is it possible to get all the iteration values for a minimization problem
Hey,
I want to animate action of linear transformation on multiple polygons, in the end, it should be a grid of multiple parallel lines that will get morphed. The transformation is defined by a matrix A.
So far I got this code to work:
with(plottools):
setoptions(style=patch,view=[-5..5,-5..5], scaling=constrained):
basis_i:=polygon([[0,0],[1,0]],color=red):
N:=20:
F:=(x,y) -> (1-k/N)*<x,y> + k/N*(A.<x,y>):
L := transform((x,y)->convert(F(x,y),list)):
A:=<<2,1>|<-1,1>>;
frames:=seq(L(basis_i),k=0..N):
display(frames, insequence=true);
It animates the basis vector nicely, but I can't seem to figure out, how to animate multiple lines, multiple polygons.
Anyone knows how to do this?
Any help will be much appreciated.
I try to fill an Array with a procedure to have pointpairs for a plot. Here is my problem. It doesn't work I wont it to.
Can someone help my please? The first procedure works, I tested it with some numbers, but the second one is the Problem.
Hi dear maple team. i have a question on integration and i need a "real" and "finite" solution with any assumption or options. thanks for the help.
f := ((1 - a)^2 + a^2*((1 - exp(-y))*(1 - exp(-x)) - 2 + exp(-x) + exp(-y)) + a*(2 - exp(-x) - exp(-y) + (1 - exp(-y))*(1 - exp(-x))))/(1 - a*exp(-x)*exp(-y))^3;
((1-a)^2+a^2*((1-exp(-y))*(1-exp(-x))-2+exp(-x)+exp(-y))+a*(2-exp(-x)-exp(-y)+(1-exp(-y))*(1-exp(-x))))/(1-a*exp(-x)*exp(-y))^3
a := 0.3;f
.3
(.91+.39*(1-exp(-y))*(1-exp(-x))-.21*exp(-x)-.21*exp(-y))/(1-.3*exp(-x)*exp(-y))^3
s := 2*evalf(int((int(f*exp(-x)*exp(-y), x = 0 .. y + t,AllSolutions)), y = 0 .. infinity,AllSolutions)) assuming real ;
Download stat1.mw
Hello, Probably there is a way to do this easily but I do not quickly find it within the help.
I want
rand(0..1)
to give a true! random number and not always the same number; otherwise it should be called
predefinedlist()
Seed is deprecated, not sure it would help though. So how do I go abouts?
In this code created by Acer a long while back. I can't figure out how to increase the length of the text rotating so the letters don't collide with one another.
Here is the code.
# One (of many) STL format collections of the English alphabet:
#     http://www.stlfinder.com/model/all-alphabet-letters-a-z
basedir:=cat(kernelopts(homedir), "/My Documents/stl/All_Alphabet_Letters_A-Z"):
getletter:=L->Import(cat(basedir, "/Letter_", L, ".stl"),
                     orientation=[-90,0,0],title=""):
letters := [m,a,p,l,e]:
for letter in letters do
  if not assigned(AZ[letter]) then
    AZ[letter]:=getletter(letter);
with(plottools): with(plots):
Rplot:=display(AZ[letters[1]],
               seq(translate(AZ[letters[i]], 40*(i-1)+15, 0, 0),
                   i=2..nops(letters))):
Rplot:=transform((x,y,z)->[z,x,y])(scale(Rplot, 5/6*2*Pi/200, 1/5, 1/20, [0,0,10])):
display(changecoords(Rplot,cylindrical), scaling=constrained, axes=none,
        orientation=[0,90,0], viewpoint=[circleright], frames=50);
Here is the file with the letters
All_Alphabet_Letters_A-Z.zip
Good day everyone and happy new year in advance. I'm trying to write a code for a series but its not substituting. Below is the attached file. Thanking you very much in anticipation for your help.
Testing.mw
I went to save a file in Maple and it had large amounts of calculated data.
Maple didn't ask me if I also wanted to save that data like it usually does - it just saved it.  Saved a 13Mb worksheet that took 5 minutes to relinquish control on my laptop.
is it possible to send compiled Maple functions (C function) to the nodes with the Grid toolbox? I can run the non-compiled function on the nodes but when I try to send a compiled version of the same function I get segmentation error. I have run the compiled function just fine in other nonparallel codes, and also with the Threads package. So I was wondering if there is something else you need to do to get it to work? Maybe compile on each node?
Dear Maple users
I just created a sunflower in Maple using the Golden angle. See attached file. I am using a scatterplot with solidcircles as symbols. But what I would like now is to plot integers instead of the solidcircles in order to investigate the order of these different solidcircles. To make it clear: I have 500 solidcircles. They have been plottet using two vectors containing the x and y coordinates of the individual solidcircles. The n'th solidcircle I want to replace with the integer n. How can I create that different plot?
NB! The plot might need to be larger or the integers smaller, but that is fine.
Erik V
sunflower.mw
A flexible rope of constant linear density hangs from one fixed end.
The lower end is pulled aside and then released.
The rope swings back and forth with a whip-like action.
What equation of motion can be used to animate this action in Maple?
I cannot find any references through Google to the appropriate math.
Is there any alternative to Mathematica's "RegionFunction" in Maple, with applications of controlling the plotting domain for surface plots ? This question has been asked previosly, and given a workaround by "Markiyan Hirnyk", suggesting to leave the function that is to be plotted undefined outside of the plot region. Something like:
f1 := proc(x,y) if x^2 + y^2 > 0 and x^2 + y^2 < 4 then 8 - x^2 - y^2 end if end proc:
f2 := proc(x,y) if x^2 + y^2 > 0 and x^2 + y^2 < 4 then x^2 + y^2 end if end proc:
plot3d({f1,f2}, -2..2, -2..2)
The result is clearly not good looking. You can increase the number of points, but we need a better way to do this.
BTW, the similar question was asked in 2010. Are there any better alternatives, ~ 10 years later ?
Please explain the logic used to construct the plot below.
plots:-implicitplot(r >= cos(theta), r = 0 .. 1/3, theta = 0 .. 2*Pi, filledregions, coords = polar, numpoints = 5000, scaling = constrained)
I found that while using maple gui cases of corruption, stuck while typing etc. Hope this problem will get solved in coming version
I have a differential equation. I can solve it using dsolve and plot it with odeplot. For example I obtain P(x).
I also have another equation. For example V in terms of x. So, I can plot it with plot(V).
Now I want to plot V in terms of P. How can I do that?
Thanks for your help
First 634 635 636 637 638 639 640 Last Page 636 of 2458
