Dear forum users/ admins, I have some questions regarding the wind turbine vibrations model based on the MapleSim gallery. I am a new user, went through some tutorials and am currently trying to understand how the system works.
I will try to deliver my questions based on the pictures shown below:
 1. After running the model, 2 results were shown. One is "Latest Results" and the other is "zeta=0.01". Based on the images above, there is a comment that the result was dated Feb 14 2013. Is this the result on which the day the model was created? If it is, is it programmed to be in the result file everytime the simulation runs?
2. If I untick "zeta=0.01", a red graph appears, which says Latest Result. But the graphs are not labelled. How can I label this graph in MapleSim?
3. I would also like to ask, what type of vibrations are occuring in the model, and what does the Deflection-Time graph means. Why does the deflection occur highest at 120s and then drops? Is it because the tower becomes stabilized after a while?
4. I understand that the model is run by a signal and fed into a speed component. May I know what is the f(critical) is, and how it affects the system?
5. From the Ramp signal, there is a "height" value. The pre-set value is 10. After changing this value, to lets say 50, the maximum deflections occur at a an earlier time as shown in the figure below:
6. I would like to understand how does the ramp affect the maximum deflection time that occurs.
Thank you very much!
Hello, I am using PDEtools to evaluate an equation but got system inconsistent in respect of a parameter used after the command map(pdsolve). I am afraid the result sebsequently given may not be correct, did I do something wrong?
test.mw
I'm preparing for my analysis exam but i'm having some trouble finding particular solutions for this differential equation. I used both the command to fully solve it and the command for particular solutions but neither gives me a proper result. Am I doing something wrong?
Hi everyone,
I'm tryng to find the equations of motion of a 5 DOF arm using Lagrange's method, but I'm pretty new at using Maple. So far, the code is:
#Método de lagrange
with(VectorCalculus):
#Origem
Orig:= <0|0|0>:
#Cinematica direta
T43:= Matrix([[1,0,0,0],[0,1,0,0],[0,0,1,L1],[0,0,0,1]]):
T76:= Matrix([[1,0,0,0],[0,1,0,0],[0,0,1,L2],[0,0,0,1]]):
R10:= Matrix([ [1,0,0,0] , [0,cos(q1(t)),-sin(q1(t)),0] , [0,sin(q1(t)),cos(q1(t)),0] , [0,0,0,1] ]):
R21:= Matrix([ [cos(q2(t)),0,-sin(q2(t)),0] , [0,1,0,0] , [sin(q2(t)),0,cos(q2(t)),0] , [0,0,0,1] ]):
R32:= Matrix([ [cos(q3(t)),sin(q3(t)),0,0] , [-sin(q3(t)),cos(q3(t)),0,0] , [0,0,1,0] , [0,0,0,1] ]):
R54:= Matrix([ [cos(q4(t)),0,-sin(q4(t)),0] , [0,1,0,0] , [sin(q4(t)),0,cos(q4(t)),0] , [0,0,0,1] ]):
