I am reading a paper which has some useful two-dimensional Fourier transforms in the appendix: for example,
Fourier transform of 1/r = (1/k)*e^(-kz),
where r = sqrt(x^2 + y^2 + z^2) and k =  sqrt(k_1^2 + k_2^2).
My guess is that the author has computed these by taking contour integrals in the upper half-plane and I would like to compute some of these myself but I have many of them to compute and was wondering if it could be done with Maple instead.
For example, could I use Maple to verify that the above 2D Fourier transform is correct and that the inverse 2D Fourier transform takes you back to the original (or almost takes you back).  After that I would then like to feed in the functions which I have to get Fourer and inverse Fourier transforms.
This may be a total newbie question, but is there a way to split an equation and save the right hand side? For example, have a look on what happens without split:
numer(L = 2/3);
"Error, invalid input: numer expects its 1st argument, x, to be of type {list, set, algebraic}, but received L = 2/3"
I thought that "convert"-function might be able to do this, but for example this does not work:
convert(L = 2/3, algebraic)
"Error, invalid input: `convert/algebraic` expects its 1st argument, pr, to be of type procedure, but received L = 2/3"
Please understand that this is a simplified example. The real problem looks like
sol := solve({eq1, eq2,eq3, res}, {L, x1, x2, x3})
The point here is how to convert the sol[1], which is L = numerator/denumerator into --> numerator/denumerator
Taking a copy of the equation works, but this is only an intermediate result, so if the split does not work automatically, Maple cannot compute the problem to the end without human intervention, and since this problem takes a long time to solve, it would be nice if I could just leave Maple to finish the task by itself.
How would I compute the series expansion of cos(x)^n at the point x=0?
combine(2^n*4, icombine);
2^(2+n)
combine(2^n*4);
4*2^n
combine(2^n/4, icombine); # BUG
Error, (in compat) invalid input: igcd received undefined, which is not valid for its 2nd argument
combine(2^n/4);
(1/4)*2^n
combine(2^n/2^m, icombine); # BUG
combine(2^n*2^(-m), icombine);
2^(n-m)
combine(2^n/2^m);
2^(n-m)
is(2^n/4 = 2^(n-2)); # ???
Download bug-icombine-is.mw
Hi everyone, I'm having issues using Maple through the command line (I have reasons to be avoiding the GUI, namely I am trying to use Maple in a development environment that integrates other programs, e.g. Mathematica into the mix. This forces me to only be able to access Maple via the command line).
Here is my issue: for some functions, like diff(), which differentiates functions, Maple evaluates the function on the input:
> f:=x+2;
                    f := x + 2
> g := diff(f, x);
                      g := 1
For other functions though, such as SPolynomial() (from the Ore_algebra library), command-line Maple is lazy and just spits back the input:
> with(Ore_algebra)
> A:=diff_algebra([D1, x1], [D2, x2]);
A := diff_algebra([D1, x1], [D2, x2])
> T:=MonomialOrder(A, grlex(D1, D2));
T := MonomialOrder(diff_algebra([D1, x1], [D2, x2]), grlex(D1, D2))
> L1:=D1;
                     L1 := D1
> L2:=D2;
                     L2 := D2
> L:=SPolynomial(L1, L2, T);
L := SPolynomial(D1, D2, MonomialOrder(diff_algebra([D1, x1], [D2, x2]), grlex(D1, D2)))
Let me know if you get the same error as well! The correct output (outputted by the worksheet version of Maple) should be:
L := 0
Let's take the last example (Maple 2019) given in help[sparsematrixplot] (representation of the adjacency matrix of a graph).
Vertices of this graph are labelled 1, 2, ...20.
Suppose I change these names as a, b, ...t.
I would like the tickmarks of the sparsematrixplot output match the names of the vertices of the graph, and not the integers 1, 2, ..20
I tried this:
S := [$1..20] =~ StringTools:-Char~(96 +~  [$1..20]);
plots:-sparsematrixplot(..., tickmarks=[S, S])
But the only the tickmars of the columns are changed, not those of the rows.
Is it possible to change the names of the tickmarks ?
How  to get step by step solutions in dsolve?
