To summarize,
dsolve numeric parametric form gives wrong answers when fdiff is used to calculate the Hessian. Doing dsolve twice gives the correct answer. Hope I am not making syntax or programming errors.
Also, fdiff is not compatible with vector form.
Digits:=15;
Digits := 15
sys:=diff(y1(t),t)=-(u+u^2/2)*y1(t),diff(y2(t),t)=u*y1(t);
sys := diff(y1(t), t) = -(u+(1/2)*(u^2))*y1(t), diff(y2(t), t) = u*y1(t)
 The system is solved with initial conditions 1,0 and value of u being equal to u1 for t<=0.5, and u2 for t>0.5. The objective is y2 at t =1. There are errors when Hessian is calculated using parametric dsolve and fdiff
sol1 := dsolve({sys, y1(0) = alpha, y2(0) = beta}, type = numeric, 'parameters' = [alpha, beta, u],maxfun=0,range=0..0.5):
obj1:=proc(u1,u2)
local z1,s1,s2,z2;
global sol1;
sol1('parameters'=[1,0,u1]);
z1 := sol1(.5);
s1:=subs(z1,y1(t));
s2:=subs(z1,y2(t));
sol1('parameters'=[s1,s2,u2]):
z2:=sol1(0.5);
-subs(z2,y2(t));
obj1 := proc (u1, u2) local z1, s1, s2, z2; global sol1; sol1('parameters' = [1, 0, u1]); z1 := sol1(.5); s1 := subs(z1, y1(t)); s2 := subs(z1, y2(t)); sol1('parameters' = [s1, s2, u2]); z2 := sol1(.5); -subs(z2, y2(t)) end proc
u0:=[0.8,1.8];
u0 := [.8, 1.8]
obj1(op(u0));
-.552540796143903
Hess1:=Matrix(2,2):for i from 1 to 2 do for j from 1 to 2 do Hess1[i,j]:=fdiff(obj1,[i,j],u0,workprec=1.0);od;od;Hess1;
Matrix(2, 2, {(1, 1) = 115.470000000000, (1, 2) = -1.11000000000000, (2, 1) = -1.11000000000000, (2, 2) = 2.22000000000000})
 Hessian is wrong. It should be noted that when dsolve is called twice inside the objective function there is no error in Hessian calculation with fdiff. The parametric dsolve is efficient, how to get correct answers with that? Another question is how to use fdiff with vector form instead u1,u2 etc to make it generic for any number of variables?
obj2:=proc(u1,u2)
local z1,s1,s2,z2,sol2;
sol2:=dsolve({op(subs(u=u1,[sys])), y1(0) = 1, y2(0) = 0}, type = numeric,maxfun=0,range=0..0.5);
z1 := sol2(.5);
s1:=subs(z1,y1(t));
s2:=subs(z1,y2(t));
sol2:=dsolve({op(subs(u=u2,[sys])), y1(0) = s1, y2(0) = s2}, type = numeric,maxfun=0,range=0..0.5):
z2:=sol2(0.5);
-subs(z2,y2(t));
obj2 := proc (u1, u2) local z1, s1, s2, z2, sol2; sol2 := dsolve({op(subs(u = u1, [sys])), y1(0) = 1, y2(0) = 0}, type = numeric, maxfun = 0, range = 0 .. .5); z1 := sol2(.5); s1 := subs(z1, y1(t)); s2 := subs(z1, y2(t)); sol2 := dsolve({op(subs(u = u2, [sys])), y1(0) = s1, y2(0) = s2}, type = numeric, maxfun = 0, range = 0 .. .5); z2 := sol2(.5); -subs(z2, y2(t)) end proc
obj2(op(u0));
-.552540796143903
Hess2:=Matrix(2,2):for i from 1 to 2 do for j from 1 to 2 do Hess2[i,j]:=fdiff(obj2,[i,j],u0,workprec=1.0);od;od;Hess2;
Matrix(2, 2, {(1, 1) = .234295697631809, (1, 2) = 0.101868715004724e-1, (2, 1) = 0.101868715004724e-1, (2, 2) = 0.853480932660994e-1})
 Doing dsolve twice gives correct answer compared to one parametric dsolve even though objective returns the same number (even gradient returns the expected answers).