R65:= Matrix([ [cos(q5(t)),sin(q5(t)),0,0] , [-sin(q5(t)),cos(q5(t)),0,0] , [0,0,1,0] , [0,0,0,1] ]):
Rr10:= Matrix([ [1,0,0] , [0,cos(q1(t)),-sin(q1(t))] , [0,sin(q1(t)),cos(q1(t))] ]):
Rr21:= Matrix([ [cos(q2(t)),0,-sin(q2(t))] , [0,1,0] , [sin(q2(t)),0,cos(q2(t))] ]):
Rr32:= Matrix([ [cos(q3(t)),sin(q3(t)),0] , [-sin(q3(t)),cos(q3(t)),0] , [0,0,1] ]):
Rr54:= Matrix([ [cos(q4(t)),0,-sin(q4(t))] , [0,1,0] , [sin(q4(t)),0,cos(q4(t))] ]):
Rr65:= Matrix([ [cos(q5(t)),sin(q5(t)),0] , [-sin(q5(t)),cos(q5(t)),0] , [0,0,1] ]):
#Coordenadas das juntas
A:= <0|0|0>:
Br:= R10.R21.R32.T43:
B:= <Br[1,4]|Br[2,4]|Br[3,4]>:
Cr:= R10.R21.R32.T43.R54.R65.T76:
C:= <Cr[1,4]|Cr[2,4]|Cr[3,4]>:
#Coordenadas dos centros de massa
TC43:= Matrix([[1,0,0,0],[0,1,0,0],[0,0,1,L1/2],[0,0,0,1]]):
MC1:=R10.R21.R32.TC43:
C1:=<MC1[1,4]|MC1[2,4]|MC1[3,4]>:
C1z := C1[3]:
TC76:= Matrix([[1,0,0,0],[0,1,0,0],[0,0,1,L2/2],[0,0,0,1]]):
MC2:=R10.R21.R32.T43.R54.R65.TC76:
C2:=<MC2[1,4]|MC2[2,4]|MC2[3,4]>:
C2z := C2[3]:
#Calculo da velocidade dos centros de massa
VPc1:= diff(C1,t):
VPc2:= diff(C2,t):
#Calculo da velocidade angular
wC1 := Transpose(Rr10.<v1,0,0> + Rr10.Rr21.<0,v2,0> + Rr10.Rr21.Rr32.<0,0,v3>):
wC2 := Transpose(Rr10.<v1,0,0> + Rr10.Rr21.<0,v2,0> + Rr10.Rr21.Rr32.<0,0,v3> + Rr10.Rr21.Rr32.Rr54.<0,v4,0>):
#Momento de inercia
Ic1:= (1/12)*m1*L1^2:
Ic2:= (1/12)*m2*L2^2:
#Energia cinética
Ec11:= (m1/2)*(VPc1.Transpose(VPc1)) + (Ic1/2)*(wC1.Transpose(wC1)):
Ec1:= simplify(Ec11):
Ec22:= (m2/2)*(VPc2.Transpose(VPc2)) + (Ic2/2)*(wC2.Transpose(wC2)):
Ec2:= simplify(Ec22):
#Energia potencial
Uc1:=m1.g.C1z:
Uc2:=m2.g.C2z:
#Energia cinetica - energia potencial
T1 := Ec1 + Ec2 - Uc1 - Uc2:
#T:= subs(diff(q1(t),t)=v1(t),diff(q2(t),t)=v2(t),diff(q3(t),t)=v3(t),diff(q4(t),t)=v4(t),diff(q5(t),t)=v5(t),diff(v1(t),t)=a1(t),diff(v2(t),t)=a2(t),diff(v3(t),t)=a3(t),diff(v4(t),t)=a4(t),diff(v5(t),t)=a5(t), T1):
T:= subs(diff(q1(t),t)=v1,diff(q2(t),t)=v2,diff(q3(t),t)=v3,diff(q4(t),t)=v4,diff(q5(t),t)=v5,q1(t)=q1,q2(t)=q2,q3(t)=q3,q4(t)=q4,q5(t)=q5, T1):
Eq11:=diff(T,v1):
#Tv1:=convert(Tv1,diff):
Eq12:=diff(T,q1):
#Tq1:=convert(Tq1,diff):
Eq13 := subs(q1=q1(t),q2=q2(t),q3=q3(t),q4=q4(t),q5=q5(t),v1=diff(q1(t),t),v2=diff(q2(t),t),v3=diff(q3(t),t),v4=diff(q4(t),t),v5=diff(q5(t),t), Eq11):
Eq14 := subs(q1=q1(t),q2=q2(t),q3=q3(t),q4=q4(t),q5=q5(t),v1=diff(q1(t),t),v2=diff(q2(t),t),v3=diff(q3(t),t),v4=diff(q4(t),t),v5=diff(q5(t),t), Eq12):
Eq15:= diff(Eq13,t):
Eqqqq16 := Eq15-Eq14=0:
##Lagrangiano
Eqqq16:=expand(Eqqqq16):
Eqq16:=convert(Eqqq16,diff):
Eq16:=collect(Eqq16,diff):
Eq21:=diff(T,v2):
Eq22:=diff(T,q2):
Eq23 := subs(q1=q1(t),q2=q2(t),q3=q3(t),q4=q4(t),q5=q5(t),v1=diff(q1(t),t),v2=diff(q2(t),t),v3=diff(q3(t),t),v4=diff(q4(t),t),v5=diff(q5(t),t), Eq21):
Eq24 := subs(q1=q1(t),q2=q2(t),q3=q3(t),q4=q4(t),q5=q5(t),v1=diff(q1(t),t),v2=diff(q2(t),t),v3=diff(q3(t),t),v4=diff(q4(t),t),v5=diff(q5(t),t),Eq22):
