I explore the "PracticeSheet" command of the "Basic" package, and I want to build two sheets on the Discriminant of polynomial ( send degree) and tangent to curves ( Derivative application). Do you have any ideas?
Many thanks!
DrillerConceptMaple.mwDrillerConceptMaple.mw
I am Seonhwa Kim, a mathematical researcher in Korea. Recently, I have extensively used Maple to compute character varieties of 3-manifolds. Several months ago, I obtained some strange results in Maple which implies a contradiction in theory.  I have been struggling with these issues since it is usually about enormous polynomial systems.  Eventually, I could figure out that the issues are caused by a defect in Maple and were able to construct a minimal working example to produce wrong computations in Maple.  I am writing this post to report them.
This is mainly about the PolynomialIdeal package.  Along with the documentation in Maple, If an ideal J is radical, PrimeDecomposition and PrimaryDecomposition should have the same result.  But, as we see the following, the result of PrimeDecomposition and PrimaryDecomposition are different although J is a radical ideal.
The problem seems to be that the PrimaryDecomposition command in Maple sometimes produces incorrect results.
We can compute the primary decomposition of J by hand.  It should be <x> and  <y, x-1>.
I double-checked this by the other software;Macauley2, Singular, and Magma, for example, you can see it as follows.
Secondly, not only for PrimaryDecomposition but also PrimeDecomposition may produce an incorrect result.
Here is a minimal working example.
Maple tells us a compatible result of prime and primary decomposition of a radical ideal J.
But the first component of J,  < b-1, c-a+1 >, contains the third component < a, b-1, c+1 >.
It contradicts with the definition of Primary decomposition. So the correct answer should be  < b - 1, c - a +1 >, <a,b,c>.
I also checked that  Macaluey2, Singular and Magma. They all say that my hand computation is correct. as follows.
I have used Maple 2017 by the license of my institute (Korea Institute for Advanced Study).
When I noticed these defects, I thought it would be fixed in the newest Maple version.
So, I have tried my examples by Maple2019  free trial, but It also has the same problem.
I guess this problem is not reported or recognized yet.
I hope this problem will be fixed as soon as possible.
Thank you for attention.
Sincerely,
Seonhwa
I need to add a legend to a figure using dataplot (I am not even sure that is the right option).  In what follows I show what I did.
dataplot([28,28,28],[.6481496576, .648149657615473, .6512873548],style='point',colorscheme=["Blue","Orange","Red"],
labels = ["k", "y(k)"], legend = ["10-digit precision", "15-digit precision", "Floating-point iteration"] ,legendstyle = [font = ["HELVETICA", 9], location = right]);
The outcome is
As can be seen some parts of the legend are missing.
How can I get this right? Do I have other ways to do the same thing?
Many thanks
Ed
Hi all, why maple output alway change from `> =` to `<=` ? example
How to config to `>=`. Thank you very much
I am using an integal sign using Int. If there is a minus sign in front of it, then
I get the expression -(Int ... dx). Why is the parenthesis there? Can we avoind it?
mapleatha
How to get the real and imaginary parts of this complex expression.
Thank you in advance
real_imag_parts.mw
Hello every one
I have a question!
My code starts with assuming the time variable (t) to be specified in a an interval for each time that the for loop executes as follows:
discontinuity := [0.403e-8, 0.45e-8, 0.478e-8, 0.55e-8];
 for j from 1 to 3 do
assume(discontinuity[j]<=t,t<discontinuity[j+1]);
After that the code runs and calculate every thing. For the second time, I mean for J=2, it does not work properly.
T[1] is the result of its first running (for j=1):
T[1]:=3.000023586*10^(-6)*exp(-4977.085344*t~)-1.325122648*10^(-6)*exp(-4.015800624*10^9*t~)
When it wants to evaluate this expression at specific time such as discontinuity[2] it cannot evaluate it. I tried to use unapply command to consider it as a function of t but it did not work. Here is the results:
AA:=simplify(eval(T[1], t = discontinuity[1]));
This is its result:        AA:=3.000023586*10^(-6)*exp(-4977.085344*t~)-1.325122648*10^(-6)*exp(-4.015800624*10^9*t~)
Without unapply command:    AA:=T[1]
Please answer my question.
Thank you so much
Here is the minimal situation that reveals which that could be a (little) bug in the MAPLE 2015 version of Explore.
In the attached file y is a list of numbers and val(r) a procedure that just print the value the rth element of y.
Changing the value of r is done with Explore (of course of no interest at all).
If I define the parameter r as a list ( r=[1..numelems(y)] ), only the value of y[1] is displayed: changing the value of r generates an error.
This doesn(t happen if r is defined as a slider ( r=1..numelems(r) ).
I discovered than the initial instance of Explore defines r as an integer while all the others (due to a change of r) define r as a string.
In the last command of the attached file you will see hjow I have circumvent this problem.
Is it a bug in Explore or does it exist some way to force the values of r to the implicit type they have in r=[$1..numelems(y)] ?