Please, what is going wrong that it is not graphing the ODE system solution?
eqs := seq(eq[i], i = 1 .. 6*n);
cis := seq(ci[i], i = 1 .. 6*n);
sol := dsolve([eqs, cis], numeric, stiff = true, output = listprocedure);
for i to n do
    graf1[i] := odeplot(sol, [t, x[i](t)], 0 .. 5, color = black);
for i from 11 to 2*n do
    graf2[i] := odeplot(sol, [t, x[i](t)], 0 .. 5, color = blue);
for i from 21 to 3*n do
    graf3[i] := odeplot(sol, [t, x[i](t)], 0 .. 5, color = green);
for i from 31 to 4*n do
    graf4[i] := odeplot(sol, [t, x[i](t)], 0 .. 5, color = red);
for i from 41 to 5*n do
    graf5[i] := odeplot(sol, [t, x[i](t)], 0 .. 5, color = pink);
for i from 51 to 6*n do
    graf6[i] := odeplot(sol, [t, x[i](t)], 0 .. 5, color = orange);
display(seq(graf1[i], i = 1 .. n));
display(seq(graf2[i], i = 11 .. 2*n));
display(seq(graf3[i], i = 21 .. 3*n));
display(seq(graf4[i], i = 31 .. 4*n));
display(seq(graf5[i], i = 41 .. 5*n));
display(seq(graf6[i], i = 51 .. 6*n));
trabalho_final_2019.mw
I had a warning solutions may be lost for the following:
with(plottools);
with(DEtools);
solve({0.5*`sinφ` + 0.5*`sin2φ` + 0.5*sin(-phi) + 0.5*sin2(-phi) - 0.5*sin(phi + psi) + 0.5*sin2(phi + psi) - 0.5*`sinψ` + 0.5*`sin2ψ`, ((-0.5*`sinφ` - 0.5*`sin2φ` + 0.5*sin(-phi - psi) + 0.5*sin2(-phi - psi)) - 0.5*`sinφ`) + (0.5*`sin2φ`)*0.5*sin(-psi) + 0.5*sin2(-psi) = 0}, {phi, psi});
Any suggestions
BIOMAT_project.mw
I am looking at an SIR model and an adapted model that has a vaccine for measles. I would like to use Maple to plot the difference between the two models.
All the work that's been done so far is in the attached file. I would like to have multiple graphs, changing the starting values but I just need the general idea of how to do this first.
I'm trying to rearrange a transfer function to get my s^2 term with other specific terms . Below is the denominator of the transfer function. I know that my goal is to get (Izz*u)/m for the s^2 term, so I divide by Df*Dr*(a+b)*u*m, as shown below.
However, if we look at the s^2 terms for now, the equation should be further simplified leaving me with simply (Izz*u)/m, but Maple doesn't want to do this for some reason, and if I use simplify on the above expression it tries to expand everything again, and forgetting about my collect(fun, s).
Is there any way to get around this?
Many thanks
I have a function g that I compute its limit at x0
but when I compute series(g(x),x=x0) then I compute the limit of the series I get different limit
series_limit.mw
Many thanks for your help
I have a piecewise equation,and two Sum (one of them is infinity and the other has upperband k). I need a numerical value for F2.
H := r->; piecewise(r < 1, 1);
XF := x-> 2;
f1 := k-> sum(XF(j)*(1-H(j)), j = 0 .. k);
F2:=sum(f1(i), i = 0 .. infinity);
This is a question more or less related to this one Is it possible to define variables with unusual na... but I think it's better to open a new thread. If some think otherwise, please feel free to displace it to the link above.
I want to relabel the vertices of a graph by using special characters.
It happens that this works perfectly if I do not impose the style of the drawing but that it doesn't if I set, for instance, spring=style.
In the attached file you will see that the subsitution of the old vertex names by the new ones doesn't work if apply it directly on the many operators of the PLOT command contains.
Is this behaviour fixed in more recent versions of Maple or it's still present?
Strange-Behaviour-with-SpringStyle.mw
Why does Maple not have texture fill for plotting. Even the old Pascal had it.
First 607 608 609 610 611 612 613 Last Page 609 of 2424