Eq25:= diff(Eq23,t):
Eqqqq26 := Eq25-Eq24=0:
##Lagrangiano
Eqqq26:=expand(Eqqqq26):
Eqq26:=convert(Eqqq26,diff):
Eq26:=collect(Eqq26,diff):
Eq31:=diff(T,v3):
Eq32:=diff(T,q3):
Eq33 := subs(q1=q1(t),q2=q2(t),q3=q3(t),q4=q4(t),q5=q5(t),v1=diff(q1(t),t),v2=diff(q2(t),t),v3=diff(q3(t),t),v4=diff(q4(t),t),v5=diff(q5(t),t), Eq31):
Eq34 := subs(vq1=q1(t),q2=q2(t),q3=q3(t),q4=q4(t),q5=q5(t),v1=diff(q1(t),t),v2=diff(q2(t),t),v3=diff(q3(t),t),v4=diff(q4(t),t),v5=diff(q5(t),t), Eq32):
Eq35:= diff(Eq33,t):
Eqqqq36 := Eq35-Eq34=0:
##Lagrangiano
Eqqq36:=expand(Eqqqq36):
Eqq36:=convert(Eqqq36,diff):
Eq36:=collect(Eqq36,diff):
Eq41:=diff(T,v4):
Eq42:=diff(T,q4):
Eq43 := subs(q1=q1(t),q2=q2(t),q3=q3(t),q4=q4(t),q5=q5(t),v1=diff(q1(t),t),v2=diff(q2(t),t),v3=diff(q3(t),t),v4=diff(q4(t),t),v5=diff(q5(t),t), Eq41):
Eq44 := subs(q1=q1(t),q2=q2(t),q3=q3(t),q4=q4(t),q5=q5(t),v1=diff(q1(t),t),v2=diff(q2(t),t),v3=diff(q3(t),t),v4=diff(q4(t),t),v5=diff(q5(t),t), Eq42):
Eq45:= diff(Eq43,t):
Eqqqq46 := Eq45-Eq44=0:
##Lagrangiano
Eqqq46:=expand(Eqqqq46):
Eqq46:=convert(Eqqq46,diff):
Eq46:=collect(Eqq46,diff):
Eq51:=diff(T,v5):
Eq52:=diff(T,q5):
Eq53 := subs(q1=q1(t),q2=q2(t),q3=q3(t),q4=q4(t),q5=q5(t),v1=diff(q1(t),t),v2=diff(q2(t),t),v3=diff(q3(t),t),v4=diff(q4(t),t),v5=diff(q5(t),t), Eq15):
Eq54 := subs(q1=q1(t),q2=q2(t),q3=q3(t),q4=q4(t),q5=q5(t),v1=diff(q1(t),t),v2=diff(q2(t),t),v3=diff(q3(t),t),v4=diff(q4(t),t),v5=diff(q5(t),t), Eq52):
Eq55:= diff(Eq53,t):
Eqqqq56 := Eq55-Eq54=0:
##Lagrangiano
Eqqq56:=expand(Eqqqq56):
Eqq56:=convert(Eqqq56,diff):
Eq56:=collect(Eqq56,diff):
##Substituicao de dados
Lagran1 := subs[eval](L1=1, m1=1, L2=1, m2=1, g=9.81 , Eq16):
Lagran2 := subs[eval](L1=1, m1=1, L2=1, m2=1, g=9.81 , Eq26):
Lagran3 := subs[eval](L1=1, m1=1, L2=1, m2=1, g=9.81 , Eq36):
Lagran4 := subs[eval](L1=1, m1=1, L2=1, m2=1, g=9.81 , Eq46):
Lagran5 := subs[eval](L1=1, m1=1, L2=1, m2=1, g=9.81 , Eq56):
## Solucao do sistema para encontrar as derivadas segundas ddqn/dt
ini:= q1(0)= Pi/10, q2(0)=0, q3(0)=0, q4(0)=0, q5(0)=0, eval (diff (q1(t), t), t=0)=0,eval (diff (q2(t), t), t=0)=0, eval (diff (q3(t), t), t=0)=0, eval (diff (q4(t), t), t=0)=0, eval (diff (q5(t), t), t=0)=0,eval (diff (q1(t), t$2), t=0)=0,eval (diff (q2(t), t$2), t=0)=0, eval (diff (q3(t), t$2), t=0)=0, eval (diff (q4(t), t$2), t=0)=0, eval (diff (q5(t), t$2), t=0)=0:
sol := dsolve({Lagran1, Lagran2, Lagran3, Lagran4, Lagran5, ini},{q1(t), q2(t), q3(t), q4(t), q5(t)}, numeric, output=listprocedure):
The problem is I'm stuck with the following error using dsolve:
Error, (in dsolve/numeric/process_input) unknown q1(t) present in ODE system is not a specified dependent variable or evaluatable procedure
Could someone show me what's wrong?
Any help would be greatly appreciated, thanks in advance!
