environment
- Windows 10 LTSB 64-bit
- Intel Haswell/Skylake
sequence:
1. install Windows unattended
2. install scheduletask for software installation (runs with systemaccount on windows starts and available network)
3. task runs a cmdfile(1) that map a networkshare and runs another cmdfile(2) on the networkshare
4. cmdfile(2) runs softwareinstallation one by one, every install is a seperate cmdfile
5. cmfile(maple.cmd) starts maple installation with the following cmdline
START "Maple 2016" /WAIT "N:\Math\Maple\Maple2016Windowsx86Installer.exe" --mode unattended --desktopshortcut 0 --shortcutname "Maple 2016" --configureMatlab 0 --matlabpath "" --licenseType network --serverName "licserver.company.domain" --portnumber 27000
Note: licenseserver and port are configured correctly, tested with manual installation of Maple
effects:
- installer starts and install some files (found unter C:\ProgramFiles\Maple 2016)
- installer persists in memory
- no startmenuentry for maple found
- no installler logfile in maple directory found
- install not finished
- try it with --optionfile ... -> hangs
- try copying all files to local harddisk and run it from there -> hangs
- try it running with a local administrator (using psexec) -> hangs
- if im logged in and run the installer cmdline manually with adminconsole or with systemaccount (psexec -i -s -d cmd) the installation runs perfect, but this is not what i need to install hundreds of machines
Dear Community,
I have a complicated function with two independent variables, namely QD( tD,  rD ). I would like to explore its behavior in a semilog plot in the range of tD = 1.0 .. 1000.0 with changing rDs, where I would like to change the values of rD with a slider of the Explore command. I've developed the attached code, yet it gives me an error message, "unexpected option... " Could you pls. have a look at it what do I do wrong?
Tx for the kind help in advance
best regards
Andras
 Explore_VEHQD.mw
Can anyone tell me how to combine several graphs into one? Fo instance I have one graph with x going from 0-1,another with x going from 1-20 and yet another with x going from 20-21. I can plot them individually but how do I put all three together?
I'm sorry I'm not doing a very good job explaining, but I hope it is understandable.
Thanks to the help of several list members I managed to translate and update some old procedures.  These procedures were part of a packcage and they all had help files.   Here is an example
# E. Mendes - 25/04/94
`help/text/sampling`:=TEXT(``,
`FUNCTION: sampling - finds the discretized model`,
`CALLING SEQUENCE:`,
` sampling(f)`,
` sampling(f,k)`,
` sampling(f,k,vars)`,
`PARAMETERS:`,
` f - state space`,
` k - order of approximation`,
` vars - variables`,
`SYNOPSIS:`,
`- sampling(f,k) returns a discrete approximation for a continuous`,
` system`,``,
` dx(t)/dt=f(x(t),u(t)) `,
`EXAMPLE: `,``,
`> with(linalg):`,
`> f:=vector([x2,x3,-x1+x2^2+2*x3]):`,
`> sampling(f,1)`,
` 2`,
` [- x1, x2 + x1 ]`,``,
`SEE ALSO: fixpoind, fixpoinc`):
I have browsed the help documentation but I must confess I don't feel comfortable to modify the help database.  Do I have to wrap all the functions up as a package and then write the help files?   I am lost here.  Any help will be most welcome.
Many thanks
Ed
I would like to silmplify a trigonometric equation with some squares. I'm sure this equation can be reduced but i didn't manage to simplify it with Maple.
Here is the equation (named condition in the maple file) that I would like to simplify:
simplification_condition_de_compatibilité.mw
May you help me to simplify this trigonometric equation?
I would like simplification if time the pattern cos()^2+sin()^2 appears.
Thanks a lot for your help
Pick any point P and let Q = (1, 1, 1). [Your choice for P can be anything other than the origin or
Find an equation for the line l1 that passes through P and the origin. Plot the line segment formed by P and the origin in Maple
How would I plot this?
Please, I need assistance with this problem.