TIA
Download explore.mw
I'd like to solve this ODE
But not sure how to write it in Maple. In Mathematica, this is what I do
ClearAll[F, x, y, t];
ode = D[F[x[t], y[t]], x[t]]*D[x[t], t] + D[F[x[t], y[t]], y[t]]*D[y[t], t] == 0;
DSolve[ode, F[x[t], y[t]], {x[t], y[t]}]
and it gives
In Maple, I tried
ode:=diff(F(x(t),y(t)),x(t))*diff(x(t),t)+diff(F(x(t),y(t)),y(t))*diff(y(t),t)=0
Error, invalid input: diff received x(t), which is not valid for its 2nd argument
ode:=D[1](F)(x(t),y(t))*diff(x(t),t)+D[2](F)(x(t),y(t))*diff(y(t),t)=0;
dsolve(ode,F(x(t),y(t)))
Error, (in dsolve) expected the indeterminate function as, say, F(x) where x is of type "name" - and also cannot be a procedure name. Received: [F(x(t), y(t))]
What is the correct way to write this in Maple?
I want to sort the formulae to Psi and Beta, but I don't know how it works. I have tried it with sort, simplify, isolate, but that isn't what I'm searching.
It should looks like the simplier formula in the picture.
ab := (diff(Psii(t), t, t))*J-l[f]*(F[s, f, l]+F[s, f, r])+l[r]*(F[s, r, l]+F[s, r, r])-(1/2)*b[r]*(-F[s, r, l]*delta[l]+F[s, r, r]*delta[r]) = 0;
  / d  / d         \\
  |--- |--- Psii(t)|| J - l[f] (F[s, f, l] + F[s, f, r])
  \ dt \ dt        //
     + l[r] (F[s, r, l] + F[s, r, r])
     - - b[r] (-F[s, r, l] delta[l] + F[s, r, r] delta[r]) = 0
bc := (diff(betaa(t), t, t))*m*v*betaa(t)+F[s, r, l]*delta[l]+F[s, r, r]*delta[r]-(diff(Psii(t), t)) = 0;
    / d  / d          \\
    |--- |--- betaa(t)|| m v betaa(t) + F[s, r, l] delta[l]
    \ dt \ dt         //
                               / d         \
       + F[s, r, r] delta[r] - |--- Psii(t)| = 0
                               \ dt        /
cd := (diff(betaa(t), t))*m*v+F[s, r, l]+F[s, r, r]+F[s, f, l]+F[s, f, r]-(diff(Psii(t), t)) = 0;
   / d          \
   |--- betaa(t)| m v + F[s, r, l] + F[s, r, r] + F[s, f, l]
   \ dt         /
                     / d         \
      + F[s, f, r] - |--- Psii(t)| = 0
                     \ dt        /
F[s, f, l] := c[fl]*alpha[fl];
                        c[fl] alpha[fl]
F[s, f, r] := c[fr]*alpha[fr];
                        c[fr] alpha[fr]
F[s, r, l] := c[rl]*alpha[rl];
                        c[rl] alpha[rl]
F[s, r, r] := c[rr]*alpha[rr];
                        c[rr] alpha[rr]
alpha[fl] := (-v*betaa-l[f]*(diff(Psii(t), t)))/(-v+(1/2)*b[f]*(diff(Psii(t), t)));
                                 / d         \
                 -v betaa - l[f] |--- Psii(t)|
                                 \ dt        /
                        1      / d         \
                   -v + - b[f] |--- Psii(t)|
                        2      \ dt        /
alpha[fr] := (-v*betaa-l[f]*(diff(Psii(t), t)))/(v-(1/2)*b[f]*(diff(Psii(t), t)));
                                 / d         \
                                 \ dt        /
                       1      / d         \
                   v - - b[f] |--- Psii(t)|
                       2      \ dt        /
alpha[rl] := delta[l]+(-v*betaa+l[r]*(diff(Psii(t), t)))/(-v+(1/2)*b[r]*(diff(Psii(t), t)));
                                       / d         \
                       -v betaa + l[r] |--- Psii(t)|
                                       \ dt        /
            delta[l] + -----------------------------
                              1      / d         \
                         -v + - b[r] |--- Psii(t)|
                              2      \ dt        /
alpha[rr] := delta[r]+(-v*betaa+l[r]*(diff(Psii(t), t)))/(-v-(1/2)*b[r]*(diff(Psii(t), t)));
                                       / d         \
                                       \ dt        /
            delta[r] + -----------------------------
                              1      / d         \
                         -v - - b[r] |--- Psii(t)|
                              2      \ dt        /
ab;
/ d  / d         \\          |
|--- |--- Psii(t)|| J - l[f] |
\ dt \ dt        //          |
        /                / d         \\
  c[fl] |-v betaa - l[f] |--- Psii(t)||
        \                \ dt        //
             1      / d         \
             2      \ dt        /
           /                / d         \\\        /      /
     c[fr] |-v betaa - l[f] |--- Psii(t)|||        |      |
           \                \ dt        //|        |      |
   + -------------------------------------| + l[r] |c[rl] |delta[
               1      / d         \       |        |      |
           v - - b[f] |--- Psii(t)|       |        |      |
               2      \ dt        /       /        \      \
                       / d         \\
       -v betaa + l[r] |--- Psii(t)||
                       \ dt        /|
  l] + -----------------------------|
              1      / d         \  |
         -v + - b[r] |--- Psii(t)|  |
              2      \ dt        /  /
           /                           / d         \\\          /
           |           -v betaa + l[r] |--- Psii(t)|||          |
           |                           \ dt        /||   1      |
   + c[rr] |delta[r] + -----------------------------|| - - b[r] |
           |                  1      / d         \  ||   2      |
