MY worksheet have more than 100 parameters, now I want to use all of the parameters within a procedure, is there any easy way to introduce all these paramaters to proc without mentioning them in parentheses one by one proc(x,y,z,...)?
hello everyone,
I am trying to optimize expressions symbolically. I need to find out the maximum value possible for an variable, so that the expressoin still have a valid solution.
For Example:
expr:=a-b/b-a^3;  # a=(0,10), b=(0,10)
In this eypression b=a^3 is the only case where undefined solution is possible, for a given interval of variables
This looks fine for simple expression. But in reality there are complex equations to solve with more than 2 varibles.
1) first thing is to find out all values of a variable resulting in undeifined output(or infinite)
2) assign a symbolic value(variable < or > some value) to the variable so that the undefined result can be eliminated.
 I need to optimize the given expression so that it does not have any undefined cases when solving. I understood that when optimizing, there always be a condition on variables(in this case variable max is the condition, maximum value the variable can take). output of an expression is always a real value
OptimizedExpr:=a-b[max]/b[max]-a^3 --> b[max]>a^3 or b[max]<a^3
(it is easy to to say b[max] is not equal to a^3 , also a^3 is the limiting value. In some case it is more resonable to just ignore other part of limiting value. Hence, I would like to optimize using greaterthan or lessthan of limiting value).
I would be very glad to know how I can find Optimized expressions. I tried using the solve function but observed that expressions are equalled to zero and solving. which is completely opposite to what I was looking. I really do not know is there any way to find out undefined cases in expressions and on what varibale at what values.
I tried to explain the situation at my best and I welcome for any suggested edits or furthur information required.
how I can determied  this integral in figure below or compute area in figure which adressed in the following website?
https://en.m.wikipedia.org/wiki/Spherical_cap
Hello everyone !
 when I use  the command   ''G1:=NonIsomorphicGraphs(5, output = graphs, outputform = adjacency)''  , I want to compute the   rank of   adjacent  matrices of
every graph in  G1,. I try to do , but maple  retutn false:
Rank(G1);
Error, invalid input: too many and/or wrong type of arguments passed to LinearAlgebra:-Rank; first unused argument is Matrix(5, 5, {(1, 1) = 0, (1, 2) = 1, (1, 3) = 1, (1, 4) = 1, (1, 5) = 1, (2, 2) = 0, (2, 3) = 1, (2, 4) = 1, (2, 5) = 1, (3, 3) = 0, (3, 4) = 1, (3, 5) = 1, (4, 4) = 0, (4, 5) = 1, (5, 5) = 0}, datatype = integer[1], storage = triangular[upper], shape = [symmetric])
  How to achieve it , I do not konw to  invoke these adjacent matrices . Would someboby
give me a hand.
Thanks very much!
how I can write taylor function for following example.
I want to gain an answer similar to the image result by using taylor function.
tylor.mw
P27 := f(x+fNx/`&Delta;x`, y+(`&Delta;y`-fNy)/`&Delta;y`, z+fNz/`&Delta;z`)
f(x+fNy/`&Delta;x`, y+(`&Delta;y`-fNy)/`&Delta;y`, z+fNz/`&Delta;z`)
with(MultiSeries)
taylor(P27, x = 0)
series(f(fNy/`&Delta;x`, -(-y*`&Delta;y`+fNy-`&Delta;y`)/`&Delta;y`, (z*`&Delta;z`+fNz)/`&Delta;z`)+(D[1](f))(fNy/`&Delta;x`, -(-y*`&Delta;y`+fNy-`&Delta;y`)/`&Delta;y`, (z*`&Delta;z`+fNz)/`&Delta;z`)*x+((1/2)*(D[1, 1](f))(fNy/`&Delta;x`, -(-y*`&Delta;y`+fNy-`&Delta;y`)/`&Delta;y`, (z*`&Delta;z`+fNz)/`&Delta;z`))*x^2+((1/6)*(D[1, 1, 1](f))(fNy/`&Delta;x`, -(-y*`&Delta;y`+fNy-`&Delta;y`)/`&Delta;y`, (z*`&Delta;z`+fNz)/`&Delta;z`))*x^3+((1/24)*(D[1, 1, 1, 1](f))(fNy/`&Delta;x`, -(-y*`&Delta;y`+fNy-`&Delta;y`)/`&Delta;y`, (z*`&Delta;z`+fNz)/`&Delta;z`))*x^4+((1/120)*(D[1, 1, 1, 1, 1](f))(fNy/`&Delta;x`, -(-y*`&Delta;y`+fNy-`&Delta;y`)/`&Delta;y`, (z*`&Delta;z`+fNz)/`&Delta;z`))*x^5+O(x^6),x,6)
Download tylor.mw
I am trying the following command:
restart; with(IntegrationTools):
simplify(int(f(x), x = 0 .. L*Ts)-Split(int(f(x), x = 0 .. L*Ts), [i*Ts, i = 0 .. L]))
Clearly the output should be 0. However, maple is not able to output the correct result. Any ideas?
