq1, all);
      The repeated indices per term are: ((...),(...),...)
        , the free indices are: (...)
                    [{}], {~mu, ~nu}
I was not expecting odesteps to show steps for this ode, but crash the server each and everytime?
Anyone could find why? I am using Maple 2024.2 on windows 10 with latest Physics. This might indicate serious problem somewhere. Software should not really crash this easily.
`The "Physics Updates" version in the MapleCloud is 1827 and is the same as the version installed in this computer, created 2024, November 13, 9:16 hours Pacific Time.`
libname;
ode:=5*(1+t^2)*diff(y(t),t)=4*t*y(t)*(y(t)^3-1);
5*(t^2+1)*(diff(y(t), t)) = 4*t*y(t)*(y(t)^3-1)
dsolve(ode);
y(t) = 1/((t^2+1)^(6/5)*c__1+1)^(1/3), y(t) = -(1/2)/((t^2+1)^(6/5)*c__1+1)^(1/3)-((1/2)*I)*3^(1/2)/((t^2+1)^(6/5)*c__1+1)^(1/3), y(t) = -(1/2)/((t^2+1)^(6/5)*c__1+1)^(1/3)+((1/2)*I)*3^(1/2)/((t^2+1)^(6/5)*c__1+1)^(1/3)
Student:-ODEs:-ODESteps(ode);
Download crash_server_nov_18_2024.mw
here is small movie
For a system of 8 equations, it takes too long for me to solve it by using solve, but I can only give one solution by using fsolve. If I want solutions in other ranges, I need to provide a general range, but I don't know the range, how can I quickly find all the solutions?question1118.mw
eqs := [a = b, c = d, e = f]:
map(`+`, eqs, 2);
map(`-`, eqs, 2);
map(`/`, eqs, 2);
         [a + 2 = b + 2, c + 2 = d + 2, e + 2 = f + 2]
         [a - 2 = b - 2, c - 2 = d - 2, e - 2 = f - 2]
               [1     1    1     1    1     1  ]
               [- a = - b, - c = - d, - e = - f]
               [2     2    2     2    2     2  ]
These work differently
map(`*`, eqs, 2);
map(`^`, eqs, 2);
               [2 (a = b), 2 (c = d), 2 (e = f)]
Error, non-algebraic base in a power: a = b
(The first one can be dealt with by applying eval to the output)
Why do not all work the same way?
Edit:
Generic work arounds where arithop is one of: + - / * ^
map(eval@`arithop`, eqs, 2);
map(map@`arithop`, eqs, 2);# Update: Maple 2021 and higher
[seq(i arithop 2, i in eqs)];
Hi, the below code is the equation of a standard ellipse intersects the line at two points, (x1,y1) and (x2,y2).
I wanna "y1+y2" and "y1*y2" generate by specific code auto, no need to input "k*x1_plus_x2 + 2*b" and "b*k*x1_plus_x2 + k^2*x1_by_x2 + b^2" manually. But I don't know how to edit it? maybe sequence?
Any answer and reply is welcome.
The below code is the equation of a standard ellipse intersects the line at two points, (x1,y1) and (x2,y2).
C := x^2/A^2+y^2/B^2-1
x^2/A^2+y^2/B^2-1
l := y = k*x+b
y = k*x+b
subs(l, C)
x^2/A^2+(k*x+b)^2/B^2-1
eq := collect(%, {x, x^2})
(1/A^2+k^2/B^2)*x^2+2*b*k*x/B^2+b^2/B^2-1
x1_plus_x2 := simplify(-coeff(eq, x)/coeff(eq, x^2))
-2*b*k*A^2/(A^2*k^2+B^2)
x1_by_x2 := simplify(coeff(eq, x, 0)/coeff(eq, x^2))
(-B^2+b^2)*A^2/(A^2*k^2+B^2)
x1 := solve(eq = 0, x)[1]; x2 := solve(eq = 0, x)[2]
-(b*k*A-(A^2*B^2*k^2+B^4-B^2*b^2)^(1/2))*A/(A^2*k^2+B^2)
-(b*k*A+(A^2*B^2*k^2+B^4-B^2*b^2)^(1/2))*A/(A^2*k^2+B^2)
subs(x1, l); subs(x2, l)
I don't know how to make it like y1=k*x1+b and y2=k*x2+b auto in this procedure.