           |             -v - - b[r] |--- Psii(t)|  ||          |
           \                  2      \ dt        /  //          \
       /                           / d         \\
       |                           \ dt        /|
-c[rl] |delta[l] + -----------------------------| delta[l]
       |                  1      / d         \  |
       |             -v + - b[r] |--- Psii(t)|  |
       \                  2      \ dt        /  /
           /                           / d         \\         \
           |           -v betaa + l[r] |--- Psii(t)||         |
           |                           \ dt        /|         |
   + c[rr] |delta[r] + -----------------------------| delta[r]| =
           |                  1      / d         \  |         |
           |             -v - - b[r] |--- Psii(t)|  |         |
           \                  2      \ dt        /  /         /
bc;
 / d  / d          \\
 \ dt \ dt         //
            /                           / d         \\
            |                           \ dt        /|
    + c[rl] |delta[l] + -----------------------------| delta[l]
            |                  1      / d         \  |
            \                  2      \ dt        /  /
            /                           / d         \\
            |                           \ dt        /|
            |                  1      / d         \  |
            \                  2      \ dt        /  /
      / d         \
    - |--- Psii(t)| = 0
      \ dt        /
cd;
 / d          \
 |--- betaa(t)| m v
 \ dt         /
            /                           / d         \\
            |                           \ dt        /|
            |                  1      / d         \  |
            \                  2      \ dt        /  /
            /                           / d         \\
            |                           \ dt        /|
            |                  1      / d         \  |
            \                  2      \ dt        /  /
            /                / d         \\
            \                \ dt        //
                 1      / d         \
                 2      \ dt        /
            /                / d         \\
            \                \ dt        //   / d         \
    + ------------------------------------- - |--- Psii(t)| = 0
                1      / d         \          \ dt        /
                2      \ dt        /
I'm trying to solve the couple of ode
with boundary conditions
using differential transformation method.Isolved the equations and found the parameter values,further i coudn't plot the graph.
Can any one help me out to solve this
Hi !
I have several infinite sommations to evaluate. Maple 2018 on Windows 10 often gives me the solution in terms of hypergeometric functions. I know that the solution can be expressed in terms of sines and cosines.
I am not familiar with sumtools or Sumtools packages.
The convert (expr, StandardFunctions) or simplify (expr, hypergeom) commands do not work.
Here is an example of a sommation to evaluate.
My old version of Maple V release V (1997 version)  gives me the desired result with the same commands.
Is there a command that forces Maple to give me the solution in terms of sines and cosines ?
I don't have Mathematica. I hate Mathematica with its difficult syntax but I have access to a computer with Mathematica.
There is a "FunctionExpand" command which converts hypergeometrics into standard functions.
For the previous summation it works very well.
Thanks !
Réjean
Use Maple to calculate 245 to the power of 272 (ie 245^272).
Enter the last three digits of this number in the box below.
I have written a bit of code which solves a linear system for some quantities which have been Laplace and then Fourier transformed.
e1 := -2*D*i*k*pi + A*s = 0
e2 := 2*A*i*k*pi + 2*C*i*k*pi + B*s = a
e3 := s*C + 4/5*P*w3*(2*pi*i*k*D - 2*1/3*pi*i*k*D)/w2 = -2*(C + 2*K*(2*pi*i*k*B - 2*1/3*pi*i*k*B))/(w2*K)
e4 := s*D + 2*5/4*P*t4*pi*i*k*C/(t2*K) = -5/(2*P)*D/(t2*K)
sys := {s*C + 4/5*P*w3*(2*pi*i*k*D - 2*1/3*pi*i*k*D)/w2 = -2*(C + 2*K*(2*pi*i*k*B - 2*1/3*pi*i*k*B))/(w2*K), s*D + 2*5/4*P*t4*pi*i*k*C/(t2*K) = -5/(2*P)*D/(t2*K), -2*D*i*k*pi + A*s = 0, 2*A*i*k*pi + 2*C*i*k*pi + B*s = a}
solve(sys, [A, B, C, D])
Linear_System.mw
I get at the end some fractions where everything in the fractions is a constant with some physical meaning except for k which is the only frequency as I am working in one dimension so just need one-dimensional Fourier and Laplace transforms.  s is the corresponding variable from the Laplace transform.
I was wondering if Maple had some functionality which would enable me to inverse Laplace and then inverse Fourier transform these quantities A, B, C and D from the linear system such that I obtain an algebraic expression at the end and not a numerical result.
I have the attached code, it returns a "unable to parse" error after the line with the "FOC__1D1" assignment. I can't find out why.
Thank you for your help in advance,
JTamas
1_2_test.mw
First 632 633 634 635 636 637 638 Last Page 634 of 2472
