I need to formulate the follow relationship in proper math symbols:
Differential in A (last days value minus today's) has a tendency to reach the Differential in B (today's)
I though this could be expressed with
AΔ -> BΔ
BUt I guess there are more elegant and mathematically correct ways to do this in Maple?
thank you!
Dave
Lets say you a country where the official government debt (not adjusted for who owns the debt) is 30% of GDP. The official government debt consist of 50% government bonds and the central banks owns 40% of these government bonds. Since the government finance the centralbank we have to adjust the official government debt and remove the 40% of the government bonds that the centralbank own to get the real government debt expresed as % of GDP. In my initial calculation I simply did like this:
Real government debt expressed as % of GDP = 0.3*(1-0.4) =18%
However, that such number does not take into consideration that the official government debt is only made up of 50% government bonds. I tried to play around with different types of equations but I found none that makes any logical sense and provides me with a reasonable number. I would expect the real government debt to around 23% of GDP. This might be a simple question but I must admit I am stuck and I am not making any progress.  Any help would be appreciated.
As I understand it, Maple will detect and use the available cores in a system, if the calculation is suitable for multi-core use.
As I am installing Maple on a multi-user cluster, using a scheduler to run maple scripts, I want to ensure the maple jobs only use the number of cores allocated to the job.
Is it possible to set the number of cores used ?
If I have misunderstood how Maple works (I am new to it), or if there is a section in the documentation which explains this, please point me in the right direction.  I haven't found this info so far.
I have the transition matrix used in Markov chain
A := Matrix([[alpha, beta, gamma], [delta, epsilon, zeta], [eta, theta, mu]])
I would like to write a system of equations that can be solved  to get a Markov chain  irreducible and aperiodic
All the entries of the transition matrix are in the interval [0,1)
Many tanks for any help
if I use the command below, I will get the right answer.
`assuming`([simplify((2*I)*deltas*Pi*BW*Ei(1, (2*I)*deltas*Pi*BW)-(2*I)*deltas*Pi*BW*Ei(1, -(2*I)*deltas*Pi*BW))], [real, BW > 0, deltas > 0, ts > 0, deltas <= ts, 2*BW*ts >= 1])
and the answer is :
2*BW*Pi*deltas*(Pi-2*Si(2*BW*Pi*deltas))
while I use the same command for the compliacated Ei function, it doesn't work any more, I don't know the reason.
 `assuming`([simplify(Ei(1, I*BW*Pi*deltas-(5*I)*BW*Pi*ts)-Ei(1, -I*BW*Pi*deltas+(5*I)*BW*Pi*ts), Ei)], [real, BW > 0, deltas > 0, ts > 0, deltas <= ts, 2*BW*ts >= 1])
 and it's reault is :
Ei(1,I*BW*Pi*deltas-5*I*BW*Pi*ts)-Ei(1,-I*BW*Pi*deltas+5*I*BW*Pi*ts)
I am looking for a nice algorithm to determine if a polynomial is expressible as an ALGEBRAIC combination of a list of other polynomials. I have written my own for LINEAR combinations, but cannot quite generalize this method.
Any help would be greatly appreciated.
Hello, I am trying to plot an expression for my General Relativity class, this expression is one of the expanding universe FLRW solutions to the Einstein field equations and contains an unknown functions.
sqrt(S(t))*sqrt(1+S(t))-arcsinh(sqrt(S(t))) = t
My question is how do I get maple to plot this?
i use
A -> B
B -> C
would like to find A -> C directly from A -> B and B -> C
but logic table show that AND(A->B, B->C) is not equal to A -> C
and (A->B) -> (B->C) is not equal to A -> C too
which logic operations can do this?
because do not want to use result to verify and because i do not know the result in the beginning
I could keep on using the commands
with(GraphTheory):
with(RandomGraphs):
DrawGraph(RandomTree(7))
but then this is not helpful because I do not get non-isomorphic graph each time and there are repetitions. So any other suggestions would be very helpful.
I assigned the greek alphabet pi=0.45 in Maple but it displayed an error message since it is already a known constant 3.142. Please how can I assign pi to 0.45 in Maple ?
for example
func1 := proc(system1)
for i from 1 to 100 do
solve([system1[1], system1[2]],[x,y]);
func1([diff(y,t) = data[i+t+1], diff(x,t) = data[i+t+1]])
i is depend on the for loop inside a function, but woud like to pass this system into a function with i
this will cause error
how to write better for passing a system as parameter using variable inside a function?
indets(AA(MM(AA(X1,X2),B2),MM(AA(B2,X3),X5)));
this can get a list of X1,X2,B2,X3,X5
propositionsentence := MM(AA("it", "run"), "maple"):
indets(propositionsentence);
but this can not get "it", "run", "maple"
how to do this in case this in maple 12?
Dear Maple users
I was using the animation command to create an animation consisting of a running sine curve with a ball following the curve, as shown below. I wonder if it is possible to create it with the Explore command too? Or is this command more limited? I need to be able to add more animations, like I can with the display command ...
Regards, Erik.
Hello all,
So far I have been unable to find this question anywhere, but I apologize if it is a duplicate. I'm trying to evaluate the integral of sechq(x), where q is a positive integer. Mathematica is able to tell me the result (a hypergeometric function), but for some reason, Maple seems not to be able to compute this integral, it just gives me back the integral. A higher info-level on the 'int' function reveals a line that says 'Risch d.e. has no solution', but I'm not sure if that has anything to do with my problem. Any suggestions or tips on how to get an answer out of Maple would be greatly appreciated!
Hi guys,
I've had only a little experience with Maple, but I decided to use it for preliminary frequecy response calculations. The funny thing is, I have already the solution in some way, but I'm too stupid to get it working. I can't see the mistake, however, it should have something to do with the H_n(f) function and the other normalized functions.
NASA has published a nice paper which explains the calculations, however, they have used MathCAD. Anyway, I don't think this should be a problem. Here is the documentation: https://ntrs.nasa.gov/archive/nasa/casi.ntrs.nasa.gov/20070016024.pdf
The error message is for example for the H_n(f) function:
Warning, expecting only range variable f in expression H__n(f) to be plotted but found name H__n
Please help me.
Maple file: calculations.mw
First 1017 1018 1019 1020 1021 1022 1023 Last Page 1019 of 2459