I have 26 equations  and 26 variables and I want to solve them numerically. fsolve function returns whole equations as a solution.
Any advice ?
What command in Maple runs specific worksheets within other worksheet?
Actually I want to know how is it possible to comminucate and control multiple worksheets within one specific worksheet?
I want to store the matrix m2 representing a system m2*x=b with vectors as given by the command "CompressedSparseForm" and solve the system using those vectors and b without using m2 and b.
vectors.mw
restart; with(LinearAlgebra)
m2 := Matrix([[102, 0, 0, .1, 1], [0, 3, 0, 0, 1], [1, 3.1, 7, 0, 0], [1, 33, 0, .5, 0], [1, 0, 0, 0, 1]], 'datatype = float')
Matrix([[102., 0., 0., .100000000000000, 1.], [0., 3., 0., 0., 1.], [1., 3.10000000000000, 7., 0., 0.], [1., 33., 0., .500000000000000, 0.], [1., 0., 0., 0., 1.]])
cm, rm, values := CompressedSparseForm(m2)
Vector(6, {(1) = 1, (2) = 5, (3) = 8, (4) = 9, (5) = 11, (6) = 14}, datatype = integer[8]), Vector(4, {(1) = ` 1 .. 13 `*Vector[column], (2) = `Data Type: `*integer[8], (3) = `Storage: `*rectangular, (4) = `Order: `*Fortran_order}), Vector(4, {(1) = ` 1 .. 13 `*Vector[column], (2) = `Data Type: `*float[8], (3) = `Storage: `*rectangular, (4) = `Order: `*Fortran_order})
b := `<,>`(1.1, 2, 5, .5, 5)
Vector(5, {(1) = 1.1, (2) = 2, (3) = 5, (4) = .5, (5) = 5})
LinearSolve(m2, b)
Vector(5, {(1) = -.107505070993915, (2) = -1.03583502366464, (3) = 1.18837052062204, (4) = 69.5801217038540, (5) = 5.10750507099392})
NULL b
Download vectors.mw
Digits := 15;
b := -I;
a := sqrt(2);
epsilon := 1;
f := proc (t) options operator, arrow; evalf(Int(exp(I*k*t)/((1+a^2*sin(k)^2)*(k-b)^epsilon), k = -infinity .. infinity)) end proc;
f(1.3)
I tried different methods like _d01amc, but either I have this error:
Error, (in evalf/int) NE_QUAD_NO_CONV:
  The integral is probably divergent or slowly convergent.
or it takes forever.
I also tried to map the interval to some finite length (k=tan(u)), but then I get
Error, (in evalf/int) NE_QUAD_BAD_SUBDIV:
  Extremely bad integrand behaviour occurs around the
  sub-interval (-1,5707963e+000, -1,5707963e+000 ).
disgusting integrand?
I hope to enter something like
5^(x-1)=5^x/5
And get "true". Mathematica and some other softwares do this but Maple returns my exact input (I'm new to Maple).
I tried using evalb and verify, but they all return false or FAIL. Is there a straightforward to verify equality and get a result of True or False in Maple?
Is there any way with integer programming function "LPSolve" to get all optimal solutions, because I know there is more than one, and in case if there is a lot of optimal solutions, how to show only the number of optimal solutions?
Thanks in advance!
Executing the entire worksheet several times I obtain random results for Threads:-Seq
N:=10^3;
f:= (a,b) -> add(evalf(j), j=a..b);
1000
proc (a, b) options operator, arrow; add(evalf(j), j = a .. b) end proc
seq(f(k*N/4+1,(k+1)*N/4), k=0..3);
31375., 93875., 156375., 218875.
Threads:-Seq(f(k*N/4+1,(k+1)*N/4), k=0..3);
31218.+j, 93875., 156375., 218875.
31900., 94170., 156375., 218875.
Download threads!.mw
I have the follownig set of inequality:
{0 < p[1, 2], p[1, 1] < 2*p[2, 2]+(3/2)*p[1, 2], p[1, 2]^2/p[2, 2] < p[1, 1], (2/3)*p[1, 2] < p[2, 2]}
Now I need to find value of p11,p12,p22 that satisfy the above inequality. Is there any easy way to find
parameters p11, p12, p22 in maple?
Best
I have a system with the following config:
But when I run my worksheet, only 10% of CPU and 8% of the RAM are working, and it takes one hour my wrksheet to be computed, I am wondering why Maple do not use enough CPU and RAM to do the computation fast.
What is the justification behind this? Is there a way to coerce the Maple to use more capacities of the CPU and RAM to speed up the computations?
First 777 778 779 780 781 782 783 Last Page 779 of 2459
