How can I get the vlalue of x, y and z into an expression?
In example here I would like to know the value of 2x+3y+z
many thanks
I'm hoping somebody can help with this problem.
The Poisson Loss Function is defined by the series:
L := sum((n-s)*lambda^n*exp(-lambda)/factorial(n), n = s .. infinity)
Where lambda is the mean value that is prescribed and s is the variable in question.
Now, if the value of L is given, can anyone tell me how to solve for  s?
Poisson Distribution Loss Function Tables are available and give values for s for a given lambda, so I's like to see if Maple can handle this.
Thanks for reading!
How do I get Maple to reduce/simplify the following difference quotient to its lowest terms? Basically I need Maple to rationalize the numerator. Any suggestions on how to do this?
f := proc (x) options operator, arrow; sqrt(2*x+1) end proc
expand((f(x+h)-f(x))/h)
(2*x+2*h+1)^(1/2)/h-(2*x+1)^(1/2)/h
simplify((f(x+h)-f(x))/h)
((2*x+2*h+1)^(1/2)-(2*x+1)^(1/2))/h
rationalize((f(x+h)-f(x))/h)
Download rationalize.mw
Consider the `or` procedure.
`or`(x, y)  should be equivalent to  x  or  y.
However:
x := a=0;
y := b=0;
                           x := a = 0
                           y := b = 0
x or y;
`or`(x,y);
                         a = 0 or b = 0
simplify(`or`(x,y));
                         a = 0 or b = 0
eval(`or`(x,y));
### So,  `or`(x,y)  is not fully evaluated [or simplified?].
### Is this documented somewhere?
# Similarly
`not`(x);
                           not a = 0
not x;
I am currently programming the Anderson Acceleration for fixed point iteration in Maple. The algorithm comes from Walker et al. 2011 (ANDERSON ACCELERATION FOR FIXED-POINT ITERATIONS) (if you are interested in this problem please read the short paper). The code that Walker supplies runs fine in Matlab, with qrdelete as a built-in function. However in Maple I have decided to skip operations on QR, and instead opted to create a new QR every time I increase or decrease the amount of residuals df. However, here comes the kicker, somehow Maple decides to turn a vector or matrix into a procedure when I Concatenate, or DeleteColumn. I could really use a working Anderson Acceleration code for my research (my research is not based on AA or root solvers in general, but spectral methods). I will paste the entire code here. This is my attempt at getting Walker's original Matlab code to work in Maple.
I could use some pointers and tips. Can you program this in a more efficient way? I would be happy to learn. *Notice that the code works for a host of different equations, but not all. Feel free to let me know if this question or inquiry is inappropriate and I will of course delete the post.
Digits:=12:
Runtime:=time():
with(orthopoly):
with(ArrayTools):
phix := Vector(2):
X    := Vector(2):
phix[1] := cos(x[2]):
phix[2] := 3*cos(x[1]):
X[1] := 0.0:
X[2] := 0.0:
#Code AndersonAcceleration.
AndersonAcceleration:=proc(N,phi,X0)
global x, xS, here1, here2;
local mMax, itmax, atol, rtol, droptol, beta, AAstart, res_hist, df, DGg, gamma;
local DG, mAA, iter, gval,fval,res_norm, tol, f_old, g_old, y, i, k, Q, R, QRg, dfT, DGT;
% Function xS = AndersonAcceleration(N,phi,x0).
% Fixed-point iteration with or without Anderson acceleration.
% 'phi' is the fixed point iteration map and 'xS' is the
% solution, so that xS = phi(xS).
% Input arguments:
%    X0 = Initial value solution. Note: In this function this variable
%        must be a column vector.
%       1. 'mMax' = maximum number of stored residuals (non-negative integer).
%       NOTE: 'mMax' = 0 => no acceleration. default=1000
%       2. 'itmax' = maximum allowable number of iterations. default=1000
%       3. 'atol' = absolute error tolerance. default=1.0e-6
%       4. 'rtol' = relative error tolerance. default=1.0e-3
%       5. 'droptol' = tolerance for dropping stored residual vectors to
%       improve conditioning: If 'droptol' > 0, drop residuals if the
%       condition number exceeds droptol; if droptol <= 0,
%       do not drop residuals.
%       6. 'beta' = damping factor: If 'beta' > 0 (and beta ~= 1), then
%       the step is damped by beta; otherwise, the step is not damped.
%       NOTE: 'beta' can be a function handle; form beta(iter), where iter
%       is the iteration number and 0 < beta(iter) <= 1.
%       7. 'AAstart' = acceleration delay factor: If 'AAstart' > 0, start
%       acceleration when iter = AAstart.
% Output:
% xS = Solution vector.
