dear all,
i have a Maple file where I have made some calculations solving equations, and have plotted a figure. I would like to know how to process this figure in a way so that i can get the data points of the plot, in order to plot them separately in a different software such as Excel or MATLAB for example.
 Right-click on the figure and exporting doesnt help as the options are only to export the figure to pdf, bitmap, png, etc. This is not what I want. I want to get the data of the fiogure, so that i can plot in external software (excel, MATLAB etc)
can you give some suggestions as to how to do this ?
thanks in advance
best regards,
Abhishek
sys1:=-.736349402144656384 = -1.332282598*10^12*(-.99999999999999966)^po1-1.332282598*10^12*(-.99999999999999966)^po2-.735533633151605248*Resid;
sys2:=.326676717828940144 = 1.331567176*10^12*(-.99999999999999966)^po1+1.331567176*10^12*(-.99999999999999966)^po2+.325144093024965720*Resid;
sys3:=.590327283775080036 = -1.072184073*10^9*(-.99999999999999966)^po1-1.072184073*10^9*(-.99999999999999966)^po2+.589610307487437146*Resid;
Minimize(sys1, {sys2,sys3},assume = nonnegative);
complex value encountered;
how to calculate basis <1,4,0>, <1,0,4> for eigenvalue 2;
how to calculate basis <1,0,1> for eigenvalue -1;
A := Matrix([[-2,1,1],[0,2,0],[-4,1,3]]);
sys1 := Eigenvalues(A)[1]*IdentityMatrix(3)-A;
sys1 := Eigenvalues(A)[2]*IdentityMatrix(3)-A;
sys1 := Eigenvalues(A)[3]*IdentityMatrix(3)-A;
B:=[<sys1[1,1],sys1[2,1],sys1[3,1]>,<sys1[1,2],sys1[2,2],sys1[3,2]>,<sys1[1,3],sys1[2,3],sys1[3,3]>,<0,0,0>];
LinearAlgebra:-Basis(B);
but not <1,4,0>, <1,0,4> for eigenvalue 2
A few days ago I was browsing through some books in my collection, that by Gradshteyn and Ryzhik in particular. What fraction of the intregrals, series and products therein can Maple handle correctly?  Besides special functions these properties are valuable components of symbolic mathematical software.  If the answer to this question is not nearly everything in that printed compilation, this inclusion in Maple is a worthy objective.
In Maple 2015 is there a way to fit data to an exponential model and determine the goodness of fit?
Thanks in advance!
Les
I am trying to solve the particular system of partial differential equation. But I get the following error.pdsolve.mw
"restart;  f(x,y):=x*y:  yy:={diff(f(x,y),x)=0,diff(f(x,y),y)=0}:  ee:=pdsolve(yy,numeric);"
Error, (in pdsolve/numeric) invalid subscript selector
Download pdsolve.mw
Of course, with Maple.
What would be the IBC conditions for the 1D heat equation describing the temperature distribution along a circular rod with a heat source at its base?
I have 6 by 6 Hessian matrix H. I want to check whether it is a negative definite. The rule of negative definite is "if and only if its n leading principlal minors alternate in sign with the kth order leading principal minor should have same sign as (-1)^k".
In my Hessian H, some leading principal minor of H is zero while the nonzero ones follows above rule. So negative definite test fails and Now I have to check negative semidefinite test which state that "H is negative semidefinite if and only if every principal minor of odd order is <=0 and every principal minor of even orderis >=0". So I have to check sign of every principal minor ( instead of just leading principal minor) to check for negative semidefinite of H matrix.
Can anyone help me how can I compute sign of all principal minor of a 6 by 6 square Hessian matrix.
Thanks and Regards,
Nilesh
Hello people in mapleprimes,
I want to single out omega^epsilon from and modify the rhs of the following expression
to the expression where the  the part without omega^epsilon and  another part of  omega^epsilon
are multiplied.
Y = -L*epsilon^epsilon*(1-epsilon)^(1-epsilon)*(-omega^(-1+epsilon)*k*theta+(1-theta)*omega^epsilon)/(1-epsilon-theta)
I am glad if you teach me this.
taro
I found this error extremely confusing when using the solve function:
Error, (in Engine:-Dispatch) cannot determine if this expression is true or false: 1000 < 5^(1/2)
Hi, i encountered this, error, and the link to the help page was broken.
Error, (in RootOf) expression independent of _S000100
when I enter a trig function as cos(pi/2) I get as a return the same input.  What I would like is the numeric answer displayed. also there are times when I don't want pi in the answer but a numeric value calculated based on pi * whatever.
Bill
I am trying to prove the equation of the least square estimator. For example, I have:
X := Matrix(2,3,symbol=p)
Y:= Matrix(2,1,symbol=f)
b:= Matrix(2,1,symbol=n)
or Y=X.b
The known estimation of b results from the minimization of the objective function:
S:=Transpose(X.b-Y).(X.b-Y).
We take the derivative of the above expression and set it equals with zero.
Then the estimator is: b=MatrixInverse(Transpose(X).X).Transpose(X).Y
How can I get this expression using commands οn maple?
My final task is to change the objective function to see the different estimations. For example if I have the below objective function which is the results of estimation as equation:
S:=Transpose(X.b-Y).MatrixInverse(C).(X.b-Y)
where C:=Matrix(2,2,symbol=w)
Ofcorsse I know the answer, but I am not sure for more complicated objective functions.
Hello people in maple primes,
I have an expression,
e1_1:=-gamma*r*theta/(w*beta*(theta-1))
, which I want to put in order as
gamma*r*theta/(w*beta*(1-theta))
Isn't there any ways to do the modification above?
 I am very glad if you answer to my question.
taro
First 990 991 992 993 994 995 996 Last Page 992 of 2467