I have this maple program, let's call it 1.mw. I need to import the data produced in 1.mw to another file, 2.mw and use it there, how do I go about this? Also how can I export the result produced in 2.mw to a different file (not necessarily a maple file). I am not sure about the right time to use, but maybe the question is, how do I get data from 1.mw to use in 2.mw, and then produce the result from 2.mw in another file?
Vic.
I wish to study the trend of medical consultations each day during six years. Thus I expect near 2200 datas to analyse.
But some parameters are to consider :
- I don't have yet the datas per day, but the mean is about 2 consultations per day
- as it is difficult to do more than 3 or perhaps 4 consultations during one day (9h30 am - 13h pm), the others if they exist will probably be seen the next day (aso if the next day 3 news consultations occured)
- then, I don't know actually (as I expect the datas or each day but don't have now these datas) if the better distribution will be simply follow a Poisson' law, or exponential, or negative binomial, ..
- do someone have a clue for the better law given what i said ?
Further, I don't have a stastic program especially used for time trend, excepting Systran 13, but I don't believe that this program can be used with a theoric model of distribution, I recall that it does usual tasks, autocorrelations, saisonnal adjustments, .. but with continuous distributions I believe, and a linear model (removing the basic frequencies)
As such program (study of temporal series) is usually sold about 3000$ in France, that I don't expect to be a trader, with only one calculus to do, could anyone tell me how to adjust the better model to the 2200 datas that could be expected ?
Thx for your help, friendly yours;
Milos
Has anyone had any luck integrating Maple TA and Ellucian Banner? Specifically storing the test scores in the banner SORTEST table using the Maple TA Web Services API?
More generally, has anyone had an luck pulling scored in to ANY system using the Web API? Care to share a sample of your code?
-Grant
I apologize because this is not a technical question but I believe that the question and issue that I have is probably of interest to a wide range of Maple users.   I am a retired biophysicist and have been using Maple as a tool in my research since Maple 5.  I recently became aware of the amazing Maple Physics Package.  It seems to offer an incredible advance.  I say “seems” because its notation and complexity is a bit overwhelming.  What I was hoping to find was a complete course (or courses) in physics that used this package.  I was hoping that with such a course I could go through it in detail and could relearn physics and become proficient in using the package.  Unfortunately, after considerable search, I could not find such a course.  (There are some older brief tutorials that do not take advantage of the features in the new Physics package.)  I am sure that there must be some physics courses that are based around this Physics Package, certainly at the University of Waterloo or the Perimeter Institute.  I would like to suggest that these courses be made available online (with a fee if necessary).  If such courses were available I know that I would avidly use them as I am sure would many others.
Hi there,
            I am new to maple. I want to ask a simple question.
            If I have a array, and I want its each component to take natural logarithm. How can I do?
            Eg:[2 3 4]->[ln(2) ln(3) ln(4)]
Dirichlet
Simple test of GaussianElimination function
Why doesn't this work?
Also can I just confirm that for GaussianElimination (according to the help this uses LUDecomposition function with the output=['U'] option) the input is the augmented matrix of the system, the coefficient matrix augmented with the RHS)
In a separate test I got an example working using this code, but I've never seen this syntax before for A Matrix (using << it seems?)
Thank you for your help.
ORIGINAL ATTEMPT
A := matrix(3, 3, [-3, 2, 1, 1, -2, 1, 1, 2, -3]);
Matrix(3, 3, {(1, 1) = -3, (1, 2) = 2, (1, 3) = 1, (2, 1) = 1, (2, 2) = -2, (2, 3) = 1, (3, 1) = 1, (3, 2) = 2, (3, 3) = -3})
GaussianElimination(A)
Error, (in LinearAlgebra:-GaussianElimination) invalid input: LinearAlgebra:-GaussianElimination expects its 1st argument, A, to be of type Matrix() but received A
Download gauss_elimination_2.mw
I wonder why the thole procedure becomes ... when converting from 1-D math to 2-D math.
It's funny how Maple automatically evaluates an expression, it can be frustrating at times, but suppose the user wants it entered the way he types.
a:=sin(-4-Phi)
                   - sin ( 4 + Phi)  #automatically evaluates the negative outside
b:=sin(x+y+z-Phi)
                   - sin (-x -y -z + Phi)
Even though both expressions are the same it seems Maple prefers -sin to +sin, in the second example above Maple has now 3 extra negatives.