% The notation used is that of H.F. Walker: Anderson Acceleration:
% Algorithms and implementation
mMax    := 1000:
itmax   := 1000:
atol    := 1.0e-8:
rtol    := 1.0e-12:
droptol := 1.0e4:
beta    := 1.0:
AAstart := 0:
# Initialize storage arrays and number of stored residuals.
DG := Matrix():
df := Matrix():
DGg := Vector(N);
QRg := Vector(N);
mAA := 0:
for iter from 0 to itmax do
   x:=X0:
   gval := Vector(phi):
   fval := gval - X0:
   res_norm := norm(fval,2):
   print(res_norm);
   # Set the residual tolerance on the initial iteration.
   if iter = 0 then
      tol := max(atol,rtol*res_norm):
   fi:
   # Convergence test, if converged the loop stops.
   if res_norm <= tol then
      print(res_norm);
      break;   # Breaks for-loop
   fi:
   # If resnorm is larger than 1e8 at iter > 5, problem stops
   if res_norm >1e8 and iter > 5 then
      print(res_norm);
      break; # Breaks for-loop, diverged
   fi:
   # Fixed point iteration without acceleration, if mMax == 0.
   if mMax = 0 or iter < AAstart then
      # We update E <- g(E) to obtain the next approximate solution.
      for i from 1 to N do
         X0[i] := gval[i]:
      # With Anderson acceleration.
      # Update the df vector and the DG array.
      if iter > AAstart then
         if mAA < mMax or Size(df,2) = 1 then
            print(whattype(df));
            df := Concatenate(2,df,fval-f_old):
            DG := Concatenate(2,DG,gval-g_old):
            df := Concatenate(2,df[..,-1],fval-f_old):
            DG := Concatenate(2,DG[..,-1],gval-g_old):
         fi:
         mAA := mAA + 1:
      fi:   # iter
      print(iter,mAA);
      # We define the old g and f values for the next iteration
      f_old := fval;
      g_old := gval;
      if mAA = 0 then
         # Initialization
         # If mAA == 0, update X <- g(X) to obtain themah next approximate
         # solution. No least-squares problem is solved for iter = 0
            X0[i] := gval[i]:
         if mAA > 1 then
            Q,R := QRDecomposition(df,datatype=float);
            while ConditionNumber(R) > droptol do
                if mAA = 2 then
                   print('here1'):
                   df := convert(DeleteColumn(df,1),Vector);
                   DG := convert(DeleteColumn(DG,1),Vector);
                   df := DeleteColumn(df,1);
                   DG := DeleteColumn(DG,1);
                fi:
                mAA := mAA - 1;
                print(Q,R,mAA);
            if Size(df,2) > 1 then
               print(Q,R);
               gamma := LeastSquares([Q,R],fval);
               print(gamma);
               R := norm(df,2);
               Q := MTM[mldivide](R,df);
               gamma := MTM[mldivide](R,Transpose(Q).fval);
               print(gamma);
            fi:
            R := norm(df,2);
         fi:
         if Size(gamma,1) > 1 then
            DGg:=DG.gamma:
            DGg:=DG*gamma;
         fi:
         # Update the approximate solution.
            X0[i] := gval[i] - DGg[i];
         print('Sol',X0);
         # Damping for non-zero beta
         if beta > 0 and beta <> 1 then
            if mAA = 1 then
               QRg := Q*R*gamma;
               QRg := df.gamma;
            fi:
               X0[i] := X0[i] - (1-beta)*(fval[i] - QRg[i]);
         fi:# isa(beta ...
         print(iter,mAA);
      fi: # mAA = 0
   fi:# mMax == 0
xS := Vector(N);
for i from 1 to N do xS[i]:=X0[i]: od:
return xS
end:
AndersonAcceleration(2,phix,X):
Is there already a build in sum(), add() procedure where you can supply a condition?
I know the help doesn't say anything about it, but I thought maybe there is something else.
Say I want to add the coefficients a(n) up to N, but only if n divides N, so
add(a(n),n=1..N,conditioner: mod(N,n)=0)
how can I get the first function acting on the symbolic expression as below(in this case log)
expr :=sin(abs(log(a+b*c)));
I need to solve for many unknown expressions. It would be great if I can able to get all functions in sequential order acting.
I got to know using op i can solve if only one function is action like below
expr := sin(a+b*c)
then op(0,expr) #gives sin
op(1,expr) # gives a+b*c
I have the following Maple code.
x := [5, 10, 15, 20];
y := [4.22, 7.49, 12.24, 19.60];
yui := [2.48, 3.76, 6.11, 14.60];
yli := [2.27, 3.34, 6.09, 10.90];
with(Statistics): with(plots):
p1 := ErrorPlot(y, coords = x, yerrors = yui);
this produces a plot with error bars. The problem is that I acutally have unequal errors. In the ErrorPlot helpfile it says:
"This options specifies errors along the x-axis. The array of errors must have the same number of elements. To specify right errors and left errors separately, use the list of two vectors." (this pertains to xerrors obviously but below it says the same applies to yerrors)
I have tried entering the code above with yerrors=[yli,yui] and with yerrors={yli,yui}....but neither option works and I get the error:
"Error, invalid input: Statistics:-ErrorPlot expects value for keyword parameter yerrors to be of type {identical(default), [{array, list, rtable, DataFrame, DataSeries}, {array, list, rtable, DataFrame, DataSeries}], {array, list, rtable, DataFrame, DataSeries}}, but received {[2.27, 3.34, 6.09, 10.90], [2.48, 3.76, 6.11, 14.60]}"
Can anyone advise me on what I'm doing wrong - I am very new to Maple.