Download Bugindsolveorfdiff.mws
hi
please help me for fsolve algebric equations...
AGM.mw
F(eta):=sum(a[i]*eta^i,i=0..5):
theta(eta):=sum(b[i]*eta^i,i=0..5):K(eta):=sum(c[i]*eta^i,i=0..5):Omega(eta):=sum(d[i]*eta^i,i=0..5):
U1:=diff(theta(eta), eta, eta)-3*Omega(eta)*(F(eta)*(diff(theta(eta), eta))-theta(eta)*(diff(F(eta), eta)))/(2*K(eta))+((diff(K(eta), eta))/K(eta)-(diff(Omega(eta), eta))/Omega(eta))*(diff(theta(eta), eta)) = 0:U2:= diff(F(eta), eta, eta, eta)+Omega(eta)*(3*F(eta)*(diff(F(eta), eta, eta))-(diff(F(eta), eta))^2)/(2*K(eta))+((diff(K(eta), eta))/K(eta)-(diff(Omega(eta), eta))/Omega(eta))*(diff(F(eta), eta, eta))+Omega(eta)/K(eta) = 0:U3:= diff(K(eta), eta, eta)+Omega(eta)*(1.5*F(eta)*(diff(K(eta), eta))-K(eta)*(diff(F(eta), eta)))/K(eta)+((diff(K(eta), eta))/K(eta)-(diff(Omega(eta), eta))/Omega(eta))*(diff(K(eta), eta))+(diff(F(eta), eta, eta))^2-Omega(eta)^2 = 0:U4:= diff(Omega(eta), eta, eta)+Omega(eta)*(3*F(eta)*(diff(Omega(eta), eta))+Omega(eta)*(diff(F(eta), eta)))/(2*K(eta))+((diff(K(eta), eta))/K(eta)-(diff(Omega(eta), eta))/Omega(eta))*(diff(Omega(eta), eta))+Omega(eta)*(diff(F(eta), eta, eta))^2/K(eta)-Omega(eta)^3/K(eta) = 0:
F(eta):=unapply(F(eta),eta):
theta(eta):=unapply(theta(eta),eta):K(eta):=unapply(K(eta),eta):Omega(eta):=unapply(Omega(eta),eta):
U1:=unapply(U1,eta):U2:=unapply(U2,eta):U3:=unapply(U3,eta):U4:=unapply(U4,eta):
s1:=F(eta)(0) = 0:
s2:=K(eta)(0) = 0:s3:=Omega(eta)(0) = 0:s4:=theta(eta)(0) = 1:s5:=theta(eta)(1) = 0:s6:=(D(F(eta)))(0) = 0:s7:=(D(K(eta)))(1) = 0:s8:=(D(Omega(eta)))(1) = 0:s9:=((D@@2)(F(eta)))(1) = 0
20*a[5]+12*a[4]+6*a[3]+2*a[2] = 0
s10:=U1(0):s11:=U2(0):s12:=U3(0):s13:=U4(0):        s14:=U1(1):s15:=U2(1):s16:=U3(1):s17:=U4(1):    s18:=D(U1)(0):s19:=D(U2)(0):s20:=D(U3)(0):s21:=D(U4)(0):     s22:=D(U1)(1):s23:=D(U2)(1):s24:=D(U3)(1):
Q:=fsolve([s1,s2,s3,s4,s5,s6,s7,s8,s9,s10,s11,s12,s13,s14,s15,s16,s17,s18,s19,s20,s21,s22,s23,s24],{a[0],a[1],a[2],a[3],a[4],a[5],b[0],b[1],b[2],b[3],b[4],b[5],c[0],c[1],c[2],c[3],c[4],c[5],d[0],d[1],d[2],d[3],d[4],d[5]}):
F(eta):=eval(sum(a[i]*eta^i,i=0..5),Q):
Error, invalid input: eval received S, which is not valid for its 2nd argument, eqns
theta(eta):=eval(sum(b[i]*eta^i,i=0..5),Q):K(eta):=eval(sum(c[i]*eta^i,i=0..5),Q):Omega(eta):=eval(sum(d[i]*eta^i,i=0..5),Q):
plot(g(x),x=0..1,axes=boxed,color=green,thickness=2,labels=[x,g]):
plot(f(x),x=0..1,axes=boxed,color=blue,thickness=2,labels=[x,f]):
Download AGM.mw
I consider  100 .100 real matrices A,B=Matrix(100,100,(i,j)->rand()) (with 12 significant digits).  In general, ConditionNumber(A) is <10^5; also I choose Digits:=17.Theoretically, the complexity of the calculations of Determinant(A), CharacteristicPolynomial(A,x), A.B and MatrixInverse(A) are similar (~n^3). Yet, the times of these calculations are respectively: 0"13, 0"67, 0"60 and, what surprises me, 75" (moreover, I don't display any result).