Is all we need just a double set of single quotes around our expression so that when we recall that variable it returns exactly how we entered it in?
b:= ''sin(x+y+z-Phi)''
           b:= ' sin(x+y+z-Phi) '
b;
      sin( x + y + z - Phi)
Would that work?  Where would that fail?  Is there a better way?
hi...please help me for solve this nonlinear equations with pdsolve
thanksoffcenter2.mw
La := .25; Lb := 0.1e-1
h := 0.4e-2
rho := 7900
E := 0.200e12
nu := .3
ve := 5
g := 9.8
M := .5
Z0 := 0.1e-2
K := 5/6
C := sqrt(E/rho)
PDE[1] := diff(u(x, t), x, x)+(diff(w(x, t), x))*(diff(w(x, t), x, x)) = (diff(u(x, t), t, t))/C^2
diff(diff(u(x, t), x), x)+(diff(w(x, t), x))*(diff(diff(w(x, t), x), x)) = 0.3949999999e-7*(diff(diff(u(x, t), t), t))
PDE[2] := K*(diff(phi(x, t), x)+diff(w(x, t), x, x))/(2*(1+nu))+(diff(w(x, t), x))*(diff(u(x, t), x, x))+(diff(u(x, t), x))*(diff(w(x, t), x, x))+(3/2)*(diff(w(x, t), x, x))*(diff(w(x, t), x))^2 = (diff(w(x, t), t, t))/C^2
.3205128205*(diff(phi(x, t), x))+.3205128205*(diff(diff(w(x, t), x), x))+(diff(w(x, t), x))*(diff(diff(u(x, t), x), x))+(diff(u(x, t), x))*(diff(diff(w(x, t), x), x))+(3/2)*(diff(diff(w(x, t), x), x))*(diff(w(x, t), x))^2 = 0.3949999999e-7*(diff(diff(w(x, t), t), t))
PDE[3] := diff(phi(x, t), x, x)-6*K*(diff(w(x, t), x)+phi(x, t))/(h^2*(1+nu)) = (diff(phi(x, t), t, t))/C^2
diff(diff(phi(x, t), x), x)-240384.6154*(diff(w(x, t), x))-240384.6154*phi(x, t) = 0.3949999999e-7*(diff(diff(phi(x, t), t), t))
at x= La
PDE[a1] := diff(u(x, t), x)+(1/2)*(diff(w(x, t), x))^2-M*(g-(diff(u(x, t), t, t))-Z0*(diff(phi(x, t), t, t)))/(E*Lb*h) = 0
diff(u(x, t), x)+(1/2)*(diff(w(x, t), x))^2-0.6125000000e-6+0.6250000000e-7*(diff(diff(u(x, t), t), t))+0.6250000000e-10*(diff(diff(phi(x, t), t), t)) = 0
PDE[a2] := diff(phi(x, t), x)-12*M*Z0*(g-(diff(u(x, t), t, t))-Z0*(diff(phi(x, t), t, t)))/(E*Lb*h^3) = 0
diff(phi(x, t), x)-0.4593750000e-3+0.4687500000e-4*(diff(diff(u(x, t), t), t))+0.4687500000e-7*(diff(diff(phi(x, t), t), t)) = 0
PDE[a3] := w(x, t) = 0
w(x, t) = 0
at x=0 NULL
PDE[b1] := u(x, t) = 0
PDE[b2] := w(x, t) = 0
PDE[b3] := diff(phi(x, t), x) = 0
at t=0 for x= [0,La]
u(x, t) = 0
u(x, t) = 0
w(x, t) = 0
w(x, t) = 0
phi(x, t) = 0
phi(x, t) = 0
diff(phi(x, t), t) = 0
diff(w(x, t), t) = 0
(14)
diff(phi(x, t), t, t) = 0
diff(diff(phi(x, t), t), t) = 0
(15)
diff(w(x, t), t, t) = 0
diff(diff(w(x, t), t), t) = 0
(16)
at t=0 for x= [0,La)
diff(u(x, t), t) = 0
(17)
diff(u(x, t), t, t) = 0
diff(diff(u(x, t), t), t) = 0
(18)
at t=0 for x=La
diff(u(x, t), t) = -ve
diff(u(x, t), t) = -5
(19)
diff(u(x, t), t, t) = g
diff(diff(u(x, t), t), t) = 9.8
(20)
Download offcenter2.mw
Hello all,
Thanks for having a look at my issue. I need to plot the solution to this particular equation called eq1 in my worksheet. The plot needs to be w against q. Any help is greatly appreciated! Thank you in advance!
Gambia ManTheoretical_Analysis_Attempt.mw
Can some one help me for converting three or two coupled pdes to odes using Lie group or any other method in maple
First 1123 1124 1125 1126 1127 1128 1129 Last Page 1125 of 2460