Jo
Dear all, I am having difficuty in executing the following program. the error message reads "Error, unable to compute coeff". Secondly the solution and the graph of the equation could not display.Attached is the prime_question.mw
Download prime_question.mw
restart; with(student)
n := 2;
v := sum(u[i]*p^i, i = 0 .. 2);
p^2*u[2]+p*u[1]+u[0]
f := proc (x) options operator, arrow; e^x+(1/2)*x*(e^(2*x)-1) end proc;
k := proc (x, t) options operator, arrow; x end proc;
F := proc (u) options operator, arrow; u(x)^2 end proc;
u[0] := f(t);
e^t+(1/2)*t*(e^(2*t)-1)
for i to 2 do u[i] := expand(subs(x = t, int(coeff(p*k(x, t)*F(v), p^i), t = 0 .. x))) end do
s := value(sum(Eu[k], k = 0 .. 2*e));
U := proc (x) options operator, arrow; collect(s, x) end proc;
with*plots:
p1 := plot*(exact*solution, t = 0 .. T, style = point):
p2 := plot*(U(t), t = 0 .. T, style = line):
plots*([display])(p1, p2);
plots*[display(plot*(exact*solution, t = 0 .. T, style = point), plot*(sum(Eu[k], k = 0 .. 2*e), t = 0 .. T, style = line))]
file
I am using DirectSearch package for optimization. I am using GlobalOptima function. I want to see the settings and results such as initial points, number of iterations, residuals etc. I tried using infolevel[Directsearch] but couldn't see any results. Let me know if there is any other command to get this information.
I want to ask you, Is there any inequality for |cosh(x)|? I have read that cosh(x)<= e^(x^(2)/2).
Hello here is a description of my issue:
1. I created a new code edit region
2. i put some code in the code edit region
3. In the context Panel I unchecked the 'visible' setting for the code edit box
When I evaluate the worksheet the code in the code edit region still runs, but I can't figure out how to edit the code in that region. There is not an icon to open the code edit region as there would be had I toggled the 'expand' setting. Furthermore, I can't select the invisible code edit region in order to toggle the 'visible setting'.
How can I make the code edit region visible again?
Thanks for you help
This is my original question, but I can't ask, so I put it here.
I have a system of pde, and it's hard to solve.
But I want to find the type of solutions which are polynomials of degree n of the several independent variables.
Is it possible using 'pdsolve'? Or there are some other commands in Maple to do that?
Sorry, I comment not for answering question.
I want to ask a question, but I can't enter any 'Tags', but they need at least one tag.
There is not any text box where I can enter a tag.
Who can help me?
thanks!
I computed A and B matrices, now I want to write it in state space reperentation.
diff(x(t), t) = A*x(t)+B*u
where
diff(x(t), t) = (Vector(6, {(1) = diff(alpha(t), t), (2) = diff(alpha(t), t, t), (3) = diff(y(t), t), (4) = diff(y(t), t, t), (5) = diff(theta(t), t), (6) = diff(theta(t), t, t)}))
So I calculated A*x(t)+B*u and got this:
(Vector(6, {(1) = diff(alpha(t), t), (2) = diff(alpha(t), t, t), (3) = diff(y(t), t), (4) = diff(y(t), t, t), (5) = diff(theta(t), t), (6) = diff(theta(t), t, t)})) = (Vector(6, {(1) = 0, (2) = k/(J*R), (3) = 0, (4) = k/(M*R*r), (5) = 0, (6) = -k/(M*R*r*l)})).e+(Vector(6, {(1) = diff(alpha(t), t), (2) = -k^2*(diff(alpha(t), t))/(J*R), (3) = diff(y(t), t), (4) = -k^2*(diff(y(t), t))/(M*R*r^2)-m*g*theta(t)/M, (5) = diff(theta(t), t), (6) = k^2*(diff(y(t), t))/(M*R*r^2*l)+(M+m)*g*theta(t)/(M*l)}))
where u=e but the formation is not A*x(t)+B*u anymore. How can I enforce Maple to output the result in the form of A*x(t)+B*u?
First 805 806 807 808 809 810 811 Last Page 807 of 2459