Here is the problem I am trying to solve:
with(PDEtools):
with(Student):
myPDE1 := D11*diff(w(x,y), x$4) + 2*(D12+2*D66)*diff(w(x,y), y$4) + D22*diff(w(x,y), x$2, y$2) - G*diff(w(x,y), x,y)= 0;
pdsolve(myPDE1);
pdsolve(myPDE1, build);
"Boundary conditions";
"(Note:the domain for the problem is a rectangle)";
bc1 := w(0,y) = 0; # @ x=0 edge;
bc2 := w(a,y) = 0;  # @ x=a edge;
bc3 := w(x,0) = 0; # @ y=0 edge;
bc4 := w(x,b) = 0; # @ y=b edge;
bcx1 := -D11*D[2](w)(0,y) - D12*D[2](w)(0,y) = 0; # @ x=0 edge;
bcx2 := -D11*D[2](w)(a,y) - D12*D[2](w)(a,y) = 0; # @ x=a edge;
bcy1 := -D12*D[2](w)(x,0) - D22*D[2](w)(x,0) = 0; # @ y=0 edge;
bcy2 := -D12*D[2](w)(x,b) - D22*D[2](w)(x,b) = 0; # @ y=b edge;
sol := [myPDE1, bc1, bc2, bc3, bc4, bcx1, bcx2, bcy1, bcy2];
pdsolve(sol);
"Note:
and D11, D12, D22, D66 and G are constant.
The intention is to find the critical value for G"
I need help with how I can handle the boundary conditions for the problem. Thanks a million.
I want to join two animations, but displayed subsequently, not simultaniously, As far as I got, I have:
plot2 := plots[animate](plot, [tau[1], z = -(1/2)*J .. (1/2)*J, color = red, legend = shear*stress], h = 1 .. 1+1/sqrt(3));
plot3 := plots[animate](plot, [tau[2], z = -(1/2)*h .. (1/2)*h, color = red, legend = shear*stress], h = 0 .. 1);
display([plot2, plot3], insequence = true);
my functions are difined as
tau[1] := h-1+(4/3)*(1/sqrt(3)-h+1)*sqrt(3)*(sqrt(3)*((1/4)*J^2-z^2)/(J^2*b))
tau[2] := (4/3)*sqrt(3)*((1/4)*h^2-z^2)/(h^2*b)
Both plots work individually, however, they have successive ranges. I wondered if I could make 1 plot, with an if statement wether to plot tau[1] or tau[2] depending on where the animation is in the range h. Does anyone know about a solution?
I need  some examples s.t. the computation of their lexicographic Groebner basis is heavy?
Thank you so much.
Already searched and browsed multiple different threads and still cannot find a solution.
Apologizing the noob nature of this question.
In this code below, Why is the factor command not working?
f := a^2+x^2-2*ax;
a^2+x^2-2*ax
factor(f);
a^2+x^2-2*ax
expand((x-a)*(x-a));
a^2-2*a*x+x^2
Download factor_polynomial_2_multivariable.mwfactor_polynomial_2_multivariable.mw
Hello people in maple primes
I have a question, which is about the matrix shown in http://www.mapleprimes.com/questions/217852-HOW-I-Convert-Root-Of-In-To-Another-Common-Form
Why can't C below be shown with beta?
A := Matrix(3, 3, [[-a, a, 0], [0, 0, -sqrt(l*b*c*(j+k))/(j+k)], [2*j*sqrt(l*b*c*(j+k))/((j+k)*l), 2*k*sqrt(l*b*c*(j+k))/((j+k)*l), -c]]);
B:=subs(l*b*c*(j+k)=alpha,A);
C:=subs(j*alpha^(1/2) = beta,B);
e:=subs(alpha^(1/2) = gamma,B);
Best wishes.
taro
From differential expression I am trying to extract coefficients corresponding to given indets, but the coeffs command is giving me error as "invalid argument to coeffs"
For example for worksheet titled "[852] Determining Equations using Prolongation" the error is showing for expression (9).
Whereas the same command in worksheet titled "[411] Determining Equations for Variable Coeff KdV(Reviewed)" is working okay and is giving desired result at (16).
I am running both worksheets in Maple 18.
[852]_Determining_Equations_Using_Prolongation.mw
[411]_Determing_Equations_for_Variable_coefficient_KdV_(reviewed).mw
Can anybody please tell, where I can find seminar/workshops on Maple training ?
I am a new Maple user and I am still unaware of a lots of fancy features of Maple. I have a problem of simultaneous fitting polynomials. I wish that I could have help from you. Say, we have two polynomials of two variables,
f1(x,y)=a1+a2*x+a3*y+(a4+a5)*x2+(a4-a5)*y2;
f2(x,y)=b1+b2*x+b3*y+(a4-a5)*x2+(a4+a5)*y2.
Note that a4 and a5 are shared by the two polynomials. I would like to fit the two polynomials against their respective data set. Is there anyway I can do it using Maple? Any of your help is highly appreciated!
Best regards,
Toby
HI
HOW I convert root of in to another form
lorenz_5.mw
First 1078 1079 1080 1081 1082 1083 1084 Last Page 1080 of 2434