Error, invalid input: subs received -(b*k*A-(A^2*B^2*k^2+B^4-B^2*b^2)^(1/2))/(A^2*k^2+B^2)*A, which is not valid for its 1st argument
Error, invalid input: subs received -(b*k*A+(A^2*B^2*k^2+B^4-B^2*b^2)^(1/2))/(A^2*k^2+B^2)*A, which is not valid for its 1st argument
y1_plus_y2 := simplify(k*x1_plus_x2+2*b)
2*b*B^2/(A^2*k^2+B^2)
y1_by_y2 := simplify(b*k*x1_plus_x2+k^2*x1_by_x2+b^2)
B^2*(-A^2*k^2+b^2)/(A^2*k^2+B^2)
Download ask_ellispe_and_straight_line.mw
I needed to plot a function, using  plot in Maple.
plot(sin(x)*sqrt(1 - (sin(x)/x)^2), x = 0 .. Pi/4)
The graph shown by Maple seems to be identically 0 from x=0 up to some x*. At this point it jumps and for x>x* it looks fine. Of course the function has a singularity at x=0, but even changing the left end of plotting range to something small but positive does not alleviate the problem. Another strange thing is that x* seems to depend on the (end point of) the plotting range.
hello,
I've been playing around a bit with mapel in the 14 day trial version and now I have a few questions
how can I set mapel so that results are always shown to me in SI format and the engineering representation and the results are automatically approximated, e.g. pi is calculated with 3.14...?
The configuration appears in the margin for individual solutions, but how do I set this globally so that I don't have to set it individually each time?
I also have to manually set the format of an input to input so that I can access the result when solving.
is there a reset button that is hidden so that I can go back to the basic settings? I must have changed something.
I hope you can help me
thanks for the help and sorry for my nob question, im reele new in Cas or other software like this
If it is the wrong tags or generally wrong here, please delete or move Thanks
Arthur
inte_eq := int(-(sum(B[i]*beta[i]* exp(-beta[i] * (t-tau)),i=1..n)),tau=0..t);
int(-(sum(B[i]*beta[i]*exp(-beta[i]*(t-tau)), i = 1 .. n)), tau = 0 .. t)
how to solve this ?
Download creep_integral_sol.mw
I experience Maple 2024 not beeing responsive.
It happens often that nothing is happening for 10 to 15 seconds after placing the cursor in an input line.
When the cursor is back, typing is normal for a little while and then again Maple is not reacting to user input.
The worksheets I am working with are between 50 and 100 Mb large in file size (containing plot3d structures, approx 1000 frames distributed across several plots:-display statements). It looks to me that the GUI has to do some house keeping from time to time which keeps it buisy with all the plot structures.
I could delete (plot) output, but this would require execution of the worksheet (before deleting the output) each time I want to continue working normally. This takes several minutes to be ready to work.
Anything else that I can do?
I am learning patten matching in Maple.
Any one could explain why patmatch(1, (x::anything)^(n::'nonunit'(anything)))   gives true but patmatch(2, (x::anything)^n::'nonunit'(anything)); gives false?
Download patmatch_question_nov_16_2024.mw
I was expecting result similar to using this other software
I do not understand Maple's result. How could I change the patmatch so it does not match 1 to the pattern x::anything^n::anything where n is not 1 ?
Update
To give context, I was trying to write this example from the other software  in Maple:
But when I wrote this
expr:=1 + x^2 + x^4;
F:=proc(X::anything,x::symbol)
    local la,y,n;
    if patmatch(X, (y::anything)^(n::'nonunit'(anything)) ,'la') then
       f(eval(n,la));
        X;
     fi;
map(X->F(X,x), expr);
Maple gave
So I modified the code now to check for explicit 1,  to avoid this bad match, like this
    local la,y,n;
        if eval(y,la)=1 then #bug in maple?
           X;
           f(eval(n,la));
        fi;
        X;
     fi;
And now it gives expected result
Hi all
I would like your help to represent the states of the ODE according to the parameter "a" for t=0..10 and a=0..5.
I can do this for a value of t=200.
enfonction_p_2_cas1.mw
First 53 54 55 56 57 58 59 Last Page 55 of 2425