My question: concerning the calculation of the inverse, where does this factor 100 come from ? Would Matlab  be 100 times faster ? I do not see why this would be the case; in particular, the standard methods for the calculation of the inverse are  easily programmable.
T := proc (t) options operator, arrow; 80+(-1)*1.4375*53*(1-exp((-1)*0.13775e-1*2.875*k*h__1*h__2*t/(1.4375^2*4190*(k*(h__1+h__2)+0.1e-2*h__1*h__2))))/2.875 end proc
proc (t) options operator, arrow; 80+(-1)*1.4375*53*(1-exp((-1)*0.13775e-1*2.875*k*h__1*h__2*t/((1.4375^2*4190*(k*(h__1+h__2)+0.1e-2*h__1*h__2)))))/2.875 end proc
T(204.39)
53.50000000+26.50000000*exp(-8.094482719*k*h__1*h__2/(8658.242188*k*(h__1+h__2)+8.658242188*h__1*h__2))
T(429.63)
53.50000000+26.50000000*exp(-17.01469059*k*h__1*h__2/(8658.242188*k*(h__1+h__2)+8.658242188*h__1*h__2))
T(872.5)
53.50000000+26.50000000*exp(-34.55372656*k*h__1*h__2/(8658.242188*k*(h__1+h__2)+8.658242188*h__1*h__2))
fsolve({53.50000000+26.50000000*exp(-34.55372656*k*h__1*h__2/(8658.242188*k*(h__1+h__2)+8.658242188*h__1*h__2)) = 56.15, 53.50000000+26.50000000*exp(-17.01469059*k*h__1*h__2/(8658.242188*k*(h__1+h__2)+8.658242188*h__1*h__2)) = 64.1, 53.50000000+26.50000000*exp(-8.094482719*k*h__1*h__2/(8658.242188*k*(h__1+h__2)+8.658242188*h__1*h__2)) = 72.05}, {h__1 = 0 .. 1000, h__2 = 0 .. 1000, k = 0 .. 1000})
fsolve({53.50000000+26.50000000*exp(-34.55372656*k*h__1*h__2/(8658.242188*k*(h__1+h__2)+8.658242188*h__1*h__2)) = 56.15, 53.50000000+26.50000000*exp(-17.01469059*k*h__1*h__2/(8658.242188*k*(h__1+h__2)+8.658242188*h__1*h__2)) = 64.1, 53.50000000+26.50000000*exp(-8.094482719*k*h__1*h__2/(8658.242188*k*(h__1+h__2)+8.658242188*h__1*h__2)) = 72.05}, {h__1, h__2, k}, {h__1 = 0 .. 1000, h__2 = 0 .. 1000, k = 0 .. 1000})
it would be great if you could explain me why maple cant numerically solve this set of 3 ecuatios for h1, h2, k being my unknows terms, it works with an exponential function. there is a way to solve it?
thanks..
Download heat_ecuation.mw
I have code
implicitplot3d((r*sin(theta)*cos(phi))^2+(r*sin(theta)*sin(phi))^2+(r*cos(theta))^2=36,r=-3..3, phi=0..2*Pi,theta=0..Pi,coords=spherical);
How can I fix the code to display the picture
How to plot f(x)=x in the interval -2<x<2 with a period 4?
The plot should look like this
How do i generate 4d plot of f(x,y,z)=1 is it possible made it in 3d?
So I am trying to find the structure of a material from x-ray diffraction data. To accomplish this I have to solve a system of nonlinear equations. Since there is some unaccuracy in the measurements I wanted to use a numerical tool, so I am trying to solve using fsolve. To check that I am doing this correctly I am trying to solve a set of similar equations where I know the solution. My code is shown below.
eqs := {(2^2/a^2+2^2/c^2-2*(2*2)*cos(x)/(a*c))/sin(x)^2 = 1/2.2393^2, (2^2/a^2+4^2/c^2+4*(2*2)*cos(x)/(a*c))/sin(x)^2 = 1/1.5968^2, (1^2/a^2+sin(x)^2/b^2+2^2/c^2+(2*2)*cos(x)/(a*c))/sin(x)^2 = 1/2.7896^2, 1/sin(x)^2*(2^2*sin(x)^2/b^2) = 1/2.8650^2}
fsolve(eqs)
For this system I know that a = 5.44 b = 5.73 c = 7.89 x=pi/2, but fsolve only returns the input.
Am I doing something wrong or should I use a different function? I am quite new to Maple, so have some patience with me.
Hello! Prompt please as in Maple can determine the distribution function of the resulting histogram distribution? I know about cdf function, but how to act in relation to the histogram do not know.
Histogram:
with(stats);
with(stats[statplots]);
data2 := [30, 30.5, 31, 31.5, 32, 32.5, 32.6, 33, 33.1, 33.3, 33.6, 34, 35, 36];
histogram(data2, area = count);
In other words, I need smoothing the histogram, get graph and get on it to obtain an analytical expression.
Aslam o Alikum!
Hope everyone going fine with sound health I want to make the graph of following system of ODEs
Eq1 := diff(F(eta), eta, eta, eta, eta)-M*(eta*(diff(F(eta), eta, eta, eta))+3*(diff(F(eta), eta, eta))+(diff(F(eta), eta))*(diff(F(eta), eta, eta))-F(eta)*(diff(F(eta), eta, eta, eta)))-Ha^2*(diff(F(eta), eta, eta));
Eq2 := diff(G(eta), eta, eta)+Pr*M*(F(eta)*(diff(G(eta), eta))-eta*(diff(G(eta), eta)))+Pr*Ec*(diff(F(eta), eta, eta))^2+Nb*(diff(H(eta), eta))+diff(G(eta), eta)+Nt*(diff(G(eta), eta))^2;
Eq3 := diff(H(eta), eta, eta)+M*Sc*(F(eta)*(diff(H(eta), eta))-eta*(diff(H(eta), eta)))+Nt*(diff(F(eta), eta, eta))/Nb;
using the BC's
IC1 := F(0) = 0, ((D@@2)(F))(0) = 0, (D(G))(0) = 0, (D(H))(0) = 0;
     F(0) = 0, @@(D, 2)(F)(0) = 0, D(G)(0) = 0, D(H)(0) = 0
IC2 := F(1) = 1, (D(F))(1) = 0, G(1) = 1, H(1) = 1;
for Ec := .1; Nt := .1; Nb := .1; Sc := .5; Pr := 10; M := .5; and different values of Ha like Ha:=0, Ha:=2, Ha:=4, Ha:=6 and Ha:=8 in one coordinate.
I am waiting your positive response.
Hello all, first time posting on here so if I make any mistakes please let me know. So I have created a function called "g" and plotted it on a graph. After looking at the two graphs I have plotted (one with discont=false and one with discont=true), I can see 3 discontinuities are present. However, attempting to solve for these discontinuities by setting the denominator of "g" = 0 only returns 1 of the points. I'm not sure why this is happening and how would I go by solving for the other 2 points? Thank you.
f := exp(x-188.5)-4*x^2+1507.964*x-142122.3+cos(x)^2;
g := (-f+x^2-376.991*x+35530.6)/(f+x^2-376.991*x+35530.6);
(-exp(x-188.5)+5*x^2-1884.955*x+177652.9-cos(x)^2)/(exp(x-188.5)-3*x^2+1130.973*x-106591.7+cos(x)^2)
plot(g, x = 186 .. 194, y = -25 .. 25,discont=false)
plot(g, x = 186 .. 194, y = -25 .. 25,discont=true)
vasymp := fsolve( denom(g)=0);
192.2026966
My script has multiple animations, in which the range of the variable is larger then I wish to see. Therefore, I have used the view=[x1..x2,y1..y2] command, which has different values for every plot. Plotted seperately, this gives me exactly what I want. However, if I combine the plots using display(A,B,C) they loose their individual views. Instead, maple chooses the view of plot A, and plots B an C in the range defined by view A.
Is there a way to combine plots and still maintain individual views, within the largest view?
Kind regards,
Bastiaan Overdorp
Am trying to valid a research work done by kuiken(1968)
Kuiken_(1968).pdf
where we have this two eauations:
Digits := 35;
with(ODETools);
with(student);
inf := 4;
equ1 := diff(f[0](eta), `$`(eta, 3))+theta[0](eta);
equ2 := diff(theta[0](eta), `$`(eta, 2))+3*f[0](eta)*(diff(theta[0](eta), eta));
Bcs1 := f[0](0) = 0, (D(f[0]))(0) = 0, theta[0](0) = 1, theta[0](inf) = 0, (D(D(f[0])))(inf) = 0;
S1 := dsolve({Bcs1, equ1, equ2}, {f[0](eta), theta[0](eta)}, type = numeric, method = bvp[midrich]);
proc(x_bvp)  ...  end;
S1(0);
[                            d
[eta = 0., f[0](eta) = 0., ----- f[0](eta) = 0.,
[                           deta
    d   /  d            \
  ----- |----- f[0](eta)| = 0.82449782146165697398999365896678734,
   deta \ deta          /
  theta[0](eta) = 1.0000000000000000000000000000000000,
    d                                                         ]
  ----- theta[0](eta) = -0.71098574970825563256340736114251047]
   deta                                                       ]
S1(inf);
[eta = 4., f[0](eta) = 1.7815670728545914261072119522795076,
    d
  ----- f[0](eta) = 0.51061876174095320088291844433043562,
   deta
    d   /  d            \
  ----- |----- f[0](eta)| = 0., theta[0](eta) = 0.,
   deta \ deta          /
    d
  ----- theta[0](eta) = -0.000054818176138173095945902421930470836
   deta
Pls, I need to find the function of the limit of f[0](eta) at eta tend to infinity. checked equation 45 of the attached document and for the two equation pls checked equation 36 and 37 for the ODE equation solved above.
Kuiken_solution for equation 36 and 37.pdf
Is it possible to animate plot like this parametically:
animate(plot, [[cos(t), sin(t), t = 0 .. A]], A = 0 .. 2*Pi, scaling = constrained, frames = 50)
however given the x and y components as solutions of an implicit equation.
I know I could run RootOf. But it seems that there is a part missing due to a branch cut :-/
What do people find a good screen size is?
Personally I find two monitors would be ideal for using Maple and especially Maplesim.  I'm going to be adding a second monitor, probably a 20".  Maybe 24" is better?  I think 20" would be enough.  Just wondering how many monitors people out there work with and their monitor sizes.
First 1086 1087 1088 1089 1090 1091 1092 Last Page 1088 of 2460
